Fresh off the UPS truck
Started by yahsemtough ·
  • 24Posts
  • 24Replies
  1. Hi Todd
    Looking at the coloUr of your housing I rekon that it will become invisible at about 35m! It even has "backscatter"?
    Yes, and to make the camera even less conspicuous to the subject, Todd diverts their attention with a bright pink modeling light.
    I am going to have to send you that damn light already. As you will be happy to know I now have the MOD light. I shall install a pink filter for nostalgic purposes on my trips with you though.
  2. Todd, I note you got the 8 inch dome port. I presume that this is so you have something that will work with the fish eye as well as wide angle zooms. Would the much cheaper 6 inch port work OK with the zooms (18-55 EFS and similar focal length EF lenses). I note the 8 inch port is significantly more expensive than the 6 inch.
    Ryan, thanks for your reply. I checked out James' link to the A300 initial review, which was cool. As you've worked out by now, the FEC hack has progressed, housed laptop no longer required! I note the underwater camera pro site mention an update to the intial review including some port info and housing in the water sort of stuff. I await it with great interest.
    PS Todd, even though you only have the one housing, if you don't have time to get it wet I'm happy to help out :)
  3. I went on Aquaticas recommendation. I also felt that with the dollars already spent that I did not want to short myself for a couple hundred dollars on the last piece.
    I'll leave the housing on the front porch, come and pick it up for a test drive. :)
    I love that Yahsemtough Blue!
  4. Todd
    It seems that the eyepiece w magnifier is quite an improvement.
    Can you easily read the tiny digital text ?
    Cheers Lars
