Is IBIS a must for for Underwater Video?
Started by Interceptor121 ·
  • 52Posts
  • 52Replies
  1. I have been always looking at camera with IBIS for underwater video. There are some little bumps and movements that cannot be avoided especially for close up handheld work
    Recently however many cinema cameras without IBIS have come on the scene BMPCC4/6 ZCAM and some top range canon models like 1DXIII also do not have IBIS as well as Panasonic GH5s
    I see lots of footage shot at 60fps and then slowed down to 24/25/30 to mask the instability and wobbles and the difficulty of the diver to hold the camera steady, personally I hate those type of shots as things underwater with some exception do not move fast at all. Water is a liquid after all with dampening effect. I also find that if you need slow motion you would need in excess of 100 better 200 fps to have something really interesting to see
    So I wonder in 2021 how people feel about IBIS?
    Are there advances in post production have better results than say 3 years ago (from what I can see artefacts show in water but maybe I do not know the latest and greatest software)?
    No IBIS can beat a tripod
    How do you place a tripod if you are doing a wall dive exactly? In some places it is forbidden to lay anything on the bottom too
    Edited by Interceptor121
    I guess you don't shoot macro video there (or at least not a good one)
    There are plenty of situations where you don’t or can’t use some form of tripod
    And in some places you cannot lay anything on the bottom or your dive guide takes you out of the water
    IBIS helps for any type of framing close shot that is not macro anyway like your pike scene which is in fact shaky
  6. I have become so used to IBIS over the years that I sometimes forget it's even on. It certainly doesn't help much in terms of smoothing movements underwater and IMO I don't think there's as much value/affect underwater as there is topside.
    One thing that I have enjoyed recently is that some camera manufacturers now (I shoot Sony) will record gyro data and you can use that gyro data to stabilize your footage in post. I haven't put it to test underwater yet because I don't find a whole lot of need for stabilization, but for topside it has been really impressive to be able to stabilize footage using the gyro data in-post rather than in-camera and dial in exactly how much stabilization you want to use.
    Note: I don't shoot macro, only WA.
    Edited by rgilkes
  7. I've been filming without IBIS since GH2 GH3 GH4. No problem at all. Now I have it with my GH5 and it helps a lot on certain kind of shots: I can shot at 35mm with the 12-35mm. It was impossible without IBIS.
    Anyway IBIS is not a substitute of good diving skills and proper filming gear configuration.
    I see a lot of people blaming their camera while they really need a diving training or simply to modify their housing trim. Neutral buoyancy it's not enough.
    I absolutely agree that it helps for most of the standard and wide angle situations (and new digital solutions are not that bad e.g. reel steady for GoPro or the Insta360 One X(R) solutions) , but for macro, it's too little help in my opinion.
    Some people also argue that IBIS is important for macro photography, but a strobe is just a much better solution.
  9. For macro you need a tripod FULL STOP
    If we are talking about real macro frame size of 36mm wide for use
    However most videos you see are not real macro they are close up work with frame size between 10 and 30 cm. I can manage those handheld if the conditions are right with IBIS but not without for up to 10-15 seconds
    At higher magnification you have all sorts of issue as the depth of field is minimal so if your subject moves you are fried together with your tripod
    Could you post some examples for handheld close up footages
  12. Could you post some examples for handheld close up footages
    Abu Dabbab 2019 - Filter Matching tests
    3:00 onwards
    I have done seahorses handheld in 2012 it is possible but hard
  13. Could you post some examples for handheld close up footages
    This is all handheld
    4K Diving Puerto Galera 2016
  14. In my opinion, most of these footages could have been improved by using a tripod.
    at 30" close-up shots with the Lumix 12-35 (24-70) at 35mm.
    It's impossible shooting video @70mm without IBIS
  16. In my opinion, most of these footages could have been improved by using a tripod.
    Tripod is not good if the fish moves octopuses and sea horses do that
    So the tripod is only good for a nudibranch or for some types of shrimp the rest is always handheld
    Hence you need IBIS
    On land I use a pan and tilt head for tele work but not for macro that is static tripod but doesn’t work with bees or similar only with flowers
    Fish unfortunately swim
  17. This is a trip where I had a tripod base
    However I could only use it for a very small set of shots because the fish would move except frogfish
    As long as you follow the parallax of a fish you can shoot handheld is the same on land
    Tripod are good for static subjects only when there is sufficient depth of field and therefore the use case is extremely limited
    Fly into Lembeh
    We are in the same page.
    Anyway kudos to macro works. It's really another sport. I learned the hard way.
  19. I searched some tripod work (not mine) as a contrast. This is a recent video posted by backscatter:
    You can also check the work by Ewan Sherman, which is mainly tripod work (just an example below)
    https://www.seasickproductions.com/bali-close-up
    Best examples you can find in the movies by Howard Hall
    http://www.howardhall.com/short-videos/
    For me those videos are way superior than your handheld footages. I agree that tripod cannot be used for many things and most of the time is impractical, probably the success rate is very low, but when it works the results are much much better.
    All of my shots are far away from shore at 70-90 meter deep. Most of the time no way to use a tripod.
