I was trying to figure out how NOT to lug around a laptop and external hard drives to back up EX1 footage. I thought maybe I could use a micro laptop with a couple of 320 gig Passport drives for redundant backup.
Then I thought, "crap, why doesn't someone make a sxs reader direct to hard drive like some of the CF flash units out there. Low and behold, the company below has a unit that comes close and has been tested with the usb transfer function of several sony hdd camcorders. It has NOT been tested with the EX1. So Im going to do it for us.
One of the extreme ND2700 is on the way as I write this for under 300 usd for 320 gb. Although not as good as having its own sxs reader and having to use the camera to transfer (if it works), it could be a compact redundant backup for 600usd (two units).
Of course I will try it with the external sony sxs reader as well. Also going to see if hard drive is field replaceable.
http://www.nextodi.com/en/product/eXtreme_en.html - product
http://www.nextodi.com/en/support/view.php...otice&id=13 - camera test
Any thoughts from the bleeding edge?
-Mark
