TTL flash trigger for M43 Panasonic/Olympus cameras?
Started by Pseudonym ·
  • 27Posts
  • 27Replies
  1. You may very well be right on TTL option, though the demand is low for that on a housing made for a camera primarily used to shoot video. I'm sure stills will be great on the GH5, so maybe an add on option for either (e.g $200 for regular flash trigger, $400 for TTL).
    Edit: Why am I offering up money making options for Nauticam? Move along, nothing to see here...
    Edited by ScubaBob
  2. hmm regarding the fiber optic cable..which one are you using now ? got iDive ones and they work fine with built in flash but dunno about the trigger
    I had issues with my old fiber optic cables initially. We tried swapping the LEDs on the flash trigger for some ultra-bright ones, and that didn't work either.
    The expensive Sea&Sea cables do work though.
    And, after some hassles (they sent the the wrong ones, and still charged me for them), I got a set of cheaper ones from Divervision. I like these ones because they're straight not coiled, and I can have a more streamlined rig.
    Just make sure that whatever cables you get have 613 cores, and I think you should be good. With 613 cores, there's noticeably more light transmitted than the crappy single-core variety.
    Hope that helps. Good luck!
  3. I am hoping that Nauticam will offer one of the UW Technics TTL flash triggers for an E-M1 II housing once they get that going.
  4. I use the Panasonic DMW-FL70 Flash in my Nauticam housing on a GH-5. It works very well in TTL and manual. Don't know if it will fit in your housing though. If you want, I can take measurements for you.
    Drawback is that it has no batteries, so you will drain the batteries of your camera faster. I had no problems during 2 -3 hour dives however.
    Edited by rollin
