Some thoughts about Nauticam water contact wide angle optics
Started by Interceptor121 ·
  • 26Posts
  • 26Replies
  1. Just now, Barmaglot said:
    I know - that's why I'm asking about the WWL-C, which is built for a 24mm-equivalent lens behind it.
    Ah sorry. If you have the WWL-C worth trying as a first buy probably not the best idea
  2. I don't have the WWL-C - I currently shoot A6300 + 16-50mm + UWL-09F - but I'm curious how the combination of a better lens and slightly smaller wet lens will stack up to 28-60mm + WWL-1 and other options.
    Personally for photos only I would not get a wet lens at all. You will never remove it
    The WWL-C is a simpler construction in my opinion will drop quite a bit
  4. In Puget Sound (including dry gloves), I do tend to remove the -1B and also carry a CNC-1. The biggest difficulty with the WWL-1B and diopters is the lack of larger indexing marks with respect to the port and caddy bayonets. I've had to put a little yellow tape on the side which aligns with the bayonet latch.
  5. I am also here in the PNW (with drygloves) and the primary selling point for me is the ability to switch between the WWL-1 to CMC-1 macro and back... I often switch at least once a dive, it isn't hard if you have good mounts for it; but it does take a good 30-45 seconds of concentration and isn't as easy as a flip filter, but still easy enough...
    Edited by insomniac
  6. I am also here in the PNW (with drygloves) and the primary selling point for me is the ability to switch between the WWL-1 to CMC-1 macro and back... I often switch at least once a dive, it isn't hard if you have good mounts for it; but it does take a good 30-45 seconds of concentration and isn't as easy as a flip filter, but still easy enough...
    Thanks guys
    Clearly there are people that benefit from the wet mount
