Moisture alarm
Started by Arnon_Ayal ·
  • 26Posts
  • 26Replies
Moisture alarm
  1. I understand that Aquatica dealers have it but since I don't have any one of them in my area I need to do order it myself. Any ideas where?
    Recommendations on good/poor products will be also appreciated.
    Edited by Arnon_Ayal
  2. Hi,
    Check out the LEEK detector sold by Wetpixel sponsor Marine Camera Distributors (at right). I also did a short review of the detector, which can be found in the reviews section here.
  3. Hi,
    Check out the Universal Moisture detector sold by Wetpixel sponsor Aquatica (at right). This detector can be set up in ajust about any housing with its self adhesive lining. It is small and very compact. Check out their site for dealers close to you.
    Mauricio Handler
  4. I bought the Aquatica moisture alarm from B&H for around $70 + shipping. It comes with installation and operating instructions and a battery. Quick, easy, painless... as long as you don't have to ask B&H any complicated questions.
  5. Tn'x for the info.
    I'll probably order the LEEK detector from Marine Camera since its cost 1/4 then the Aquatica product unless someone have an idea if the Aquatica is so superior that is worth so much money.
  6. An audible alarm is REALLY nice to have. The LEEK detector is visual only.
  7. Aquaticas alarms are also visual only. For years they where both audio and visual but changes in the last few years have made them only visual alarms.
    Mauricio
  8. Another questions:
    - Does thus detectors detect humidity or actual water?
    - Why Aquatica stop the audio alarm? its seems very useful.
  9. I have a leak detector from Marine Camera Distributors
    Is only optical but its work fine. But my sensor has one light and 2 Sensors??!!
    Is there any need for the second sensor and how you hold the sensors and light in place inside the housing?
  10. Double faced tape or velcro, silicone (very thinly) for the diode and probe (not the terminals leads, they need to be exposed).
  11. Another questions:
    They usually only detect actual water. The water is what closes the circuit to make the light or sound go off. They're definately housing-life-savers ;)
    Cor
  12. O.K. Sould i do it like this?
    Or sould I put the second leak detector or the right side?
    The diode is facing inside now. Is it save to put Silicon around the diode?
    lambis
  13. Use a very small bead of bathroom silicone sealer, the one you can peel off, your installation looks good, but your terminal (probe) should be flat on the bottom or as close as can be, the way your's is set-up, the water level would be really uncomfortable when it reach the probe sensor. :)
    Whatever you do, never, I repeat never use crazy glue :), epoxy or contact cement on your acrylic window. ;)
    cheers
  14. Thanks Jean
    By terminal (probe) you mean the second (on the Right) detector?
    Its sad that the electric wire that goes to the LED is not longer.
    Nexus have a small window on the top off the housing (above the viewfinder) It would be e exelend place to place the Led.
    Thanks again my Friend...
    Lambis
    P.S. What happen with the new D2X aquatica housing??
  15. Hi Lambis,
    It's long enough - there's no reason why the battery and electronic block needs to be on the bottom of the housing. In fact, it shouldn't! All that needs to be on the bottom is the small electrode which contains the two contacts.
  16. Thanks James
    The battery have to some electrodes. What is the need off them?
    Is it of double Security? You say that the Battery must be in a place protected from Water so that if you have a minnor leak you still can use again the Leak detector?
    lambis
    Here is drawing of how I would install the probe (terminal) the important thing is not putting a bead all around it, otherwise would make a barrier preventing/retarding the water contact with the probe sensor terminal.
    Hoping you never have to face the light of fear ;)
  18. Is it of double Security? You say that the Battery must be in a place protected from Water so that if you have a minnor leak you still can use again the Leak detector?
    Hi Lambis, the battery should be protected because if there is a leak and the water reaches the battery first, the warning light will not work when water reaches the sensor and you will never know there is a leak.
    Luiz
    Edited by Rocha
  19. If the wire are too short, too long or whatever, a simple soldering iron is all you need, you want that LED where you will notice it and the electronic out of harms way and have easy access to the battery, (always carry a spare battery, not much use with a dead battery ;) ),
  20. I dont think Jean that you cane replace the Marine Camera Distributors leak detector battery but maybe I am wrong.
    I think that the best is to protect the Battery with some Silicon.
    Lambis
