Max 3 dives with D500 battery?
Started by sinetwo ·
  • 24Posts
  • 24Replies
  1. 2 hours ago, sinetwo said:
    @TimG can you share your exact setup and settings on how you get such good battery life?
    Sure, but they were nothing special.
    Focus set to AF-S; mode on Manual,; varying shutter speeds from around 1/60 to about 1/400. UWT trigger (which allows high speed sync (HSS) with my Retra strobes); fibre optic cables; f stops between f8 and f22; No Liveview; minimal image review between shots; camera switched on throughout dive with sleep on default setting; focus centre-weighted.
    I plan on diving today and will be using the same settings so I can check further. But, as I say, really nothing special or unusual. Apart from using HSS a bit , I use pretty vanilla settings.
    I must admit I was surprised by the battery life. I usually change batteries at the end of each dive day but pushed it as an experiment to see just how long it’d last. I used my setup just as normal not taking any special efforts or changes.
    Edited by TimG
  2. @TimG thanks, I think you're right in the way of AF/VR using battery. I'm guessing D500's AF system is fairly intense and may require more battery life, and perhaps that in combination with VR drains it even more.
    I read up on this thread that seems to indicate this as well. Perhaps I should try turning off VR and see if that makes the difference, as I also use vanilla settings for both macro and wide (perhaps long exposures every now and then).
  3. Interesting thread in that link. Thanks.
    Hmmm, makes me think a couple of things:
    - make sure the Wifi/Bluetooth bits and bobs are switched off
    - turn off VR
    - maybe reduce the standby timer to as little as you really need. (I know Mags was keen to increase hers)
    - it made me wonder whether using a WA lens (rather than macro) also reduces battery power usage. The 682 images I took on less than one full battery were all using a Tokina 10-17. So minimal - almost no - focus hunting or shifting. That said I have used either a 60mm or 105mm (VR off) loads of times and have never really noticed a battery drain that caused me any kind of concern.
  4. Just done 2 dives this morning in awful (for Sint Maarten) viz caused by swells.
    70 images recorded and camera showing 62% charge left with my oldest battery - an EN-EL15 (not an a, b or c model)
    Here's the settings:
    Mode: M
    Shutter: Between 1/40 and 1/125
    ISO: 200
    Aperture: f11 or f13
    AF-C (not AF-S)
    XQD = RAW
    SD = RAW
    WB Auto0
    DX
    Single Shot
    Notes: Only very short image reviews; No LiveView; Lens Tokina 10-17 so no VR; Standby Timer (c2) 6secs; Matrix Metering
    Like I said, nothing unusual in any of that.
