Seeking help with gear set-up for Sony a1
Started by Frothin ·
  • 24Posts
  • 24Replies
  1. 21 minutes ago, ChrisRoss said:
    You can remove the focus knob if that is a concern, refer to the instructions here:  https://drive.google.com/file/d/1eqjAuRyQbazThYDkdThLO0zsoLvzdktJ/view
    If the concern is the price, probably no alternative the 45 on the port name refers to distance from port flange to the port glass and if you use a longer flat port you risk vignetting if the lens is not close enough to the port glass.  The closest is a N100 flat port 50.
    Many thanks for that! Will be exactly what I will do.
  2. 34 minutes ago, ChrisRoss said:
    The Nauticam A1 housing is a little over 60% more expensive than the OM-1 housing.  Similarly ports are more expensive and larger.
    True, but then you'd need to buy a new $2200 body, which will eat most, if not all, of the savings. Honestly, if I had an A1, I don't think I could imagine using any other camera underwater.
    FYI - I bought this recently and removed the focus knob. Super easy and it works well.
    Thanks. Good to know.
