Molykote 1292
Started by diver dave1 ·
  • 27Posts
  • 27Replies
Molykote 1292
  1. GHP,
    Sorry for the interval of time to answer your question.
    Please contact Stephen Phillips he is the distributor for the UK.
    tribolubeuk@aol.com
    Regards,
    David Lodwick
    Hi Randy.
    Where can I get this in the UK? (Without having to buy 1Kg of the stuff!?)
  2. Antacid,
    We have a Tribolube distributor for you as well. Please contact Andy Fritz.
    info@rebreatherlab.com
    Regards,
    David
    what about in Singapore? :lol:
    i agree i've got too many o-rings and greases to worry about. the lady at the local ikelite distributor said "coloured" (as in non-black) o-rings should use the grease supplied. for me that refers to inon strobe o-rings, and sea&sea housing o-rings..while black o-rings on the ikelite system can use any of the silicone grease that comes with cameras, strobes, or whatever.
    is this true? i've been using the inon & sea&sea supplied grease for almost everything, and so far so good.
    of course, i would like to have a single grease that i know for sure that is safe, and works well with all the rubber we lug around.
    thanks!
  3. what about in Singapore? :P
    thanks!
    Out of ignorance I bought a tube of sea & sea O-ring grease to use on my Ikelite Housing o-ring (black).
    My buddy informed me that some o-ring greases are not to be used with certain types of O-rings.
    I'm confused.
    The ikelite web site says "any quality silicon grease is OK"
    It all depends who you talk to.
  4. All this o-ring stuff has become very confusing for no apparent reason, other than to possibly sell these little tubes of "special grease". Buna (black) o-rings require a good quality silicone grease. A big tube will last for years. Silicone (red) o-rings require NO grease - use spit as lubricant. There is no engineering based reason to use the pretty colored o-rings on anything we use underwater. Buna works just fine. I use S&S strobes & sync cords. First thing I do is replace their blue o-rings with buna. One basic grease for everything. This is not rocket science.
    Edited by jcclink
  5. Out of ignorance I bought a tube of sea & sea O-ring grease to use on my Ikelite Housing o-ring (black).
    I'm confused.
    It actually all depends on what the o-ring is made from.
    "Ordinary" silicone grease is fine with Ikelite o-rings. It's the fancy rings (usually coloured) that swell if the wrong grease is used. The "fancy" (and expensive) silicones will work with buna o-rings, but why pay for the expensive lubricant?
    Despite paranoia (see above) I have used Molykote 1292 on all of my o-rings, buna and silicone, for 6 years now with no problems, despite the addition of polyurea to control its viscosity.
    I'm not sure about spit, as a protein residue may build up on the o-ring or in the groove if not regularly cleaned...
    Replacing silicone with buna isn't feasible for some of the o-rings in current use, particularly on compact camera housings.
    Tim
    :rolleyes:
    Edited by tdpriest
  6. It actually all depends on what the o-ring is made from.
    Tim
    :rolleyes:
    If I had a big tub of 1292, I would probably use it too, but I think the question was about what to buy. In that case, finding a grease that is all purpose and not full of gunk would be where i started. Given that these things are incredibly cheap per use (not per kg) I would opt away from some of the more organic type fillers.
    Bill
  7. JIS metric o-rings are available. The hard part is determining the proper size. The small control o-rings are buna, so no problem. We seldom mess with these anyway. So I'm basically talking about the main housing & port o-rings here, in particular the pretty colored ones ( blue, yellow, etc). Red silicone is ok if you just don't grease it. Water or split is free & easy to come by. Any time the main o-ring is removed (try to minimize this), also clean its groove & all will be fine. Just trying to make life a little easier. In the olden days there were no "special" o-ring compounds, & no leaks (at least not due to compound).
    Edited by jcclink
