Ikelite + 300D / took it to the pool / macro
Started by mexwell ·
  • 28Posts
  • 28Replies
  1. Just got my rig today.I was planning to get started in pool, but am I dissapointed after putting it all together and the flash doesnt go off.
    I have to read all the manuals etc. Any tips from you experienced guys
    Lars :)
    Lars, do you have the manual controller as well as the DS-50? If so be sure and check the the little 'dip' switch settings. When mine arrived it was not set correctly to work with the Rebel. After those were set correctly, everything worked perfectly!
    :wink:
    Dave.
  2. Hi Dave
    I actually have the Ds-125, same as you. I will check settings today and report back
    Lars
  3. Ok
    I have isolated the problem. connecting the strobe straight to camerahouse works fine. Its the controller which is the problem. I have tried all different settings but no way. Ike, do you have any suggestion
    lars
  4. is the strobe set to TTL?.........that's required for the manual controller to work
    Karl
  5. is the strobe set to TTL?.........that's required for the manual controller to work
    Karl
    Yes ..and i have tried to run on all different settings as well
    Lars
  6. Ike
    Switch is set to DS 125 ( which is what I finally got, not DS50 )
    The other switch is set to no preflash ( crossed over P )
    Setting on strobe tried both TTL and just ON
    As i wrote earlier strobe works fine without manual controller.
    My bet is that the controller is broken, so I will have to get it exchanged
    ( capebyronimports in Byron Bay, Australia )
    Lars
