Available light shots
Started by Alex_Mustard ·
- 165Posts
- 165Replies
I cannae see your images - where are they???
I have been doing some experimenting with available light using the D2H (not too great at high ISO) and a fast lens, a Sigma 20/1.8 set at maximum aperture.
Previously I experimented at this location and time of year (November) with UR filters but they overshoot the WB. It is very blue not only because of the water but because the light is indirect. The valley floor and stream do not get direct sunlight once the water is clear enough to shoot in (air needs to be freezing; very turbid in summer with glacial sediments). I did WB in post using LR3 (beta 1). I de-saturated the top part a bit using the grad tool. The white spots are air bubbles as the location is downstream of a short falls. Fish size ranged from about 30 to 80 cm in length. Species are Dolly Varden and coho salmon. The bottom on the far side is 4 to 5 meters away.
Exposure was at ISO400, f/1.8, 1/250.
Here is another example using the Sigma 20/1.8 at maximum aperture, also with the D2H. I used motor drive mode set at 4 FPS (the camera can do 8 but then one has a lot of pix to sort through!). This tributary is relatively clear in summer but does have some tannins. Direct sunlight through clouds. Aperture priority, 400 ISO, 1/500 s.
I used a Seacam wideport with 30mm port extension tube for this shot as well as the one in the previous posting.
That is a killer shot, the wide angle and aperture gives it a unique look for underwater.
