Which mirrorless system for UW..e-pl3 vs gf2 vs sony nex-5n?
Started by cheetohcat ·
  • 55Posts
  • 55Replies
  1. Open this PDF and look at the port chart and you will see the Inon AMRS parts that fit onto the Acquapazza port to use the lenses in manual. The purple housing at the top has the gears and focus rings mounted for both zoom and manual focus.
    http://www.acquapazza.jp/product/apsonex5_ct.pdf
    If you do not understand how the system works, see my INON X-2 article in the current issue of UWPmag.com The system works the same way on these ports.
    Phil Rudin
  2. Hello Aliens,
    The two housings are different on the underside and the NEX-5/5n grip from Nauticam is a bit small. The Nauticam flexitray for compact housings with one or two grips does work on the NA-NEX-7 housing and has the great Nauticam grips. The Inon holder II grip set also works with the NEX-7 housing.
    Phil Rudin
    http://reefphoto.com/shop/index.php?main_p...roducts_id=5385
    http://reefphoto.com/shop/index.php?main_p...roducts_id=4957
    http://reefphoto.com/shop/index.php?main_p...der+ii+grip+set
    Thanks I have an Inon baseplate and arms from my compact camera trying to change this to use on the Nauticam NEX7. Thanks for your reply
  3. the m43rd lenses just keeps coming in.
    especially 3rd party.
    Besides the newly announced Olympus em5, rumor has it
    they will also released a 60mm macro plus an underwater housing for it.
  4. Oooh, you get colors!
    Phil, Thanks for the link. Certainly do-able. Appears to be AF only.
    Bob
    No, full manual focus is available with the brilliant mangentic ring system.
    Hugh
  5. I had a chance to take the nex-5n out this Sunday for 2 dives on the Oil Rigs near Long Beach, CA. We lucked out and had AWESOME viz, so I could really put the set up through the paces for wide angle. I'm still getting used to it, but I am very happy with it so far!
    These were all taken with the Sony 16MM WA pancake lens + fisheye, and in the Recsea + dome port. I'm hoping to try out the 16mm alone, and the 18-55mm kit lens in the next few weeks as well.
  6. Carolyn
    What modes were you shooting in? I ask because on my screen, a few of the pics are under exposed by at least 1.5 stops. Just wondering if you are using manual or any other mode? Thanks.
    Edited by Drew
  7. Carolyn
    For us Novices, can you pick one picture and explain in more detail why you think its under exposed.
    Hugh
  8. Hey Drew, I was shooting in manual mode for the camera and strobes, so any exposure issues are due to operator input. :lol:
    On a related note, do you have suggestions on how best to calibrate computer screens for accurate post processing? I just recently switched from PC to mac, and I find the images look radically different between the two, or vs. my work computer etc.
    Thanks!
  9. Hey Drew, I was shooting in manual mode for the camera and strobes, so any exposure issues are due to operator input. :lol:
    Thanks!
    carolyn:
    I have a calibrator you can borrow next time we see you on the giant stride. On my monitor, the metridiums for example are at least a full stop underexposed and the cabezon (if that is what he is) is about a full stop under as well. I think you need to think about dialing in some strobe compensation. I like the composition a lot and the sea lion shot is very nice.
    Let me know when you are going to dive with Jim again (I think we are on the boat next on the 25th) and I will bring my screen calibrator or if you are coming to the LAUPS meeting on Wednesday I will bring it then.
    Bill
  10. Carolyn,
    Thanks for sharing. How was the view throught the viewfinder?
    Bob
  11. thanks Bill! that would be awesome! I think Dana said you guys were on the GS on the 26th but I can't join ...I'll plan on the LAUPS meeting next week.
    carolyn:
    Bill
  12. Hey bob, there's no viewfinder, but the LCD was easy enough to see in the housing. Since I'm coming from a compact, I'm used to screen only so I didn't have any problems with it.
    Carolyn,
    Bob
  13. We use our cameras on dry land at nighttime also so you may want to factor high-ISO performance in the decision if it's important to you. Currently, the NEX IQ is clearly superior to other mirrorless systems.
    If you are into video, you may also want to consider NEX-5N and NEX-7 - the only two mirrorless cameras with 1080 60p video. With other mirrorless systems, you have to sacrifice 1080 resolution for 60P smoothness, and vice versa. Keep in mind that James Cameron wants to shoot Avartar 2 and 3 in 60 frames per second and this can be the beginning of the end of the outdated 24fps film standard that filmmakers actually hate. It's a certainty that 1080 60p will become the default video standard for consumer cameras and camcorders in the near future. Why wait?
    Adjusting White Balance on the NEX-5N is simple and the results are pretty encouraging. There's no RAW for video, so adjusting WB at the scene is the only way to obtain the most accurate colors for movies... AND STILLS ALSO.
    I have an in-progress "Personal-Observation" page on the NEX-5N here for those who are interested.
    Edited by A.Y.
  14. Hey cheetoh, you use one or two strobes?
  15. Hey Nitro, I use two strobes. Didn't have them dialed in correctly for the first time out power-wise, but it was definitely necessary to have two to get coverage with the fisheye lens on the camera.
