Sony a6000 vs a6500
Started by dubscutty ·
  • 42Posts
  • 42Replies
Sony a6000 vs a6500
  1. I currently have an a6000 and looking to get into underwater photography. Is it worth spending the $$ to get the gear for the a6000 or should I look at upgrading to the newer a6500 before splurging on underwater gear?
  2. SeaFrogs Salted Line housing supports A6000, A6300, A6400 and A6500 with a few part swaps, so you can upgrade the body later if you like, and keep the housing. In any case, the improved autofocus on A6400 is more useful for underwater photography than the in-body stabilization on A6500.
  3. Thanks for the info. I'll have to do some more research on the A6400 as I was not considering it as an option.
  4. Phil Rudin has an underwater-specific review of the A6400 in UwPMag issue #108; you may want to check it out.
  5. The auto focus on the A6400 is truly remarkable for a camera at this price point and beats many cameras in the over $3000.00 price range. I also agree that AF speed and accuracy in U/W photography is much more important than IBIS.
    The rest of the article is a free PDF download.
    Edited by Phil Rudin
  6. Don't write off your A6000. I've been using it UW with a Sigma 19mm and Meikon housing for a couple years now. It's a lot of bang for your buck. Don't get me wrong, I'm hoping to upgrade soon but would still recommend the A6000 to anyone.
    Sent from my CLT-L29 using Tapatalk
  7. Hi dubscutty,
    I have been shooting with an a6500 and fantasea housing for the past two years until now (I just upgraded to a canon 7d m2 since I had a good deal on the setup). I do really like it, and I think it is worth going for the 6500 over the 6000. I also had the 6300 for 6 months with a meikon housing for 6 months or so a while back before I felt limited and upgraded to the 6500. I personally think it is the best cropped sensor mirrorless to take underwater, but I have not done too much research on the 6400 yet.
    Anyway, I don't think you could go too wrong with either! Good luck!
  8. I have been shooting with my A6500 with the Nauticam housing for 2 years as well. It's a great camera and I really like the housing. I did a lot of research when I purchased and felt the A6500 was the way to go. The A6400 was not on my radar, so I can't comment on it. What kind of photography do you do? Feel free to message me directly if I can help with other questions. Also watch in classifieds as I may be selling my wide angle lens and dome port for the Nauticam housing.
    Hey, do you have any sample images? I'm starting to consider the A6000 for myself and would love to see what it puts out
  10. Hey, do you have any sample images? I'm starting to consider the A6000 for myself and would love to see what it puts out
    Thanks [emoji4]
    Hi Dave, yeah sure, here are a few.  Like I say, taken on the A6000, Sigma 19mm f2.8 lens, Meikon housing, 1 strobe (InonZ330, some of them may have been taken with one Sea&SeaYs-02 strobe before I had the Inon).  I've got a Meikon wet lens attached to the housing.  The A6000 is 1.5 crop, therefore the Sigma lens is effectively about 28mm, but the wet lens widens it a bit, I'm guessing to about 20 or 22mm?? Not sure.  Anyway, it's a total workhorse.  Been used for I'd say about 600 dives over the last 3 years, as well as daily blasted on land.  I dread to think how many clicks its done and (touch wood) it's still going.  People argue that the Sony's have that 'weird colour science' but I've found it's totally fixable in LR.  Here are a link to some sample images... (can't upload them direct here as it's saying I can only upload max 0.98mb.
    Sample images
    **edit** Oh and forgot to mention re video, obviously there's no 4k but it does have zebras which I use constantly and it absolutely enables you to nail exposure every time.  No complaints about the auto focus either.
    Edited by Placebo365
    The Meikon wet dome isn't a true lens like, say, a Nauticam WWL-1 or Inon UWL-H100 - it's only a dome with air inside, so its effect is limited to restoring the lenses in-air field of view. Basically, when you put a lens behind a flat port and take it underwater, its angle of view shrinks by about a third due to refraction - Meikon's wet dome cancels this effect, similar to how a dry dome port would do the same, but it doesn't otherwise affect the optical properties of the lens. 'Real' wet wide lenses have multiple lens elements inside, and widen the camera's field of view significantly, but of course they cost a lot more.
  12. The A6500 is a major step up in autofocus performance over the A6000. With the hefty outlay for an underwater setup, I think upgrading to the newer camera is the sensible choice.
  13. Autofocus of 6300 and 6500 are the same.
    The 6400 is newer and got a lot of better AF functions...
    Stabilising is nice, but not so much worth than a quick autofocus....
    Water dimms a lot of shaking against air.
    Sample images
    Thank you! Lovely images. I think that's sealed the A6000 for me. I'm a bit confused about what lens choices still, but at least I know which camera to choose!
  15. Thank you! Lovely images. I think that's sealed the A6000 for me. I'm a bit confused about what lens choices still, but at least I know which camera to choose!
    No problem Dave. Started off with the kit lens 16-55 if I recall, not very sharp at all. I did loads of research on lenses too. Went for Sigma 19mm f2. 8 which is pretty sharp for the price. Great at f8 which is what I mostly use it at. F9-f11 I find it hunts quite a bit for focus. Good luck.
    The 16-50mm PZ is an okay starter lens, but on its own, it's neither particularly wide nor capable of macro. It is, however, very compact and quick-focusing - you can put it in a short threaded port and shoot wide-angle and macro with add-on wet lenses. There is an older 18-55mm kit lens, but that one hasn't been sold for years now.
    Expanding from that, for wide angle, there is Sony 10-18mm f/4, and... that's pretty much it. There is the Zeiss 12mm, but it suffers from a fixed focal length and can only do CDAF, while its 1-stop advantage in aperture (f/2.8 vs f/4) is wasted underwater.
    For fisheye, you can pick between Sony 16mm f/2.8 with VCL-ECF adapter (full controls and autofocus, but iffy quality and fixed focal length), manual lenses from Samyang and 7Artisans (cheap, but manual focus and fixed aperture once you seal the housing) and adapted options like Tokina 10-17mm (fairly expensive once you include the adapter and AF issues on older cameras like A6000). In fairness, fisheye is kind of a weak point for Sony, both on APS-C and on full-frame.
    For macro, there are four choices, each with its own compromises:
    • 30mm f/3.5 - small, cheap, generally fits the same ports as 16-50mm kit lens, but the short focal distance produces a very short working range - its 1:1 reproduction distance is practically on the port glass. More suitable for fish portraits than true macro.
    • 50mm f/2.8 FE - good combination of working distance and focal length - not too long, not too short - but very slow and unreliable autofocus on most bodies. Reportedly, the A6400 solves its autofocus issues, but with older bodies, it's not a good choice.
    • 50mm f/2.8 Zeiss Touit - suffers from the same issues as 50mm FE, but costs more.
    • 90mm f/2.8 G - great image quality, but costs a lot, and even buying used doesn't save you much. Autofocus can be fast (for a long macro lens), but you have to hold it absolutely still while it's moving its internals around; a bit  of current or surge can totally ruin your day. It also chews through battery - I can reliably get three dives out of a single charge with 10-18mm or 16-50mm, but no more than two with 90mm. The narrow field of view can also limit your shooting opportunities, especially in less than perfectly clear water - you simply have to stay way too far back to fit non-macro subjects into the frame. On the other hand, it's your best choice for true macro and supermacro.
    FWIW, I use the 90mm G, but if I had an A6400 rather than my A6300 (the former did not exist when I bought the latter), I'd probably go for 50mm FE instead.
  17. I guess it all depends on the final product you're after.  I upgraded from a NEX-7 to a6500 Nauticam housings and enjoy the better AF and IBIS (miss Tri-Nav though).   I shoot super-macro most of the time and MF is the most common focusing method, so focusing systems come more into play more in video and fast action shots.  The a6500's IBIS helps with lens that don't have built in stabilization.  I've set up my rig to shot with the very sharp and bright Sigma 16mm f1.4 in a 4.33 dome.  f1.4 is a nice fast lens for underwater video and has fairly fast and accurate focusing.  Use this with Sony's "Clear Image Zoom" function and a 15X diopter and you have some incredible footage in macro or WA using one lens (and swing diopter).  For those scratching their heads and thinking Sigma 16mm f1.4 in compact 4.33 dome with diopter?  I got the lens to fit by filing off the shade support mechanism and  grafted a swing diopter mount from my old Flat Port 72 onto it's wings (not for the faint hearted..it was a lot of work), but I love that stuff.
    Still photography fast action shooting will always benefit from improving focus systems like the a6400 and new a6600 have. I'm happy with my upgrade from the NEX-7 to a6500 though with the latter being no slouch in the arena of AF. Perhaps not as accurate as the new system in the 6400/6600 but I wonder how much?  Worth the extra buck when you can pick up clean used a6500 housings and camera now that the latest and greatest a6600 are out (just a matter of time for Nauticam, they never miss a beat.....
    Using some creative modifications,  I now shoot Sony 18-55 (single dive Macro & WA set-upset-up),  Sony/Ziess 16-70,  Ziess Touit 12 and  Sigma 16mm f1.4, all in my compact 4.33 dome (w/ swing diopter CMC-1 for macro with appropriate lens) using a mix of 20-50mm of mini-extensions.  Great travel rig.  However,  I also added the Sony 90mm macro housed in the  N100 manual focus port system which added to it heft, but nice sharp and long macro lens in APS-C format.
    Have fun with your new rig whatever you get :-)
  18. That's interesting to hear Marsh - I'm just getting into A6500 with 4.33 dome and right now have taken UW shots w the 16 mm Sony w fisheye converter. I also have the 16 mm Sigma 1.4 - what extension do you use for that? I've tried the Sony 16 mm pancake without converter behind the 4.33 dome and it had trouble focusing
  19. Sigma 16mm is a rectilinear lens (and so is the Sony 16mm without converter), so you will need a much bigger dome. 4.33" is basically for fisheyes only.
    Have you found good luck with the SeaFrogs/Meikon line?
