Focusing the dome (AKA shooting on your feet)
Started by Davide DB ·
  • 45Posts
  • 45Replies
  1. Yesterday I made up a simple and cheap ($10) protective hard cover for the Nauticam dome port (8mm).
    Interesting solution. How do you secure it? Where do you intend to keep the cover during the dive?
  2. Interesting solution. How do you secure it? Where do you intend to keep the cover during the dive?
    I've always used a hard cover for my domes. The cover for my Subal SWB is actually a 150mm sewerage PVC pipe end cap...worked faithfully for 12 years (although I've lost a couple).
    I mostly dive from a boat and I take it off on the surface once someone has handed the housing to me (I've learned the hard way never to go over the side of a boat with my camera). I ask the person on the boat to put it in my camera box/bag. After the dive I ask for the cover before handing the camera over.
    Because this port is somewhat smaller I might just put it in a BCD pocket...particularly if there's no one on the boat to help.
    Edited by HDVdiver
  3. I've always used a hard cover for my domes. The cover for my Subal SWB is actually a 150mm sewerage PVC pipe end cap...worked faithfully for 12 years (although I've lost a couple). I mostly dive from a boat and I take it off on the surface once someone has handed the housing to me (I've learned the hard way never to go over the side of a boat with my camera). I ask the person on the boat to put it in my camera box/bag. After the dive I ask for the cover before handing the camera over. Because this port is somewhat smaller I might just put it in a BCD pocket...particularly if there's no one on the boat to help.
    Same method here following the same advice of HDVDiver and this thread:
    http://wetpixel.com/forums/index.php?showt...mp;#entry308675
    I miss a couple of stickers and I'm a pro :D
  4. Here's a couple more solutions for protecting a dome...one simple (PVC end-cap) the other more sophisticated/expensive (machined Delrin) ...but only for ports with thick walls that can have clamps attached.
    Edited by HDVdiver
  5. Oh...and the "virtual image" is actually a multiple of virtual images each one corresponding to the lens-to-subject distance. Furthermore, this varies depending on the diameter of the dome and the focal length of the lens used.
    Of course, just as the subject distance is a range, the perceived distance to the virtual image is a range that is a function of subject distance. However the theory would be to limit "focus space" to suit the range of the virtual image. I suspect focus limited lenses today doesn't work with this range (and surface applications are more aimed towards tele i suppose). This is just a theory though, high contrast artifacts on the dome may still cause problem for AF and image.
