New Housing "Airlock" Vacuum from Backscatter
Started by Steve Williams ·
  • 196Posts
  • 196Replies
  1. I ordered the Vivid. Why?, I like the idea of being able to monitor the status without having to reattach the pump. I like the idea of seeing the green blinking light right before I enter the water. I had two issues with the underwatercamera stuffs system, the cost of the electronic version and having to fit the electronics into the housing.
    Ken
  2. Why would anyone wants to introduce flashing and blinking lights or monitor the partial vacuum inside. Just use it and forget it. That is best in my books. The valve does not even need to be fussed over. Just normal rise with the housing and it will work over and over again.
    I think the leds (or a gauge) are essential! How else do you know there is no leak? If you don't have any means to check the vacuum before entering the water, you also don't know if there is a leak.
    This probably saved my camera a while ago. I had vacuumed the system at home, and when I arrived at the dive spot, the Hugycheck showed a flashing red light. Upon closer inspection, the housing had completely de-pressurized again, which means a significant leak. Without that blinking red light, I would have entered the water without knowing anything and flooding the camera!
  3. The hand vacuum pump has a pressure gauge. Its similar to Backscatter and Sentrythingy....
    yes you check if the gauge and see if vacuum dips or not. Used this method since 1993.
    Zero flood.
    regards
    David
  4. I find it very comforting and I am sure others would agree to be able to look at the flashing green led once I am in the water, and several times during the dive. My counts are floods = zero, leaks = less than 6, water damaged equipment = zero. On the other hand the flashing red led is not so comforting but it is better than damaged equipment.
    If you elect to purchase a system without electronics PLEASE make sure that you have a FUNCTIONAL moisture / leak / water detector in your housing. Some of the lower end housings do not have this installed as standard equipment.
  5. Kenr;
    PM sent.
  6. Vivid Housings has tiny electronic indicators available for less than 75 Euro, with a switch and red and green LEDS to indicate whether the vacuum has been lost. I think most housings would have space for these where they can be seen from the outside. They also make the Leak Sentinel which is the complete unit, valve, vacuum sensor etc.
  7. Can you please provide a link to that item and price?
  8. I am also thinking that vaccuum checks are a must for underwater photographers (I have one in my Hugyfot D7000 housing and it brought peace of mind that I didn't have before while diving.
    Someone suggested that it would be useful on strobes too. Indeed, I wouldn't mind having one on each of mine Inon Z240 type IV, these are expensive toys too. Xan anyone comment on the feasibility to do it on strobes?
    By the way, would a vaccuum check system also secure the Nikonos 5-pin connector on housing side?
    The question may be stupid, I have no idea if how the barrier between water and inside housing is made on nikonos connectors.
    Nicool
    I was hoping that someone else would answer this question for you. Normally the strobe connectors are water / air tight. You would need to drill a small hole in the inside where the pin's are to allow for vacuum to enter the housing. We designed a connector that would fit in the nikonos socket two years ago and have not sold one yet.
  9. www.vividhousings.com
    I have two in shipment.
    Cost with custom adapter was 200Euro or about US$260 each including shipping
    I will post a report in early May upon return from Indonesia.
  10.
    Nicool
    Thanks for the answer Bill, very very interesting :-)
    So you would deliberately create a path for air to flow in the nikonos sync plug, to ultimately mate itsafer because tighter.
    I moved to optical fibers after my electronic cable unscrewed itself in the rinse tank, causing me the lost of my cable and of the bulkhead, but I must admit that I like better electronic sync (I do ttl, so optical fibers take a lot on the camera battery).
    I sent you an emai with some questions on friday about using your sentry on my future Nauticam OM-D housing. On that one there's a single bulkhead (aimed at Electrical strobe connection), so I assume that I would need a separate hole to be drilled for thensentry if I want to use your nikonos plug accessory?
    By the way did you or anybody develop a vaccuum check system for pricey strobes (I am thinking of my 2 Inon Z240 type 4)?
    cheers
    Nicolas
  11. Nicolas
    I don't know of anyone who has a vacuum system for strobes but it could be done if there is room for the vacuum connector. I will reply to you email about the OM-D housing latter today. Yes you are correct about needing the extra hole drilled. That is a solution but it may not be the best one.
    Have a great day.
    Bill
  12. I am just back from a week in Key Largo using the Leak Sentinel from vividhousings.com, and it definitely made me comfortable dunking my D90 and macro into my camera bucket on the boat each morning. Having the blinking green light going during that first kerplunk and during the dive is very reassuring and gives positive confirmation that the vacuum is holding.
    Miso, who runs Vivid Housings, was able to make an adapter for my Aquatica AD90 housing and have it shipped out to me from Europe in less than a week. It fit perfectly, once I figured out that the lockwasher goes on the _inside_ of the housing. Duh!
    I would assemble my equipment in the hotel the morning before the dives, and pump it down, going 3-4 extra pump strokes after the LED went from blinking red-green to blinking green. I would leave it pumped down the whole day until I was back at the hotel to remove the memory card and battery. I never got any water into the vent area: I used a towel to dry that area off thoroughly before removing the cap. If I was opening the enclosure on the boat, I would definitely want to have a towel or some compressed air to blow off the water around the cap. Now where would I get compressed air on a dive boat? :)
    For $260 all in, it's an amazingly good deal: provides the vacuum lock of the seals, provides continuous visual indication of vacuum, and the battery (single 1632 coin battery) seems to last forever.
    I agree with other commenters: there's just so much that you can get wrong putting a complex system together and that having some way to verify the integrity of the seal other than destructive testing only makes sense. Whatever system you get is infinitely better than not having a system. We are talking a fairly small fraction of the cost of your entire camera/housing system to keep it dry on the inside. Look at all those posts about folks getting their D7000 housings flooded because of the stupid microphone cable!
  13. I am just back from a week in Key Largo using the Leak Sentinel from vividhousings.com, and it definitely made me comfortable dunking my D90 and macro into my camera bucket on the boat each morning. Having the blinking green light going during that first kerplunk and during the dive is very reassuring and gives positive confirmation that the vacuum is holding.
    Good post.
    Some day ALL housing will have such a system.
  14. To me a vacuum system is more or less needed to really enjoy my underwater photography. Due to plain stupidity on my behalf I have earlier had one total flood and one partial. It came to the level where I worried just to much over doing another screw up, and taking my camera under water became quite stressful, which is the absolute opposite of what I want it to be. A vacuum system takes most, if not all of the worries away, as one simply knows that nothing is Leaking. I agree with the above that any such system is much better than not having a system. I also agree with John, these systems will without doubt be an integral part of future housings.
  15. Whilst I agree with much of the above, I do think that there seems to be a tendency to think of vacuum devices as a "silver bullet" that will prevent leaks. Good practices when using housings will still prevent leaks. All the vacuum units should provide is an additional level of verification that theses practices have been correctly carried out.
    To illustrate this, I know of at least one instances where the vacuum bulkhead itself has caused a leak! I have had a catastrophic housing flood, however this was caused by the lack of a port lock on that particular housing, rather than any failure of the seals on the housing. The vacuum system would not have prevented it :(
    I have also had an experience where having the vacuum system has prevented me getting in the water when I would of safely done so without it (due to temperature change).
    I agree that they are a useful piece of equipment and expect that I will probably have one fitted to my next housing, but am a little concerned that they are being seen as a replacement for good practices and common sense ;)
    Adam
  16. I have had a catastrophic housing flood, however this was caused by the lack of a port lock on that particular housing, rather than any failure of the seals on the housing. The vacuum system would not have prevented it :(
    Adam
    Adam. you are displaying a classic lack of knowledge about this system. With the vacuum pulled, that IS a port lock. You cannot open the housing or remove the port without releasing the vacuum.
    I've just been commissioned to write a piece for an American publication about vacuum leak test devices and I thought of you when I wrote: "I foresee this important device becoming more popular as people wake up and smell the coffee and more of these expensive cameras not so protected become toast. Others may protest and need to be dragged kicking and screaming away from that cautious test in the freshwater rinse tank."
    Edited by John Bantin
  17. Whilst I agree with much of the above, I do think that there seems to be a tendency to think of vacuum devices as a "silver bullet" that will prevent leaks. Good practices when using housings will still prevent leaks. All the vacuum units should provide is an additional level of verification that theses practices have been correctly carried out.
    Adam
    I totally agree with your first paragraph. In your second paragraph, didn't the vacuum system detect the leaky vacuum bulkhead? As far as the port lock is concerned with 10" of vacuum it would take in excess of 50 LBS / 362 kg of force to remove the dome port from my ikelite housing so I think that this would have saved your flood. I have not had the temperature problem you indicated. I have see vacuum systems save more than one camera. I think that they will become more standard in the future and many housing may integrate them at an added cost or option. But currently, it is a aftermarket custom add on accessory for a lot of housings. What I am wondering is at what cost will people with point and shoot cameras start using these systems as the P&S cameras are getting better and slightly more expensive?
  18. It may be a surprise but I am aware that a vacuum in a housing will help make a port lock! I don't think I suffer from a "classic lack of knowledge" and have been fortunate enough to have used most brands and types of housing (including some equipped with vacuum systems) more extensively than most.
    Even with a vacuum in a housing, enough force will still move the port. I'll let other brighter persons do the physics, but 50 lbs quoted is actually about 22.5 kg. That is not a whole lot of force. Call me a Luddite, but I am much happier with a piece of metal that prevents the port from coming off. Of course, if a housing has both, I am also happy:)
    The vacuum system did not detect the faulty bulkhead as the bulkhead failed catastrophically whilst underwater.
    I think I should be clear that I do not rely on a "cautious test in the freshwater rinse tank" to ensure my housing's integrity, nor would I recommend anyone else to. Like many other active underwater photographers, I currently rely on a extensive maintenance and inspection regime before and after each and every time I open the housing. John, I would hope that, in the interests of balance, you will point out in your forthcoming article that, despite there being a lot of people diving with housings, the incidence of floods is actually fairly rare. This is because most underwater photographers are aware of the issues, and have strategies for dealing with them.
    I think the point of my post was to point out that vacuum systems are a good addition, but should not be seen as a replacement for the current checks and procedures that most underwater photographers follow to prevent leaks. Sorry if I offended any evangelic sensibilities :)
  19. Adam
    I may have incorrectly stated or incorrectly converted the 50 lbs as I am not that used to working with metric weights and forces. It took over 50 pounds of pull to dislodge the port. That is a 50 lb weight attached to the dome with the dome pointing strait down.
    Sounds like you must have had one of those plastic bulkheads that are glued together? care to elaborate on it a bit?
  20. I know of someone who did forget to pull a vacuum and went in the water without the plug. This is essentially like diving with a hole in the bulkhead of your housing. Fortunately, he had a dome port on and caught it as the water started rushing in so he was able to turn the camera so the water began collecting in the dome as he was aborting the dive.
    To Adam's point, having a vacuum system isn't completely fool proof. You still need to check your system before jumping in.
