Focusing the dome (AKA shooting on your feet)
Started by Davide DB ·
  • 45Posts
  • 45Replies
  1. As already said I'm coming from a classic videocamera system: Sony HC9, Alu housing, 70° glass lens adapter...
    Now I'm paying the penalty for changing setup to a DSRL :P I still was not able to shoot a perfect sequence...
    Yesterday i had the opportunity to dive again after a one month stop for a little surgery on my arm. Mounting the acrylic dome i did not notice some dust on the internal and some limestone stains left from the previous rinse. I was too concentrated on the o-ring neatness!!!
    I used the wrong AF: "23 area focusing" while probably I should have used "1 area focusing". In short terms, every time I half pressed the shutter button using an aperture of 8/11 on my Lumix 8mm the camera focused the little stains or dust on the dome. Playing the video in camera underwater they seemed perfect!
    Dust particles on my dome were enhanced by the fact I was shooting toward the sun in 2/3 meter of fresh water. Never had these problem with my previous setup.
    Looking at the video, later at home, I noticed that on the external part of my dome I had some microscopic air bubbles. Is there any way I could clean the acrylic dome to avoid all these problems?
    Should I use some antistatic product on the inner part?
    Which autofocus do use? And how I can avoid to focus on the dome?
    This is killing me because I got some amazing shots (IMHO) totally ruined.
    I'll post a couple of shots later to show you the problem.
    Edited by M43user
  2. You seem to guess the answer: throughly cleaning the optical path.
    Secondly manual focus is safer, especially if you are able to confirm the distance. The numbers might not be the actual distance, but, you should be able to distinguish whether you are focusing on dust or outside the dome.
    Then a small tip if you are shooting towards the sun: make sure that any and all reflected surfaces are as black as possible. I have painted all metallic surfaces with a matte black.
  3. You seem to guess the answer: throughly cleaning the optical path. Secondly manual focus is safer, especially if you are able to confirm the distance. The numbers might not be the actual distance, but, you should be able to distinguish whether you are focusing on dust or outside the dome. Then a small tip if you are shooting towards the sun: make sure that any and all reflected surfaces are as black as possible. I have painted all metallic surfaces with a matte black.
    Unfortunately on my Nauticam housing (for Lumix GH2) I haven't the manual focus. The nauticam dome side protection are painted black.
    Is there a "safe product" for acrylic dome cleaning except pure water? Some antistatic product?
    Here a short crap showing the problem. On the first clip the sun rays hit the dust through the plants on water surface. On second clip there are a lot of flares. The last clip seems better but is clearly blur as you can see dust on the left. Everything seems in focus just because I was shooting at F13.
    [vimeohd]41657276[/vimeohd]
    Edited by M43user
  4. Where is the dive? The field of green is really cool.
  5. Where is the dive? The field of green is really cool.
    Posta Fibreno Lake near Rome. A natural reserve with an amazing viz.
    I was trying to imitate my dive buddy photos :P
  6. The last part of your clip looks OK. BTW this is a problem for still shooters too. Shooting by remote control with a stationary camera in stream it is possible to have grit land and stay on the dome surface which then gets focused on by the AF - a cause for me to reject many pix :<
  7. The last part of your clip looks OK. BTW this is a problem for still shooters too.
    Actually also on the last part the camera focused on the dome. The sub seems ok just for the extreme DOF at F11. Looking at the original 1080p footage, dust is clearly visible and perfectly in focus :P
    So no solutions except manual focus?
    bye
  8. So no solutions except manual focus?
    bye
    MF is not an option for what I do; even with a FE I find focus to be critical as I am dealing erratic fish movements. My solution is to bin the pix and keep shooting more.
    Edited by Tom_Kline
  9. Are you not able to somehow activate the autofocus to focus on what you want, then inactivate it. In other words use it as 'electronic' manual focus.
    For example with Nikon and most housings I am familiar with, one can do that by moving the focus lever to autofocus when you want to focus, then back to manual once you have fixed focus.
    Edited by loftus
  10. Are you not able to somehow activate the autofocus to focus on what you want, then inactivate it. In other words use it as 'electronic' manual focus. For example with Nikon and most housings I am familiar with, one can do that by moving the focus lever to autofocus when you want to focus, then back to manual once you have fixed focus.
    Do you mean AF Lock? Yes I have it but it's seems strange that I cannot focus correctly with this lens/dome.
    I cleaned everything and I will try again.
  11. Not just focus lock, actually turning autofocus on and off. Even without dirt on the dome with a close focusing FE lens, the lens may hunt and focus on the dome inadvertently and you may be better just using hyper focal distance with AF off
  12. Can you use complete manual focus?
    My suggestion would be to jump in a pool with a lens chart or equiv, work out where the virtual image is for that lens and not what focal lengths you need to be at for a subject at .05m, 1, 2, 4, 5, 10m for example and use that, forget the auto focus.
  13. Unfortunately on my Nauticam housing (for Lumix GH2) I haven't the manual focus.
    I am baffled by this. There must be a manual focus knob. Mustn't there? :P
  14. I can't watch your vid right now but I can guess your issue. It's a common occurrence.
    I suggest you clean the dome with a fine acrylic polish to remove the lime deposits and fine line scratches. Alternatively, soak the front end of the dome in white vinegar, then polish. If the scratches are inside your dome, you'll have to do the same.
    As for bubbles, get into the habit of checking then wiping down your dome once you enter the water. It has to become habit to do so, especially if you swim past bubbles. The fine lines on acrylic have enough surface tension to hold small bubbles. Don't rub too hard or you'll just end up adding more fine scratches. I know a few people who dive with a small cut chammy, but most use their bare hands.
    As for AF modes, turn off Continuous AF for wide angle and use the shutter button to pre-focus before recording. AF works for macro but not for wide angle unless there is a clear subject in gin clear water.
    Nick, the unfortunate side effect of a compact housing is the lack of all the features necessary. Only the Seacam housings have focus and zoom knobs, and it's a bit of a nightmare to fit the gears, especially with lenses getting fatter and the narrow space, many lenses can't use that option. Some maufacturers have shifted focus to the ports/extension rings, but it's a limited number of lenses that can use that.
  15. I have the same set up.
    I have not experienced this problem before.
    I think the problem may have been there was nothing for the camera to focus on at the start of your clip(shooting blue water) and therefore the auto focus started to hunt. There is a menu to switch off continuous autofocus.
    I have had some limited flaring in bright conditions when i shoot towards the surface . However i try limit this type of shot as the dynamic range is not great .
    When i first started using the camera i had continuous auto focus on. I have now switched this function off. I use AS focus and have the small central focus selection. I prefocus on my subject them move to frame and then start shooting.
    I always try to use F8-F10 with the 8mm.
    I have been very happy using the 8mm for video.Its better than the 14mm pancake lens in terms of fast accurate focus.
    There is a detailed topic in the DSLR forum about cleaning dome ports.
    Edited by Kevster
  16. I am baffled by this. There must be a manual focus knob. Mustn't there? :P
    There is a manual focus knob on the housing.
    However i do not think there is a focus gear for the 8mm lens. Therefore you cannot really manual focus. You can select manual focus but there will be no way to adjust focus point without the focus gear on the lens. IMHO there is no need for a focus gear for this lens.
    I have the same set up and i have just bought a focus gear for the 45 mm macro lens so i can use manual focus for small stuff.
  17. Slight sidetrack, but what perceived distance does the virtual image end up at when the actual subject range is say 20cm and infinity?
    It would be a great additional functionality for the camera manufacturers to add a focus limitation that only searches for focus within that range. This is probably possible to achieve with camera hacks like Magic lantern (for some Canon DSLRs)
    //O
  18. I am baffled by this. There must be a manual focus knob. Mustn't there? :P
    Hi Nick, I have the knob on the left but it's for the zoom gear if you have the Lumix 7-14mm or the Oly 9-18mm or acting as manual focus for the Leica macro lens.
    An illustration is better than thousand words :) It's the huge knob up the red lock botton.
    Really I could not imagine a better design for a so small camera and housing. As other Nauticam products it's a mechanical engineering masterpiece.
    The housing it's very small:
    I try to answer to all the others kind people here who replied to my questions... :rose:
    I never used the continuos AF. I know that is absolutely useless. I use the single AF. I just half press the shutter button to pre-focus. In my previous test it worked perfectly. Also at 80m deep without light the focus is instantaneous. At the beginning, reading so many comments on AF problem I could not believe how fast and accurate it was.
    During the dive I was misleaded from the display. Everything seemed perfectly focused. Prior to shoot toward the blue I pre-focused at some object at a couple of meter in front of me and then using F11 or F13 I thought that everything was ok. I also played some clip in camera during the dive. Only at home I realized the mess :(
    Probably If I was shooting photos I would have realized it immediately. You can enlarge automatically the photo just after the shot. But with video you cannot enlarge it in camera (Well, I guess. I'll check it at home :o )
    Later, looking at my dome I realized that the inner part was completely covered by dust. It was my fault and the reason it's another story :)
    I have some little scratch on the external part but its' really something you can see just observing it toward a strong light. I guess that once in water it shouldn't be visible.
    The dive was in a natural resurgence. While entering in the water I had to pass through a thick layer of death green algae. Probably the dome was not well cleaned and it kept some grease and water bubbles. Shooting toward the sun and surface I amplified the problem.
    Despite of this inconvenience I was really impressed for the nearly zero banding on the blue water and green algae. I used a magic filter and it was great! I manual white balanced the shots at different depth. At the beginning I tried to WB against the white tanks of my buddy but the tanks were so shining under the sun that the camera refused to WB saying "image too bright to WB" :huh: So I WB against the gray mud of the lake obtaining a nice blue tone. Except for being out of focus most of the clips did not need color grading at all (IMHO).
    I hope to test it again in that lake asap. In the meantime on Thursday I will go in a pool to experiment.
    I do not pretend to obtain the same results as my buddy with the large Underwave/Igloo glass dome :)
    I read many threads on acrylic dome cleaning but there are a lot of different opinions. Could you suggest me a good method for a normal cleaning of my Nauticam dome?
    If I would try to remove that few nearly invisible scratches which product I could safely use. They aren't deep scratches. I think that the same neoprene nauticam cover cause some little marks on the dome.
    Thank you all.
    Edited by M43user
  19. While we're on the subject of manual focus options with the GH2. Is it possible to manually focus with the 7-14mm and others? When i looked at the port finder here http://www.backscatter.com/sku/na-17702.lasso at backscatter it says Auto focus only for all of the ports? Are there focus gears for these ports?
  20. While we're on the subject of manual focus options with the GH2. Is it possible to manually focus with the 7-14mm and others? When i looked at the port finder here http://www.backscatter.com/sku/na-17702.lasso at backscatter it says Auto focus only for all of the ports? Are there focus gears for these ports?
    I think the focus gear is available only for the Leica 45mm macro.
    This table is more clear:
    http://www.nauticam.com.au/products/housin...ctor/index.html
    Bye
