Temp of color using two strobe's z-240 in a Nikon D80
Started by RBernardo ·
  • 36Posts
  • 36Replies
  1. Hello
    i am using a external converter for TTL (HeinrichsWeikamp), i have a Nikon D80 camera and i am using two strobe's Inon Z-240, and when i start to use the second one, my photos have a "strange"color.
    i'd like to know, in the white balance, what temperature should i put?
    thank you
    Rui Bernardo
    http://rbernardo.blogspot.com/
  2. 5500-5600K is a good starting point for Inons. Alex
  3. Hi Bernardo,
    What type of strange colour do you get?
    I have the same setup. I can however not say that I get strange colours when I add the 2nd Strobe.
    I just let the Camera do the "Auto" WB and then I correct it in Capture NX if needed. That works fine for me.
    A rather elegant solution would be to have Grey fins, that can be photographed everynow and be used as a Greyscale.
    /Erik
  4. 5500-5600K is a good starting point for Inons. Alex
    Hello Alex,
    that was my start, and when i was using one strob that works just fine, but know i have more dificulties to understand the color in the photo
    this photo is with one flash
    http://3.bp.blogspot.com/_1tzRjEszJ0M/SLBJ...-h/DSC_5385.jpg
    and that one is with two
    http://2.bp.blogspot.com/_1tzRjEszJ0M/SL7c...-h/DSC_5632.jpg
    can you see the diference in the yellow?
    thank you
    Rui Bernardo
  5. Hi Bernardo,
    /Erik
    Hello Erik
    see this picture take with one flash
    http://4.bp.blogspot.com/_1tzRjEszJ0M/SJ3u...-h/DSC_5076.jpg
    and that one, shoot with two
    http://4.bp.blogspot.com/_1tzRjEszJ0M/SML8...-h/DSC_5739.jpg
    can you see that the green is note so vivid?
    thank you
    Rui Bernardo
  6. The second images do seem to have some issues. Not sure that it is all down to white balance, though.
    How does the camera perform shooting them same subjects (single and dual strobe) on land?
  7. The second images do seem to have some issues. Not sure that it is all down to white balance, though.
    i never tried on land to shoot with one, only
    i tried with two and the results are not conclusive, i tried in some flowers in my garden, but the light conditions are diferent
    i shoot always in manual, iso=100, wb= 5600ºK.
    i dont realy understand what is happening...
    Rui Bernardo
  8. I am also not really sure what the issue is. In the 4th Pic, 5739, the right hand flash is perhaps a bit stronger than the left hand. The distance seems short enough for TTL to work in all 4 cases.
    I would take land pictures of the same topic with 1 resp. 2 Strobes and compare them, just as Alex suggests.
    /Erik
  9. thank you all
    i will try it and then i will came back
    once again, thank you
    Rui Bernardo
  10. Hello again
    o forget to tell that one oh the strobes is type II and the other one is type III, but i do not think that can cause the diference.
    if i shoot to close of the subject, wiht two strobe's, the TTL do not work (+/- 5cm) in land. Underwater it work's perfect (but the color is not god as i told before)
    the arms have 30 cm long
    i shoot wiht a lense nikon 18-55mm and a 105mm and use a barbolight 04 as a focus light
    Rui Bernardo
  11. I can not really imagine that type II or III makes a big difference, for this issue. Mine are both of Type II.
    Hmm, I was just having a look at the Pic 5632. It might be a stupid idea, but are you sure that the Strobes fired?
    /Erik
  12. I can not really imagine that type II or III makes a big difference, for this issue. Mine are both of Type II.
    /Erik
    Not such a stupid idea Erik.
    When I first looked at the second photo in each sequence I thought the same thing.
    None of the colors are showing strobe influence at all. . . . IMHO
    Bruce...
  13. Seems to me that by adding the second strobe you are losing contrast. To me, on my monitor, uncalibrated iMac, the colors look fine. But, by adding the second strobe you lose the depth and shadowing. If perhaps you could turn one of the strobes down by a couple of stops.
    I use the S&S TTL III with dual YS-110's and have the same problems as you. It is a problem I'm trying to overcome as well, and it happens when I pull back from my macro shots on the same subject and on CFWA shots if I'm too far away to make the TTL effective.
  14. I can not really imagine that type II or III makes a big difference, for this issue. Mine are both of Type II.
    /Erik
    Hello Erik
    it's not a stupid idea, but i use both in TTL so i think both fired, could be bad oriented??
    this photo was shot F/10, and 1/100. it was a night dive, maybe i shoud use F/>10?
    Rui Bernardo
  15. Not such a stupid idea Erik.
    Bruce...
    Hello Bruce
    is it possible config camera settings to change that? or could be because bad orientation of the strob's?
    Rui Bernardo
  16. Seems to me that by adding the second strobe you are losing contrast. To me, on my monitor, uncalibrated iMac, the colors look fine. But, by adding the second strobe you lose the depth and shadowing. If perhaps you could turn one of the strobes down by a couple of stops.
    Hello IMSushi
    i do not know if it possible turn one of the strobes down a cuople of stops, because, as i said, both are connected to the external converter.
    your connection is electrical or optical?
    Rui Bernardo
  17. Hello Alex,
    thank you
    Rui Bernardo
    Looks like the second image is not lit? Perhaps your strobes don't synchronize to the camera properly? Do you have the 'adv. curcuit'-button on the Z-240:s pushed in?
    /christian
  18. Looks like the second image is not lit? Perhaps your strobes don't synchronize to the camera properly? Do you have the 'adv. curcuit'-button on the Z-240:s pushed in?
    /christian
    Hello Christian,
    yes i do, because if i does not have it pushed, the z-240 does not work wiht the Nikon D80.
    as soon as i get home, i am going to try to shot wiht one and then wiht two strobes, as Alex said...
    and then i will show the pics...
    i have try every thing i know, because i do not understand what can happened...
    that's why i put the question is this forum...
    Rui Bernardo
  19. Hi again Bernardo,
    Bruce: Thanks
    You can actually limit the max allowed Strobe dump, by having the advanced cancel circuit pushed in and switching from STTL to M -0,5 to -6. It is supposed to be for Film Cameras with TTL, but it seems to work.
    Back to the Pic 5632. If it was a night dive F10, 1/100s and assumed ISO100. Then Contrast seems too low for a strobe hitting it. What was actually your ISO Setting?
    /Erik
  20. Hi again Bernardo,
    Bruce: Thanks
    /Erik
    hi Erik
    i always set the iso to iso 100.
    Rui Bernardo
