Practice with strobes
Started by Sandyzoo2 ·
  • 23Posts
  • 23Replies
  1. 15 minutes ago, Sandyzoo2 said:
    As he said, after power cycling the Retra it requires another learning shot - but it's no big deal.  You need to remember to do it though or you will miss your first shot!
    In general, I find it to be a good practice to take a test shot of a wall before you take the camera rig for a dive. This serves to confirm that everything is turned on and connected as it should be, strobes are firing, caps are removed, etc. This is also a good opportunity to establish the pre-flash pattern when you're using Smart SL mode. It is also best practice, as suggested by Oskar, to have the strobes turned on before you splash, as this way the leak detector is functioning as the strobe is submerged, so that if you get a leak into the battery compartment, the strobe can immediately alert you about it. If you follow this routine, then the first shot will have occurred back on land, and your system will be ready to shoot (barring the need to burp a wet lens, if you have one) as soon as you splash down.
  2. On 3/13/2022 at 9:02 AM, TimG said:
    Yep, it is worth trying:
    Have a start with this:
    https://www.backscatter.com/reviews/post/How-To-Underwater-Strobe-Flash-Placement
    Also, Alex Mustard's book, "Underwater Photography Masterclass" and Martin Edge's "The Underwater Photographer" are well worth  a read. Both available at Amazon.
    Great advice! I have read both of these books and they are excellent.
