Fisheye lens options for RX100/Nauticam?
Started by onewolf ·
  • 46Posts
  • 46Replies
  1. Thanks Interceptor,
    It's hard to find a wide for the xz1 that can be used on the more current cameras (type 1 vs type 2 etc). Since im eye-ing the rx100 II, I can save some cash by using my uwl-100.
  2. UWL-100 M67
    Thanks Interceptor,
    Do you have the M67 or 28AD version?
  3. UWL-100 M67
    28AD
  4. What's the lens rear glass diameter in mm?
  5. I'd really like to know where you purchased the bayonet mountings for the RX100 wet lenses. I have looked all over and can't find them. I have the Aquatica +5 Close up lens and the INON UWL-H100 28M67 Type2 Wide Conversion Lens. Also can you get lens holders that attach to the strobe arms for the bayonet mounted lenses? I'd appreciate the help. It is a pain to attach and detach without bayonet attachments.
  6. You have to buy the LD lens option or the AD lens.
    The UWL-H100 28M67 can be converted into bayonet using a service part. Then you need an LD bayonet adapter for the housing. Nauticam and Fix sell it.
    Fix is hard to find but you can try asking reefphoto
    This is the nauticam
    http://reefphoto.com/shop/index.php?main_page=product_info&cPath=117_87&products_id=5611
    You can then convert your close up lens using this part
    http://reefphoto.com/shop/index.php?main_page=product_info&cPath=117_87&products_id=5086
