Hey all
I’m new to underwater videography and looking to buy my first set. I don’t have a budget in mind first I want to know what you advice. I already looked for an CANON Legeria HF G10, whit an Light & Motion Bluefin standard housing, 2 Sola 1200 lights and an Light &Motion Fathom 65 wetmate. Is this too big to start with? I want high quality films (I not planning to do this for living just as an hobby) and a set that can be used for a dozen years.
I’m not new to diving I have, I’m diving for about 4 years now and made almost 800 dives (798). All of my dives have been in the Netherlands in the fresh waters and in the seas, dives on depths of 5m to depths of 50m. I want to use the set for these type of dives
What would you advise?
Thnx!
Just want to put in a balancing opinion on electronic controls verses mechanical.
In the old days, there were problems with electronic controls and sea air moisture. Quality housing manufacturers learned to solder and seal connections and seal the sensitive parts of electronic units. Controls buttons are now either fully sealed or completely externalised with magnetic through-the-housing switches. I've been using electronic housings since 2004 and never had an electronics failure. I do always keep absorbent silica gel inside the housing to keep the moisture to a minimum, but you should do this with every housing to stop glass fogging.
The big advantage of electronic controls are that all the control functions are at your finger tips.
On the other hand, the two mechanical video housings that I have owned were both a pain in the butt. Finding the right control is often not intuitive and sometimes awkward to reach and align. I had one housing that was a real fiddle to switch the camera on and off. Had to jiggle the control at just the right angle. With mechanical housings you usually have to stop shooting, adjust the control and start again (although I'm sure very experienced shooters may have mastered this skill, a newcomer would be challenged not to jiggle the camera while making mechanical adjustments). With electronic handle controls, you can make adjustments mid-shot.
Another good point for electronic housings is that the good ones only have two or three holes through the housing (main, port) both with user-inspectable and user-serviicable o-rings = less places to leak. Mechanical housings can have up to a dozen holes, one for each control. The user can not see nor service these controls, potentially a source of leak if salt or sand build up around a control rod.
L&M are a good company with good ethics and service. They suffered a bit recently from their success - their sales outstripped their service capability, causing delays. I have recently noticed an improvement. Their Bluefin with a Canon HF G10, a Fathom 90 (if wide-angle is required), and a pair of Sola 1200s would make a good package for someone who wanted to quickly get on with capturing good footage.
Having said that, I also highly recommend the BS Kinetics housings and use one with my Canon XF100. But this set up is quite expensive, much larger and more complex.
Regards
Peter
