Anybody shooting with the Panasonic GX80/85/GX7II?
Started by Interceptor121 ·
  • 46Posts
  • 46Replies
  1. Unfortunately small cameras tend to have smaller batteries and life is not so good. If you are after more battery life you might like to consider other m43 cameras. The GX85 battery is 1025 mAhr, I had an EM-5MKII with 1225 mAhr battery which would do 3 dives and probably 150 images or so. I now have an EM-1 II which has a 1750 mAhr battery, yet to test it out but has loads of battery capacity after 2 dives taking 100-120 images.
    If you don’t shoot ttl and set the flash to minimum you can extend your battery life considerably
    Video and TTL will kill a small battery in less than two dives from what i have experienced
  2. For those who have the Nauticam housing for GX85:
    Could you measure the size & weight of housing without port & tray?
    It is not indicated on Nauticam site.
    thanks
    I get an answer from Nauticam
    NA-85 is 1.1kg.
  3. I opened a topic to find solution to extend battery of GX9. It also apply to GX80/GX85/GX7II.
    You can find it here:
    http://wetpixel.com/forums/index.php?showtopic=62108
    I'm looking for available room in Nauticam housing to place a secondary battery.
    Battery size is 42x37x14mm
    It seems to me that on the right side of camera the free space should be ~16mm wide, 43mm in height: to be confirmed
    I don't know if the depth is higher than 37mm?
  4. I love my GX85, just wish there was an affordable housing for it.
  5. Video from the same dive.
    I have the same camera. Love the detail here. I need to find a housing for it so I can get started.
  6. I have the same camera. Love the detail here. I need to find a housing for it so I can get started.
    You should be able to find them - both Ikelite and Nauticam made them. The Nauticam housing is nice. Not as good as the GH 4/GH5 housings, but also much smaller. I still love mine - just been too busy with work to dive! (Blasphemy I know).
    Thanks by the way!
