RAW converters
Started by String ·
  • 23Posts
  • 23Replies
RAW converters
  1. download the DNG editor ffrom adobe. Run the program (no installer). Pick a DNG file with your normal base profile (or export a DNG from one of your normal raws). It will export with your normal camera profile.
    open the |DNG in the editor. go to the color matrices tab. use the bottom tint slider (white balance calibration) and set it to whatever you need.
    go to the menu and save the profile. It will automatically select the proper folder for your profile. At the next startup of Lightroom, it will be there.....
  2. cheers
  3. download the DNG editor ffrom adobe. Run the program (no installer). Pick a DNG file with your normal base profile (or export a DNG from one of your normal raws). It will export with your normal camera profile.
    Thank you so much, it was needed for me.
