Hi Marc,
Here is another guy who's working at the same problem, it was
already in the forums and there were also some interesting answers (from RUIZ, etc.).
I'm working with a D2X in a Seacam-housing, two SB800 (in
Seacam-housing with powermodule & targetlights). At this moment
I can only use "one" SB800, and I-TTL is working fantastic underwater.... (I'm also using Subtronic Megacolors on manual and this works much better than I could ever believe)
But first of all, after 37 dives with the D2X, I can tell you that TTL is
NOT necessary with this camera. But ofcourse when you once used
the SB800's topside, you want to use them underwater (just like me).
Wiring the two SB800 together does not work. (see the explanation of
RUIZ in the forums / both flashes are thinking they are the master).
Wiring one (I-TTL) and using one on SLAVE I-TTL is the solution (BUT THEN YOU NEED A FLASH HOUSING WHICH DOES NOT COVER THE SENSOR). Sealux has such a housing (I think it's the only one).
The SEACAM & SUBAL housings for the SB800 are both covering the sensor. The flash is in a tube-housing. At this moment a foto-repair-store is looking if it's possible to replace the sensors to the top of the
SB800, so I can place it in my Seacam-housing (and the sensor is
not covered anymore)... I'm waiting for an anwer. In this case, one
of my SB800 is lost for topside...
Topside it's also possible to use two SB800 on I-TTL by wiring the master-flash to the other flash (connection at the side of the SB800). Maybe this is also a solution for underwater (rebuilding the flash-housing of the master flash / extra flash-socket to wire the master-flash-housing to het second flash-housing, etc...). I DON'T KNOW IF THIS IS POSSIBLE... (and a lot of cables for underwater...)
Your solution is very interesting, but how can you connect the fiber optic
cord to the second flash-housing? And is it working with I-TTL on the D2X... The I-TTL system of the D2X is not the same as the D70 or a compact-digital... Let me now if it works please. Maybe your solution is "THE SOLUTION".
For those who are thinking of housing the fantastic SB800. When you only want to work with one flash there is no problem, but if you want to use two flashes... Maybe it's better to wait :
1° Subtronic is working very fast and I think in a few months the digital
NOVA is ready for D2X I-TTL.
2° I-TTL is not really necessary with the D2X, manual flashes are working fine...
Bart
