Hi guys,
On the topic of the D3 underwater without strobes. I have also been giving a lot of thought to this very topic. I have just boght a D3, but at present don't have a housing so all thoughts on the subject are merely conjectural and theoretical. I currently shoot with Nikon F5's and film and have always felt that if I were to begin shooting with digital, it would be because the digital camera had to have some significant capability that my film cameras didn't have - other than instant gratification and many more shots per dive.
Nikon has finally entered the "full-frame" arena with a camera that does offer at least one very huge advantage - its very low light capability (high ISO). It also allows me to use all the same lenses I have becomes used with film in exactly the same way. For shots without flash, the high ISO capabilities will allow us to shoot earlier and later into each day and still use a color correcting filter such as the "Magic Filter" without missing the extra f-stops the filter eats. A nice plus for shooting subjects like whales.
The high ISO's would allow shooting very large subjects - whales and other marine mammals, large reef walls, etc using fill flash where the same strobes wouldn't have a high enough guide number (enough power) to provide illumination from greater distances. This can work ONLY if the ambient light is low enough that it doesn't overpower the strobe fill. A possible example of where this might be of real value is shooting something like the Orcas feeding on herring in Norway. In the age of film you had to push process high ISO film to even get a grainy image. I believe the D3 with ISO 1600 or 3200 or even 6400 would be capable of getting a much better quality image. AND be able to do it with fill flash to make the picture even better.
Another area where higher ISO might be useful is trying to shoot "super-macro" shots with water color as a background. Right now, with ISO 100 film it takes virtually all the muscle two Hartenberger 625 strobes can put out to simply correctly a 4.4x lifesize image on film for which I use 92mm of Kenko extension tubes combined with a Nikon 2x converter between my F5 and the 105mm Micro-Nikkor. I shoot at between the marked f16 and f22. But there is an effective aperture loss of about 5-6 apertures which means that wide open (at f2.8) the lens about f18 and the shooting aperture is somewhere between f90 and f128. And no water color is recorded. With a much higher ISO you would need much less strobe muscle (Ikelite 50's or 125's) AND possibly be able to get a blue water color which can really enhance the shot vs the "night-like" black.
And even regular macro can benefit. While in Komodo in 2005 I shot a Tozeuma shrimp down at about 20 meters. I was "last in line" for the shrimp and thus had all the time I wanted with it. First I shot a few frames of the standard black background. Shot at about 1/250 at F18-f20 with the 70-180 Micro-nikkor zoom. And then I scrunched way down into the black sand and shot up the sand slope towards the shallows. To get any blue to record at ISO 100 I had to drop my aperture to about f11 and my shutter speed to 1/15. But I like the "blue" shots much better as a background for the yellow shrimp and yellow black coral even though there is noticably less depth-of-field. Unterwasser, in Germany for whom I was doing the Komodo shoot liked the "blue" shot much better also. On a digital camera simply raising the ISO from 100 to 800 would have allowed me to shoot at 1/60 at f16 - a much more workable combination.
I think there is no doubt that most of the major housing makers will be coming out with a housing for the D3. And if we are very lucky, the highly rumored 24 MegaPixel D3x (or whatever Nikon calls it) will be built on the same camera body and fit into the very same housing. It could be almost like film in one respect - you would decide which camera body (instead of which film) to put into your housing based on the light conditions you expect to be shooting under.
As a small aside, I also picked up one the the new 14-24mm f2.8 Nikkors. Geneally it seems to be a nice lens. And maybe even sharper and less vignetting than Nikon's fixed 14mm. On the down side, I was very disappointed to find Nikon did not put a get filter slot on the back of the lens and because of the curvature of the front element, no filter can go there. So it will be much more difficult to utilize a "color correction" filter on this lens than on their 17-35mm f2.8 which takes a standard 77mm filter on the front. The 17-35 also focuses several inches closer which means it can be used in a 6" diameter dome whereas the 14-24 just about requires an 8" or larger dome. Overall, with its 2:1 zoom ratio, closer focusing, and regular filter capability I feel that I will use the 17-35 more often than I would the 14-24. And may end up selling the 14-24 unless it is definitely sharper than my fixed 14mm which I like to use for over/under shots.
The 14-24 is also so large in diameter that it won't fit in any of Seacam's current dome ports. Misses by about 1 mm or less. So I am having to have a machine shop make me a special adapter which will allow me to mount an older, thread mount, 8" Aquatica dome (which I had for my F4 housings) on my Seacam. I should have the lens in the water in another couple weeks for testing vs the 17-35. Aquatica at DEMA told me that they were going to be able to "shave" a hair off of the opening to their new 9" glass dome to make the lens squeeze in. I have also heard that Subal's D3 housing may be using a different port mount than their current housings, which would mean all new ports or using port adapters for Subal users changing over to or addiing a D3. So again, that may be another reason to "skip" the 14-24.
Fred Bavendam
