HugyCheck in Ike housing??
Started by kornse ·
  • 30Posts
  • 30Replies
  1. Do any of you know if you can by a HugyCheck(http://www.hugyfot.com/Products/HugyCheck.html) kit separate and install it in an ike housing and would it be worth the effort??
    kind regards
    Mads
    Edited by kornse
  2. Do any of you know if you can by a HugyCheck(http://www.hugyfot.com/Products/HugyCheck.html) kit separate and install it in an ike housing and would it be worth the effort??
    kind regards
    Mads
    I was talking to Tom Leys today and I think that since it is the unique selling proposition for Hugyfot they are unlikely to sell the system without the housing. Maybe someone else will come up with something similar.
  3. I was talking to Tom Leys today and I think that since it is the unique selling proposition for Hugyfot they are unlikely to sell the system without the housing. Maybe someone else will come up with something similar.
    That's a shame because the system is Awesome.
    Having tried to find a way to stop my domeport from rotating in the hands of the boat crew prior to passing it over the side, the pressure differential tightens all the O ring seals reducing the risk.
    My Subal ND30 has a third synch port opening (blanked off) so a retro fitted Hugycheck is a possibility.
    John can I have the one out of yours before you send it back? :)
    Nige Wade
  4. You probably have seen this recent post, that there are other ways to stop it rotating :
    http://wetpixel.com/forums/index.php?showtopic=24605
    Nice one Cpix, lots of info there, I must have missed this thread.
    Thanks for posting the link.
    But I'm still going to try and "blag" the one out of the Ageing Scribe's Hugyfot !!!! :)
    John, it'll take months before they realise and you'll be thousands of miles away sipping gin and tonic with Stuart Cove when they do.
    Go on, I'd do it for you :)
    Nige
  5. ... Having tried to find a way to stop my domeport from rotating in the hands of the boat crew prior to passing it over the side, the pressure differential tightens all the O ring seals reducing the risk.....
    Probably not a problem but be aware that introducing a partial vacuum into the housing will effectively reduce its rated depth.
  6. Thanks for the replies.
    I got in touch with a danish dealer and apparently theres some electronics incorporated in the housing(although it should be pretty easy to make one that fits all) . That was his explanation for why we cant buy it...
    Think i might make something similar to the acrylic anti-port-rotating-divice.
    Edited by kornse
  7. Thanks for the replies.
    Hey Mads
    I also have thought about the vacuum in the ikelite housing and want to do that. Can we work together and come up with something? Any chance you can borrow one?
    I am working on something better than the rev4 acrylic anti-port-rotating-device made out of stainless but if you want one acrylic anti-port-rotating-device and would do a nice write up on it I could ship you one.
    Take a look at the new updated website and also look at the Ikelite site (http://ikelite.com/faq/faq_4portlock.html) as They are also doing something with this situation although I like my solution better (http://uwcamerastuff.com/port_lock_4.htm).
  8. I believe that you can buy the Gates Seal Check as a separate set of components that could be easily adapted to almost any housing. It works great for their video housings.
    Bill
  9. But I'm still going to try and "blag" the one out of the Ageing Scribe's Hugyfot !!!! :(
    Go on, I'd do it for you :uwphotog:
    Nige
    Not wishing to burst your bubble (as mine was bursted) a helpful friend in Denmark got involved and organised a 'terrific price' for the Hugyfot. Terrific it might be but it was a lot more than nothing - but as I'd bought the camera and 16mm lens it seemed that I had to buy a housing so the Hugyfot with the security of the Hugycheck was the obvious choice. Alas, I had to pay something for it!
  10. :eek: $1250.
    Would have thought something like this might have the makings, added to a bit of silicone tube and a bulkhead fitting. You're only looking for a pressure drop over time.
    http://cgi.ebay.co.uk/MINIVAC-MINI-VAC-VAC...=item3ef8edfed1
    Edited by Balrog
  11. The problem with the manual vac is that it takes 50 to 75 squeezes to pull 15-20" of vacume on a ikelite housing. Takes some time and energy. I would like to find a low cost small size, light weight battery operated vacuum. Does anyone know how many inches of water a breast pump will draw?
  12. The problem with the manual vac is that it takes 50 to 75 squeezes to pull 15-20" of vacume on a ikelite housing. Takes some time and energy. I would like to find a low cost small size, light weight battery operated vacuum. Does anyone know how many inches of water a breast pump will draw?
    Ah, didn't look the manual vac capacity. Never seen a battery vacuum pump.
    Would doubt if a breast pump would be designed to pull 15"Hg, I can't suck much more than 5". How about those manual pumps that are used to evacuate half empty wine bottles, they might have a larger capacity per stroke.
    Then again there's venturi ejectors but in my experience use a lot of air. Be OK for the 2nd dive using the old tank and a modified first stage but that's not really when you need it :uwphotog:
    http://cgi.ebay.co.uk/VacuVin-Vacuum-Wine-...=item562d693a2f
    http://cgi.ebay.co.uk/SEMIGAS-VENT-VAC-VAC...=item5ad1b81e4d
    http://cgi.ebay.co.uk/Venturi-Vacuum-Pump-...=item45ed9e25b0
  13. Ah, didn't look the manual vac capacity. Never seen a battery vacuum pump.
    Hi all
    Well here is a update. It takes 160 squeezes of the manual pump to pull 15" of vacuum on my ikelite test housing. It takes 50 pumps of the wine pump to get the same results.
    Still trying to figure out how to keep the vacuum in the housing and still remove the pump remembering that you have to be able to release the vacuum from the same fitting. Any Suggestions?
  14. What's the objective, a leak test, then releasing before venturing under or trying to hold the vacuum to keep the dome seated. A leak test probably doesn't need as much as 15" Hg. Less vacuum might be a sterner test for piston sealing O rings subject to an accurate enough manometer.
    I would be concerned at exposing a body and lens to 1/2 Atm vacuum without manufacturer's confirmation. Are you sure all components and any sealed lens elements can take this.
    What pressure does Huggy use?
  15. Thanks for your questions.
    My goal is to keep the vacuum in the housing throught the dive. This would help keep the dome in place, all o-rings sealed and re the dangerous area of breaking the surface in or out or the rinse tank, jumping in with the rig and having it handed to you from the boat. I dont think there is a concern with the camera or lens although thats something to think about.
    Huggy well Hugyfot wouldn't tell me anything except that they only sell the device to people who have there housings. We don't really have any information from them.
    Gates on the other hand uses 6 in Hg with there stuff. Can anyone supply information from hugyfot?
    Regardless of what the ending vacuum is the test of the two vacuum creating devices is for comparison and reference only.
    Edited by blibecap
  16. Thanks for the link, very informative.
    Would someone please check my conversions and math, all calculations are using air, I have made mistakes before and will do so in the future.
    It looks like they have a slight typo, as there manual states Calibrating at sea level (1.015 hPa). The period should be a comma.
    From what I can find this is a little off even with the typo.
    1 atmosphere = 29.921 in Hg = 760 mm Hg = 1.01325 bar = 1013.25 mb = 101.325 kPa = 1013.25 hPa = 14.696 psi
    1.002 atmosphere = 29.973 in Hg = 761.313 mm Hg = 1.015 bar = 1015 mb = 101.528 kPa = 1015 hPa = 14.721 psi
    I don't know why there using about -50' as a sea level reference point but really doesn't make a lot of difference.
    Hugyfot set points are < 950 hg = a solid red light
    950 hg = 14.721 psi = 712.559 mmHg = 29.973 inHg
    Hugyfot set points are 950 hg to 850 hg = a fast flashing red light
    850 hg = 12.328 psi = 637.552 mmHg = 25.100 inHg
    Hugyfot set points are 850 hg to 750 hg = a slow flashing red light
    750 hg = 10.878 psi = 562.546 mmHg = 22.147 inHg
    Hugyfot set points are < 750 hg = a solid green light
    The problem is they don't say where there set point for the pump cut off is exactly.
    My calculations are
    hugyfot 1015 hg - 950 hg = 65 hg or real 1013 hg - 950 hg = 63 hg difference
    hugyfot 1015 hg - 850 hg = 165 hg or real 1013 hg - 850 hg = 163 hg difference
    hugyfot 1015 hg - 750 hg = 265 hg or real 1013 hg - 750 hg = 263 hg difference
    63 hg = 0.914 psi = 47.254 mmHg = 1.86 inHg
    163 hg = 2.364 psi = 122.260 mmHg = 4.813 inHg
    263 hg = 3.814 psi = 197.266 mmHg = 7.766 inHg
    265 hg = 3.844 psi = 198.766 mmHg = 7.825 inHg
    Not much difference between 1015hg and 1013hg
    So the logical conclusion I could draw from this is that there most likely pulling about 8" of vacuum on the housing as compared to 6" in the Gates.
    I like the idea of the different set points and the indicators in the Hugyfot.
    6" of vacuum = (14.696 psi + 2.947 psi = 17.643 psi ) converts to the same pressure as being about 6.6 feet deep in sea water.
    7" of vacuum = (14.696 psi + 3.438 psi = 18.134 psi ) converts to the same pressure as being about 7.7 feet deep in sea water.
    8" of vacuum = (14.696 psi + 3.929 psi = 18.625 psi ) converts to the same pressure as being about 8.8 feet deep in sea water.
    In regards to how much vacuum can a camera and lens handle, can someone shed some light on this? Of course the chips are sealed, but the lens although somewhat air tight is not really sealed as dust and fungus can infiltrate.
    Using a camera at 15,000 feet altitude subjects the camera to a pressure 16.886 inHg verse sea level of 29.921 inHg or 13.035 inHg of vacuum as compared to sea level. 20,000 feet would be about 3 more inches or 16.213 inHg.
    So 15" of vacuum would be the same at taking the camera to a altitude of 18,026.4 or 16.5 feet deep in sea water.
    Regardless somewhere between 6" and 10" of vacuum should be enough to keep the housing well sealed, keep the camera and lens safe and not remove too much depth from the housing rating.
    Well I hope all of these calculations are correct or close as I really did not enjoy all the calculation and conversions.
    Anyone found a nice small battery operated vacuum pump yet?
    Edited by blibecap
  17. http://users.telenet.be/owfotograaf/beelde...20HugyCheck.pdf
    May by this can help if you translate my article.
    I was involved by designing the Hugycheck. It is not so easy to built the measuring electronics inside by yourself.
    A little vacuum meter is also no solution, bout sides are one the same pressure :uwphotog:
    You need also a check valve, and a vacuum pump.
