Sigma 150MM macro F2.8-Any experiences/pictures out there?
Started by TomR1 ·
  • 25Posts
  • 25Replies
  1. Stewart,
    That is fascinating info. The 150 with +5 may be much easier to deal with than the 105 with a +10.
    Tom
  2. Tom,
    Having used both, I agree
    S.
  3. I have some interesting options. It appears that I have a port combo which will allow me to mount one or two dry diopters on the Sigma 150. I am thinking I can mount the 5t (+1.3) and then use the +5 when I want and leave the +10 on the boat. I can still focus within 24". However the +5 wet will be further from the 150MM. Anyone know how that affects things?
    Tom
  4. Same same, i love the 150 sigma, a real pleasure to shot...like it was mention before on clear tropical water the distance is not realy a problem as long as the subjet it smaller than 20cm and on water with more particules: i arrange my strobe very much in front of the housing to minimize the Light /subjet distance, me beeing still far from the fish, it usually does not scare it.
    the mouving subjet are not scare ( see the photo below: this fish is so shy that this shot will be impossible if not with 150 ) : http://www.flickr.com/photos/101623137@N02/9730953994/
    with the subsee + 10 , i found it very difficult , but i presume it is also because my lense is 1cm away from the dome end, making the distance beteewn the dome and the lens too long ...someone has any idea ?
    but you get realy close shot : http://www.flickr.com/photos/101623137@N02/9866059744/
    with the + 5 it become resonable and easy to use...
    after using the 150 for more than a year ( all my last macro shot on my flickr galery are with 150 ) i can't go with another lens ( i try again 2 times the 60 AFS that i previously used, but it seems that the possibility are better with the 150 ), i really get use to it and it is great.
    enjoy wakatobi,
    Gilles
    Edited by Gilbubblefish
  5. I used the handy spreadsheet and came up with the following:
    150mm w/ +5 subsee. 3 1/2 (95.56mm) inch working distance 1.9:1 magnification max F/stop is f/22
    105mm w/+10 subsee 2 1/4 (58.16mm) inch working distance 2.2:1 magnification max F/stop is f/32
    150mm w/+10 subsee 2 3/8 (64.66mm) inch working distance 2.9:1 magnification max F/stop is F/22
    T.D Priest indicated that 2 8" arms were barely long enough to get the strobs in the proper position and suggested additional extensions or a remote strobe and a buddy.
    Regards and Merry Christmas,
    Tom
