Wetpixel Live: Strobe Triggering Advice
Started by adamhanlon ·
  • 22Posts
  • 22Replies
  1. 3 hours ago, LeftyMD said:
    Sorry to revive this old thread, but im curious to know if anyone has an experience with this trigger. I bought a seafrogs housing for my EM5 III and it seems that the maximum sync speed with this trigger to my strobe is 1/100. Anyone else with the same experience? Might consider selling this housing and trigger if it is indeed the case.
    You might be in a mode using electronic shutter, that will reduce the maximum sync speed.
  2. Should sys at 1/250 as specified by the specs.
    I have seen bad or rather non multi core fiber cables that will cause some issue.
    You didn't really specify what you have tried and not tried.
    Sent from my SM-S908E using Tapatalk
