Compact vs Mirrorless
Started by lbedogni ·
  • 22Posts
  • 22Replies
  1. On 2/5/2023 at 10:34 AM, ChrisRoss said:
    Currently you have a olympus 60mm macro which will do 1:1 which is a frame 17.3 x 13mm.  If you refer to the Nauticam N50 port chart I linked above it gives the min frame size.  A G7XIII can do down to 23 x 13 so not as good as you currently have.  The RX-100VI/VII can do a smaller frame of 14.3 x 9 but only focuses 84-94mm from the port which means you have a big gap between what it can with the diopter and the bare lens.    In other words you are stuck around the 14 x 9mm frame size with a big gap to the bare lens.  You would be really hard pressed to match the experience using the 60mm macro if you change to a compact.
    As for the EPL-10, the AOI housing for that really is quite compact, but the AF won't be a match for the EM-1 MkII.
    I see, thanks for the detailed answer. I believe I'll have to stick with the EM1.2 for now.
    That's why most UW photographers stick to the RX100V(A) - here the full zoom range can be used.
