Testing the RX100
Started by Alex_Tattersall ·
  • 32Posts
  • 32Replies
Testing the RX100
  1. Nice photos EunJae....sweet, is that +10 Subsee you are using ?
    thanks
  2. Nice photos EunJae....sweet, is that +10 Subsee you are using ?
    thanks
    Yes, Subsee +5, +10 and FIT +16. Some of shot was stacked diopters.
  3. I see, thank you.
    Sony RX100, 28mm, f/8, 1/320sec, iso 125, single s2000, Illustration Picture Effect (in-camera effect).
    p.s
    To Dear OP (Alex Tattersall),
    I'm very sorry if I hijacked(I hope not) your post.
    EJ.
    Edited by escape
  5. Nice shots Eunjae, and thanks for sharing your info on this camera Eunjae and Alex.
    I have ordered a RX100 a few days ago, will be housing it in a Nauticam housing.
    Looking forward to seeing the difference in quality and resolution with my old S95.
  6. Beautiful shots... especially the second one ( I presume a giant clam) ! have been considering this camera also. Backscatter said that there was no TTL but someone here said TTL was available with the YS-D1. Has anyone else experienced TTL on this camera and if so with what combo of housing and strobe?
    Do the Subsee +5, +10 and FIT +16 diopters then fit right on the nauticam housing or other housing?
  7. I am going to correct myself as I reread the email from Backscatter.... They said that you get TTL with the YS D1 because it is an optical slave... So any problems with the TTL and the Sony Rx100?
  8. I tested with Inon s2000 and TTL via optical trigger (It's only an option to use external strobe) works well.
    Don't forget to set "Red Eye Reduction" Off in camera menu.
  9. I was thinking about getting the rx100. I already have a oly xz-1 with the oly housing.
    Has anyone tested the olympus wide angle lens on the nauticam rx100 housing. Is the performance as good as with other wide angle lenses?
  10. Photo from this weekend, a tiny bit of vignetting all the way zoomed out with the FIX UWL-04
    You can see the dome shade on the bottom of the photo.
    Rottnest Island by Xander Rood, on Flickr
  11. Good work - haven't seen the Bathurst lighthouse from that view before.
  12. Glad to hear it works well with the Inon s2000. I'm looking to sell off my xz-1 and was trying to decide what to get.... since I'm a supermacro fanatic, this might be the way to go.
