Rechargeable battery advice
Started by wetpixel ·
  • 41Posts
  • 41Replies
  1. mAh is Milli Amp Hours and states the storage capcity (run time) a battery will have. The spec you need to be concerned with is the voltage. AA rechargables are usually 1.2 volts. Higher or lower mAh will only affect how long a device will run and does not harm the device in any way. It's kinda like the difference between a D cell and a AA, both are 1.4 volts (alkaline) but the run time is substantially higher in the D cell. Now when it comes to an air tight sealed unit like an underwater strobe I THINK (assume) that the higher the mAh, the more off gassing it will produce but I'm not sure. In any case I'm using 2000mAh batteries in my two 90dx's with out a problem and they have the same case as the 90Auto.
  2. Thanks Robert,
    Voltage is the first thing I consider before I read the Sea & Sea Menu. But do you understand what is this sentence for? "Use only manganese, alkaline, lithium, Ni-MH or nickel-cadmium bateries rated 1000mA or less in this unit." Why it emphasizes current? Do we have choice on this?
    :D
  3. I think that is a typographical error. Should read mAh.
    I also don't agree with them. You can't even BUY 1000 mAh batteries anymore. Jeeze.
    Everyone I know uses at least 1,600 now and has not had any problems.
  4. But do you understand what is this sentence for? "Use only manganese, alkaline, lithium, Ni-MH or nickel-cadmium bateries rated 1000mA or less in this unit." Why it emphasizes current?  Do we have choice on this?
    I think this is a CYA because the higher rated batteries produce more gas build up and they don't want that becoming a cause of a flood. I really don't think this is an issue or Ike would be saying the same thing, and he's not.
  5. Robert,
    In this case, I gotta get out to look for some >2000mAh NiMH batteries. Thanks!
    Nawk
  6. 2200mAh are the latest and greatest but my problem now is with the run time of my CP5000. Thomas Distributing
  7. I have a set I used to use in my Ike AI strobes. 3500 mAh for a C cell is not high. They range from 3000-5000mAh. The larger the battery the more capacity (mAh) it will hold. Again, this is not voltage it is capacity (run time). For example, D cells range from 4000-11000mAh. As for recycle time, I'm not sure if the quality of the battery has anything to do with this but the higher mAh rating will not.
  8. Has anyone tried the Uniross 2300ah AA's with the 2hr sprint charger. Costs around £27 here
  9. Hi all,
    any one up on the skinny about the differences between lightweight rechargers, such as the ipowerus FC402 (110/240V) and the much (4x?) heavier chargers, often requiriing an ac adapter and often single input voltage?
    2mike
  10. Thanks Eric!!! You're the greatest ;)
    By the way - the site is looking absolutely fabulous!
    Woody
    (sorry, posted this in the wrong place, but I can;t find a way to delete it)
  11. I'm replacing all my AA's (24) for an upcoming trip. There once was a link to a comparison chart of the different brands and their performance. I haven't been able to find it. My 1st thought is either Maha's or Ansmann's from Thomas Dist.
    Also, has anyone tried the newer 2500+ mAh batteries? My old ones were 1800's.
  12. "Also, has anyone tried the newer 2500+ mAh batteries? My old ones were 1800's."
    I can see how higher mAh batteries would off gas more. I'm wondering if you wait a day after charging before putting them in the strobe if that helps things. I think the newer strobes can handle it, however the older ones don't, so they advise against the NiMh. I once had a strobe flood and I recall that the batteries were still warm when I put them in before hand. I see there are now 2700 AA's available, and I was wondering how much extra risk is involved?? Thanks- John
  13. "Also, has anyone tried the newer 2500+ mAh batteries? My old ones were 1800's."
    I have used 2.7 Ah NiMH in my Inon Z-240s (type II) and Nikon SB800 strobes for several years now without incident.
    Bob
  14. I too use 2700 mAh batteries in my Inon Z-240s (type 1 & 2) for the last few years without any problems and I change batteries after two dives to a fresh set. I also use a pulse tester to check my batteries before each trip to ensure 100% capacity.
    Elmer
  15. I too use 2700 mAh batteries in my Inon Z-240s (type 1 & 2) for the last few years without any problems and I change batteries after two dives to a fresh set. I also use a pulse tester to check my batteries before each trip to ensure 100% capacity.
    Elmer
    We are so on the same page Elmer.
    Bob
  16. It is funny how these NiMH batteries lose their capacity after sitting around for a few months. With the pulse tester I am assured of a good set of batteries for the trip.
    Elmer
  17. pulse tester? as opposed to a volt meter?
    -J
