Fotocore GTM?
Featured Replies
Hi guys… someone has used this strobes?
I have used inons for almost twenty years, for macro(z330 with beam reducer) and fill wide angle.. love their compactness/weight/power ratio for travel.. always used them in full manual mode, so i don’t need the latest gimmick..
I’m searching something comparable in size and power for both macro and wide angle..
those fotocore gtm are even comparable? Other strobes similar?
For what i see around seems that I’ve to wait the z360(but when?) or going heavier and a lot more expensive!!!
Thanks!!
Fabio
I have two and there is a write up somewhere here about them. The GTM for me is quite similar to the Z330 but I think better built, i.e. it is all metal and uses modern Li batteries and has a circular flash tube. They are pretty heavy but underwater not so much. The Paper Nautilus below was shot with 2 of the GTM
  • Author
Thank you!! Have you tried them also in wide angle photography?
I saw the backscatter big test and they rated them so low in GN that it’s difficult to believe.. 😬😬
Sorry, I only shot a few wide shots and they were all CFWA. For what I shoot, and comparing them to my Z330, they were equally bright. but I clearly am the wrong guy to ask about wide angle. There are 7 power levels and I never went above 3.
Bill
I am quite suspicious of the Backscatter GN testing. There are a lot of issues with the data, GN is not linear and in most cases that I have ever seen, the GN underwater is considerably less than in air. Their data shows the opposite. If you were closer I would let you borrow one to try but it is a long swim to get here.
BV A
  • Author
BV A
I agree… it’s very strange 😬😅😅
