Your Daily Lembeh Photo
Started by MikeVeitch ·
  • 68Posts
  • 68Replies
  1. Thanks John, glad you are enjoying, thanks for keeping up with it.
    For today we have one of the less exotic species around here but with a patient specimen it can be photographed it an interesting way.
    Lizard Fish Portrait, look at those teeth :)
    D90 and 105mm lens with 2x TC
    1/250 at f20
    YS 120 strobes
  2. Usually that photo is taken with a horizontal orientation. It looks different vertical and I like the extra negative space.
    Thanks for posting!
  3. Mike I'm loving this thread keep it going pleeeeeeeeaaaaaaase.
    Last time I was in Manado / Lembeh my wife (who's scared witless of snakes) asked my diveguide if there were any snakes around
    "Yeh but you won't see any around here because they make good eating" was his reply :)
    Nige Wade
  4. Nige, ya, most things can be on the menu around here :)
    This cute little blenny has made a home from an old bottle, one of the many interesting ways that the critters of Lembeh utilize rubbish as an asset to them
    Nikon D90 Aquatica housing
    60mm
    1/25 at f11
  5. Thanks John, glad you are enjoying, thanks for keeping up with it.
    1/250 at f20
    YS 120 strobes
    Mike
    How did you get a 1/250 sybc speed? My D90 only syncs at 1/200 max.
    Did you use the FP mode?
    Sean
    Edited by londonsean69
  6. really? i don't know! haha.. i use 250 all the time. if i go to 320 i get a black line at the bottom but on 250 its fine. When you say you can't synch higher, it won't actually go past 200 or you get the black line? What is FP mode?
  7. really? i don't know! haha.. i use 250 all the time. if i go to 320 i get a black line at the bottom but on 250 its fine. When you say you can't synch higher, it won't actually go past 200 or you get the black line? What is FP mode?
    If I have either;
    The onboard flash up
    OR
    A strobe connected
    The maximum shutter speed I can set is 1/200.
    FP mode is all to do with the flash firing and quenching at a speed that is faster than the rated sync speed, or something like that.
    Might have to investigate using it (I never have)
  8. I don't use FP as far as i know.. first i have heard of it.
    I have an Aquatica housing and old YS120 strobes, no TTL system. Whereas your Ike system with new strobes might be the difference as its TTL? Ike strobe seem to work differently, i had to tape my hotshoe when i used DS125 strobes. if you try putting some tape on the hotshoe or a small piece of plastic so that only the middle pin is connected that might fix it. Worth testing out on land to see. When i look at the properties for my photos it says "strobe not fired" does yours say the same or does yours say strobe fired?
  9. I don't use FP as far as i know.. first i have heard of it.
    I'll have to get back to you on that "Strobe not fired". Worth investigating though, thanks
  10. Continuing with the "arty" theme from the nudibranch we have a regular ol clam.. but with just a kiss of light from a wider beamed snoot
    Nikon D90 and Aquatica
    105mm
    1/250 at f22
    YS 120 with snoot
  11. Backlit Rhinopias
    Nikon D90 Aquatica Housing
    60mm Lens
    1/250 at f22
  12. Hello!
    FP mode is a nikon way to light the whole frame when using high speed. It does it firing the strobe several times while the curtains are running so there is always an strobe fire per part of the frame and, as a result, there are no dark bands. AFAIK it can only be done with nikon strobes SB800 etc...
    If you cover all the pins except ground and trigger, the camera "does not know" there is a strobe and lets you shoot above the max sync speed and you start getting the dark band (check the clam shot and you will see on the right border part there is a dark band top to bottom)...
  13. HI David, interesting on the clam shot, i don't see it on any others. Usually the banding you would see would be larger from my experience, very noticeable at 320.
    I also had to cover the pins when i used Ikelite strobes as i mentioned above, have not had to do that with my Sea and Seas.
    Snake Eel blending in with the sponges
    Nikon D90 and Aquatica Housing
    10.5mm with 2xTC
    1/13 at f13
    single YS110 alpha strobe
  14. honestly, i actually took this one today! haha
    What's pathetic is looking at my Lightroom catalogue and discovering that it was my first time underwater with a camera since May 27 :unsure:
    Hairy Frogfish
    10-17mm
    1/15 at f13
  15. What's pathetic is looking at my Lightroom catalogue and discovering that it was my first time underwater with a camera since May 27 :unsure:
    I am reading this sitting in my cube, over 800 miles from the nearest ocean. If you are looking for sympathy for not diving enough, keep searching...
    The cube job pays for the diving vacations well enough but living next to good diving would sure be nice.
    Thanks for all the pics you have been sharing with this thread.
  16. Hi Dave
    Nah, not looking for sympathy, rather calling myself pathetic instead :unsure:
    Glad you are enjoying the thread ;)
  17. Love the snake eel shot. Great perspective!
  18. Nudibranch portrait
    Nikon D70 Aquatica Housing
    105mm lens
    1/200 at f14
    One YS 120 strobe, hand held and half covered
  19. Hey Mike, I love the lighting on the nudi! Keep the great photo's coming!
    Mike
  20. Mike - Thanks for sharing the "daily" photos. And I especially love that they are from the D90 setup.
    Keep them coming.
    Also...can you share how you do the hand on the strobe for the lighting effects? Any particular way you are creating this effect?
    Happy diving - DiverPam
