3D Printed Nauticam Float Arm Bayonet Holder
Started by thetrickster ·
  • 28Posts
  • 28Replies
  1. Hi guy
    I know this post was long time ago but i just come here to say thank you to "Thetricker" the owner of this post your works so amazing!!!
    I downloaded your file and print it to use with my carbon fibre float arm. Actually my float arms diameter is 80 mm. so i have to fix it to suite them.
    Then i post my file here if someone who owned 80 mm. float.
    https://drive.google.com/file/d/11yUGMvQOuFsFfdlnTxGMH74wgMNSMwzl/view?usp=sharing
    Also here are the pics when assembly on my carbon fibre float arms.
    I thought the original Nauticam carbon-fiber float arms were 60mm or 90mm, whereas the current Nauticam float arms are either 70mm or 90mm. My two original 90mm arms flooded, and were replaced by Nauticam with the newly designed ones, 90mm. I also have two 60mm arms, that I'm only using because of the 60mm bayonet holder on one of them. I do not understand this reference to 80mm arms; I can't find any current or old arm descriptions of that diameter.
    Edited by tursiops
  2. I’ll modify the design for the 70mm I already have a design for the 90mm. Will report back tomorrow
  3. I thought the original Nauticam carbon-fiber float arms were 60mm or 90mm, whereas the current Nauticam float arms are either 70mm or 90mm. My two original 90mm arms flooded, and were replaced by Nauticam with the newly designed ones, 90mm. I also have two 60mm arms, that I'm only using because of the 60mm bayonet holder on one of them. I do not understand this reference to 80mm arms; I can't find any current or old arm descriptions of that diameter.
    My float arm are not nauticam. They are Meikon brand.
  4.
    LOL! Complete with blue o-rings!
  5. I’ll modify the design for the 70mm I already have a design for the 90mm. Will report back tomorrow
    Did you ever get around to doing this? Been thinking about switching to the wwl and attaching it to my 70mm arms would be ideal.
  6. Did you ever get around to doing this? Been thinking about switching to the wwl and attaching it to my 70mm arms would be ideal.
    I could really use the 70mm ones as well, as I just received warranty replacements! I really appreciate your time and help if you can make this happen! They have been so nice to use.
  7. Guys,
    Just click on Richard‘s link in his signature box … Custom 3D printed parts
  8. No worries ;)
    A 3d printed version of the Nauicam #17916 Monitor hood for NA-501 /502 is in the works for the NA-BMPCCII and 501/502 housings.
