Panasonic LUMIX GH5 for underwater video
Started by Nick Hope ·
  • 244Posts
  • 244Replies
  1. Impressive, barely any noise what so ever. Did you denoise this? Do you remember your settings here?
    This is about 28 meters with 8mm lens
    Skickat från min VTR-L29 via Tapatalk
  2. First, I don't think crop sensors are a disadvantage in terms of noise performance underwater, because if shooting THE SAME DEPTH OF FIELD on a Full Frame sensor or a m4/3 one, your noise performance will be the same. Yes, a full frame sensor will have about a 2 stop advantage in terms of ISO performance over m4/3, but that's entirely negated by the fact that you need to shoot at a narroer aperture on full frame in order to keep your corners sharp. Basically, when using a full frame camera, I almost never shoot at anything below F8 for wide-angle. Usually at F11. With the GH5, I'm usually at F4 or F5.6. Which means my ISO is 200 or so on m4/3, and 800 or so on full frame. Guess what? That gives you basically identical noise performance.
    A full frame camera will still have better dynamic range and higher resolution, but whether that matters largely depends on what you intend to do with the photos. Unless you're making really large prints, I think the GH5 is perfectly adequate for stills. About half the photos in my portfolio are taken with a GH4 and the other half with a Nikon D800 and Sony A7RII. I'd be surprised if many people would be able to guess which is which.
  3. First, I don't think crop sensors are a disadvantage in terms of noise performance underwater, because if shooting THE SAME DEPTH OF FIELD on a Full Frame sensor or a m4/3 one, your noise performance will be the same. Yes, a full frame sensor will have about a 2 stop advantage in terms of ISO performance over m4/3, but that's entirely negated by the fact that you need to shoot at a narroer aperture on full frame in order to keep your corners sharp. Basically, when using a full frame camera, I almost never shoot at anything below F8 for wide-angle. Usually at F11. With the GH5, I'm usually at F4 or F5.6. Which means my ISO is 200 or so on m4/3, and 800 or so on full frame. Guess what? That gives you basically identical noise performance.
    Dreifish is spot on you have at least two stops benefit with full frame however where you shoot f/4 in a mft fisheye with ff you are qt f/8 negating the benefit for ambient light wide angle.
    The resolution however is much better with full frame and this is something that doesn’t go away if you print. On a screen unless is 4K you don’t see the benefits and in video definitely you don’t see them.
    As a paradox I have seen full frame having much better performance in macro because mft have quite a bit of diffraction from f/11 onwards and at f/16 most lenses are weak and become garbled at f/22. Full frame you keep sharpness until the smallest aperture and the resolution is amazing
  4. Dreifish is spot on you have at least two stops benefit with full frame however where you shoot f/4 in a mft fisheye with ff you are qt f/8 negating the benefit for ambient light wide angle.
    But why would you shoot macro at F16 or F22 on m4/3? At F11 on m4/3, you get the same depth of field and diffraction characteristics as you would at F22 full-frame. Some full-frame sensors have more megapixels to crop into, but in actuality you get greater magnification in m4/3. 1:1 macro for m4/3 works out to filling the frame with a subject that would require 1:2 reproduction ratio on full frame to fill the frame. So in terms of detail, you should be able to extract more detail from small subjects with m4/3 than full frame simply because the pixel density is greater. Diffraction scales with depth of field, so it's ultimately equivalent for the same depth of field across different formats.
    The main advantage I see for macro with full-frame cameras is actually faster focusing with less hunting at macro distances. And I think that's primarily an advantage with newer generation Nikon (and perhaps Canon -- I have no personal experience) bodies. The 90mm macro on Sony A7x bodies is also quite slow to focus, like the 45mm and 60mm macro lenses on m4/3.
  5. But why would you shoot macro at F16 or F22 on m4/3? At F11 on m4/3, you get the same depth of field and diffraction characteristics as you would at F22 full-frame. Some full-frame sensors have more megapixels to crop into, but in actuality you get greater magnification in m4/3. 1:1 macro for m4/3 works out to filling the frame with a subject that would require 1:2 reproduction ratio on full frame to fill the frame. So in terms of detail, you should be able to extract more detail from small subjects with m4/3 than full frame simply because the pixel density is greater. Diffraction scales with depth of field, so it's ultimately equivalent for the same depth of field across different formats.
    There are plenty of subjects that you need f/16 if you want to focus more than the eyes like pygmies, bobtail squid, shaun the sheep nudis and you can’t really work out with f/11 likewise you want more depth of field on a larger subject if you want to focus the whole fish I have plenty of examples where the same shot on the same subject looks better on a full frame but less so on ambient light wide angle
  6. Hello Pajpen
    my settings were f 6.3 sh 60 and iso was 250 noise rduction 0 long shtr noise reducrion off
    glad you liked it..
  7. There are plenty of subjects that you need f/16 if you want to focus more than the eyes like pygmies, bobtail squid, shaun the sheep nudis and you can’t really work out with f/11 likewise you want more depth of field on a larger subject if you want to focus the whole fish I have plenty of examples where the same shot on the same subject looks better on a full frame but less so on ambient light wide angle
    But if you need f/16 on m4/3 to get the entire subject in focus, then you'd need f/32 on full frame, not f16 to get the same depth of field. And the loss of resolution to diffraction would be the same (assuming the same pixel size). The shot may look better on full frame because of dynamic range, for example, but assuming the same level of magnification and the same depth of field, they should look basically identical if I understand the physics correctly.
  8. I don't have a scientific explanation however look at those charts
    This is a Nikkor 105 on a Nikon D800
    https://www.dxomark.com/Lenses/Nikon/AF-S-Nikkor-VR-105mm-f-2.8G-ED-mounted-on-Nikon-D800E---Measurements__814
    Perceived resolution around 5 megapixels
    This is the Olympus 60mm on a OMD-EM1 Mark II
    https://www.dxomark.com/Lenses/Olympus/Olympus-MZUIKO-DIGITAL-ED-60mm-F28-Macro-mounted-on-Olympus-OM-D-E-M1-Mark-II---Measurements__1136
    Perceived resolution 3 or less megapixels
    In theory if you look at imatest etc looks like the two outcome are comparable but when you look at the same subject at those apertures it is not
    In terms of dynamic range you don-t see that in macro what you see is more colours due to the sensor so maybe the combination of colours and resolution together gives a better look
    For wide angle shots in ambient light not much to say for shots with strobes FF always much better colours
    For me is not much the dynamic range but the color depth and resolution where FF beats MFT however for video resolution does not matter and colours are anyway 8 or 10 bits so the extra 2-3 bits you have simply are not visible
  9. Interceptor, in the DXOLabs charts you linked, if you compare the percieved resolution with the Olympus at F11 and the Nikon at F22, they're both orange. Or compare F5.6 vs F11 for that matter. Perceived resolution looks pretty similar to me. Where are you seeing 3 vs 5mpix?
    A full frame sensor does have better color discrimination, but again, that's ISO dependent--just like noise and dynamic range--as Architeuthis pointed out. So for instance, the EM1 has better color sensitivity at ISO200 (23.7 bits) than the D850 does at ISO800 (22.6 bits). Of course, if you're not limited by depth of field and can choose use ISO 200 on the D850, you'll get better color sensitivity (25.1 bits) -- about 2 stops better, as we would expect given that the sensor has 4 times the light gathering area.
    In wide angle shots with strobes, you are no longer depth of field limited, so if you end up shooting both at, say, F8, ISO 200, then yes, of course the full frame sensor is going to show greater resolution, color sensitivity and dynamic range, since you're not limited by the depth of field as you would be with macro.
  10. Am looking at the sharpness tabs not the global ones
  11. Anyone using the GH5 with Nauticam housing and the Lumix 14-42 power zooming the WWL-1?
    How heavy does it get underwater?
    Is the WWL-1 easy to keep attached to the set up while not being used? (to make sure it does not change buoyancy from wide to macro)
    My wife is looking for a solution to shoot macro and wide on same dive with good results.
    Any tips on good video set ups are appreciated :)
  12. in water, with the right amount of additional floatation like the float collar, it can be neutrally buoyant.
    Having the WWL-1 attached to an arm while not in use is possible, but it's a bit inconvenient to be honest. You'd definitely want to have the float collar to counteract the weight of the glass.
    Personally, I think for easy of switching between macro and wide, you can't go wrong with a traditional camcorder..
  13. Hi guys, looking for solution that can support 4K60 10-bit for my Atomos Ninja Inferno recorder with GH5.
    I currently have NA-GH5 housing but Nauticam housing for Ninja Inferno does not support HDMI 2.0 for 4K60 10-bit
    It can handle HDMI 1.4 that can record 4K60 8bit, OR (but not AND) 4K30 10-bit ONLY.
    Just because of their cable.
    Any ideas?
  14. Hi Will
    It is a good question, for me i am looking for a solution for the Atomos Ninja V.
    Nauticam has written to me that they did not plan to make a housing to the Ninja V, so i am looking for the housing as well.
    What experience do you have with the hdmi cables from Nauticam?
    my last body tried 3 cables on a week and all cables made his Atomos show a black screen as soon as we got under water and the cable was moved a bit. No leakage detected though.
  15. What experience do you have with the hdmi cables from Nauticam?
    Hi buddy,
    I have not any experience with Nauticam's housing for external recorder because I didn't buy it yet (here in Russia it may cost me around $5000 for housing itself) for a reason I described - it can not record 4K60-10bit with native cable they provide, so it does not make any sense to use it until Nauticam get fixed their 'cable issue' in the factory but not DIY.
    I had a long conversations with Nauticam's guys with no luck.
    Or I have to find a way to replace HDMI (A-A) cable to high speed one with an adapter, nauticam's hole is not big enough to put HDMI-A (Full size) connector through it.
    For this moment I just have Atomos Ninja Inferno and GH5 and NA-GH5 housing and use GH5 without an external underwater monitor.
    I have an experience to use different HDMI cables with GH5+Ninja Inferno in my studio not underwater.
    So both (Atomos) cables I have are quite expensive ~$150 vs $50, and $50 cable does not support 4K60-10bit, but 4K60-8bit does.
    The $150 cable is OK
    https://www.facebook.com/photo.php?fbid=2209411635756424&set=a.177517785612496&type=3&permPage=1
    I have two more chinese s**t cables I bought at AliExpress for my experiments and they just don't work and show me black screen.
    Also I have complains about another issue that Nauticam has and doesn't want to admit and fix - TERRIBLE reflections in conrtlight from shining black surface that covering their DOME.
    I described it here: https://www.facebook.com/VitalySokol/posts/2112898938741028
    For now I use black velvet to cover backsurface (such as SeaCam's domes have), but I have to find good material and replace my old solution - it showes me black corners in 7mm focal length.
    https://www.facebook.com/photo.php?fbid=2256111124419808&set=a.177517785612496&type=3&permPage=1
    To Panasonic as well =)))
    https://www.facebook.com/VitalySokol/videos/2122858431078412/
    Edited by WillFalcon
  16. Hi Will
    Nauticam makes a housing for the Ninja V. Nauticam PN 17922
  17. Nauticam makes a housing for the Ninja V. Nauticam PN 17922
    Well spotted, Lionfish. It is indeed listed as Recommended Accessories for the BMPCC and Fuji XT3 housings. So it will be coming.
    No M24 bulkhead on the Nikon Z6/7 housing, so were bumped on that one re. new RAW option....
    Edited by bubffm
  18. Hi Will
    Thx for you comments, lets hope Nauticam soon will make a good solution.
    Hi Lionfi2s
    Thx Lionfi2s, have to admit i asked them back in March 2018, if i remember correct.
    And i guess they just did not have thought about it at that time?? And i read their mail like they never would make it :-)
  19. Nauticam makes a housing for the Ninja V. Nauticam PN 17922
    Don't see it at Nauticam's website.
