Removing scratches from a GLASS dome port
Started by dhphoto ·
  • 26Posts
  • 26Replies
  1. Cerium oxide is recommended for glass polishing!
    Optical Grade High Purity Cerium Oxide Polishing Compound - 4 Oz - Walmart.com.
  2. On 1/15/2022 at 3:16 PM, Davide DB said:
    I will give it a try
    Did you have much luck ?
    No. The scratch was quite deep and in the center of my WWL-1, which I thought was now to be thrown away.
    I gave it to a friend, a very good underwater photographer, who learned at his own expense how to repair domes. He used Cerium oxide spending a lot of time risking to overheating and crack the lens. The result was not guaranteed but the alternative was to throw it away.
    He did a magnificent job and now it is as good as new. WWL-1 has an internal coating.
    That is great! I can only imagine that throwing out things like WWL must be rather painful...its not exactly dime a dozen :P
    Out of the curiosity, would you happen to have pics before/after ?
  5. Actually Nauticam can change the glass only but IIRC it cost 900 euro.
    Before
    After
    IMG-20230124-WA0017.thumb.jpg.b66bf3dacada87231328be67476f0f28.jpgIMG-20230124-WA0018.thumb.jpg.2f2727b26fade4bd2e80de5a0afd2a52.jpg
  6. I'll be damned, this looks like new!
    Your friend has magical hands, that is for sure :D
