39mp underwater
Started by Troy Aitken ·
  • 264Posts
  • 264Replies
39mp underwater
  1. 2) When you talk about Lembeh, what are these conditions? Are they similar to Grand Cayman?
    Actually I would consider those as two extremes! Lembeh is a famous muck diving spot in Indonesia that is particularly popular with underwater photographers. This is partly because there are many fantastic subjects for macro underwater photography and partly because most of these subjects don't move and are easy to photograph. Most of the critters are between the size of your fist and the size of your thumbnail.
  2. IMHO the first is something of an irrelevance - the whole point about different formats is that they use different lenses to do somewhat similar - but not identical - jobs and as such you simply cannot compare the pixel level IQ because apart from any other consideration there are lens design parameters and physical factors which mean that the image laid down on the sensor has different characteristics - even assuming identical sensor characteristics. 100% crops will I suspect be totally unconclusive! If, as you point out, a MF digital back can outperform smaller formats in a studio, then it stands to reason that it will outperform them underwater, but.....
    There are claims being made here that MF is capable of far greater enlargements than 35mm. In fact, the enlargement capability that's implied is much greater than the extra sensor size or pixel count would suggest. If this were so, then there would have to be undeniable per-pixel IQ benefits to the larger format. It can't be any other way. If 100% crops are inconclusive, then claims of MF IQ superiority are unsubstantiated.
    Now, if the comparison becomes one of like print size, then 100% crops don't have to tell any particular IQ story. MF users never make the comparison this way, though, and you can look no further than the discussion on MF aperture limits to see how pervasive this is. If we were comparing like enlargements, an H3D could (and should) be stopped down further than f/16. The fact that it isn't is proof that per-pixel sharpness is being maintained.
    Ultimately, you have to put a stake in the ground. If you are going to talk about sensor sizes, pixel counts, and enlargement capabilities, then you should expect per-pixel performance to matter. People like to attribute desirable qualities to larger formats, but if those qualities exist then we can measure them. The first step to that is to standardize the manner in which we compare. There is always resistance to that among advocates of these larger systems.
    Regarding the use of different lenses, I believe that's more to the point. Different systems have unique components other than just sensors. I wonder how much different the lenses are when you only consider macro, though.
    I would add, finally, that I've read claims that MF digital offers dynamic range benefits over 35mm beyond ADC bit depth and lens design because their bodies surpress stray light better. I don't know if that is really true, but it certainly could be. I don't believe that such a design feature necessarily translates into better images all of the time, but it is another example of how it's the complete system that matters.
    MF advocates remind me of audiophiles, and the two types of products are similar in a lot of ways. There's enough technical merit to justify superior performance objectively, but there's also a lot of mythical benefits. An MF shooter may like the way a certain lens performs just as an audiophile may like the way a certain amplifier sounds, but just because they like it doesn't mean it's objectively better. Like audiophiles, some photographers just don't like the idea of these differences being quantified. I'm not interested personally in the Tice clocks of underwater photography.
  3. OK Craig.
    If you feel like taking it, here's a challenge for you.
    DEFINE Image Quality! Remembering, of course, that you cannot seperate a format from its lenses! Is it merely a function of how large a print you can make from a given format? Is it about dynamic range? Or is it a far more complex interaction of projected image and sensor characteristics. What figures would you use and where would you set the levels of poor, acceptable and good? I'd say that this is a tricky one, but do give it a go.
  4. Hello Craig,
    I thought we cleared this up but, here we go again hopefully for the last time. You are really discouraging me from posting any images in the near future.
    Craig said-
    Troy, I am toning it down. I address each wild, unsubstantiated claim as it comes up. You may not appreciate that kind of "toning it down" but maybe you should be prepared to provide sound arguments for your assertions before making them. It does not further the cause of MF to make unsubstantiated claims.
    Your tone I was referring to was being disrespectful and putting others down of whom you probably don't even know. It's one thing to disagree and correct others contructively to encourage everyone to be willing to participate so we all can learn new things.But it's another to put others down and call it "toning it down". Over and over I seem to be trying to satisfy you that my digital mf set is new and new things will be discoverd about it. There are variables that need to be added to what you know in your head. Only experience can teach and show this. This is what I am willing to do. All I am trying to do is share my images and experiences about my set up. You seem to be bent on misrepresenting what I have posted and trying to push this thread towards the notion that I am trying to prove the mf format to be better than the 35mm format. I am not making these assumptions. I am hoping to share for everyone to comment on the findings from using this set up. Then as things progress we can be more objective in the findings.
    Craig said-
    All of us have interest in seeing what this rig can do underwater, but so far we haven't seen much. Ridiculous praise over unremarkable samples doesn't further the cause of your format. We're too familiar with what other cameras can do for that. You have yet to post anything that demonstrates any technical value of the H3D, not a single 100% crop nor a single corner, you don't provide adequate technical information on what you do post, and you haven't shown anything of subjective value that would get the attention of an experienced photographer. It will be hard with your approach to earn the respect of either gearheads or photographers; you just aren't showing anything that can't be done already.
    Troy's response-
    Of course, no one has seen much. Many divers with 35mm formats have been shooting for a number of years and should have alot to say and images to post. But to draw judgemental conclusions so quickly at someone who has only had this set up for I month with 4 dives is unfortunate. You want tech specs go to hasselbladusa, better yet call them. If you are so familiar with what other cameras can do, then post some of your own work to show than some of your knowledge has dropped down into your hands for you to actually do. The crop of the juvy flamingo tongue was 100% cropped. At least that was a start. Tech info was not why I started this thread. Any person with Google can spend a few hours and read up on what I have not mentioned and spew it out like they designed the equipment. But there is little practical info on the H3D u/w. If you can allow me, I will be more than glad to share and answer questions as best as I can from what I find out. I will suspect within a year of practice and learning the equipment everything will improve and I look to aim to have a Gallery of images to display.
    Craig said-
    I am intrigued by the combination of low ISO, 16 ADCs, and fast shutter sync for sunballs. It's too bad that your wide angle lens isn't particularly wide. Still, sunballs are what I want to see, and your local dive conditions should be ideal for that. As more than one photo pro has said here, there doesn't seem to be any compelling reason to consider MF digital underwater. It would seem to me that you would want to show something that plays uniquely into the strengths of your rig if you wish to demonstrate something compelling. Otherwise, you will need to demonstrate that your optics aren't neutralizing any benefit you get from the bigger sensor, since all you have left is your claim that the H3D is suitable for big prints. I don't accept your big print claims as fact since we haven't seen evidence that your port system can outperform a 1Ds2 solution. A camera body, be it an H3D or 1Ds2 or D80, cannot be used to make prints at all; you have to have a complete solution.
    Troy Response-
    An image that is compelling can be from a 35mm or mf. Remember what I said " to have a good set up is good, to know how to anticipate the shot is better but to be at the right place at the right time with the right settings is best". Maybe that time has not come yet but I,m believing it will and it will be a "magical" moment.
    In conclusion, I sincerely would be intersted in seeing some of your work.
    Please lets move forward,
    Troy Aitken.
    Edited by Troy Aitken
  5. Troy
    Don't be discouraged! Forums are about learning and finding things out but aren't always the easiest of place to express oneself in ways that come across just as intended. Discussing complex issues in brief notes is difficult at the best of times, but do post images. I for one am interested to see how you find handling the housed MF and images from it will give a good idea - especially if you comment about your own satisfaction level with the image you post. I don't post many images, but if I do I allow people to look at the image as a whole - if they don't want to accept my comments about, well its a free ..... er, world I suppose! Bottom line is that if I like one of my own images then I'm satisfied, if others do then its bonus time, but assessing IQ (whatever that is) from web postings is very, very difficult.
  6. OK Craig.
    I'm not the one ignoring IQ definitions while sweeping to conclusions regarding the superiority of the larger format, Paul.
    Defining a subjective measure objectively is impossible by definition, but that doesn't mean you can't make relative comparisons (and make them easily). In this thread, an obvious, fair standard of comparison is a 35mm full frame, best-of-breed 1Ds2.
    Considering that Troy states that the H3D is capable of 5'x8' prints, it's sensor is 1.5x larger and offers roughly 1.5x the linear resolution, that would mean that the 1Ds2 is capable of better than a 3'x5' print. If the 1Ds2 is not capable of that, then the H3D must have better per-pixel IQ. I don't need an absolute definition of IQ in order to conclude that. If anyone disagrees, I'm eager to hear their explanation for why I'm mistaken.
  7. Troy,
    This thread didn't start out as an H3D underwater advocacy thread though there were bound to be elements of that and there's nothing wrong with advocacy. Anyone who chooses to read the thread does so because the topic interests them. That includes me and I'm quite interested in your results. If you can think back to the beginning of the thread, my first question was what macro lens you used and how did you obtain sufficient close focus. There was a reason for that. First of all, I researched housing MF a while ago and concluded the lenses didn't support the kinds of shooting I preferred. Second, I felt that good, reliable information about the format is an important part of advocating it.
    Regarding macro lenses, the discussion didn't get contentious for me until my points about the limitations of your macro lenses were dismissed by Dan. There has been a fairly consistent string of specious comments coming from Dan that have been stated with an air of expertise that he most definitely doesn't possess. It's not conducive to friendly discussion.
    Misleading and inaccurate claims don't serve anyone's interest here and I see no value in advocating equipment just because it is expensive and prestigious. A housed H3D could be the ultimate housed DSLR for certain kinds of shooting. It would be important to know the limitations of what it is suitable for, however. I've encouraged you to shoot certain kinds of shots, show crops and corners, etc. and others have as well. We do this because we want to see the strengths and weaknesses of the system. If your system has a compelling strength, we all want to see it and encourage you to demonstrate it in its most effective light. We aren't interested in beating you up over your shots.
    I don't disagree with you that what's most important underwater is being in the right place at the right time and being prepared. It's far more important than the type of equipment you use. Many of us feel that's a good argument against such an expensive, limited system. A certain degree of flexibility is important to us underwater.
    Finally, I don't want to discourage you from continuing to posting results. Just because I disagree with things you've said does not mean I am your enemy. I would be delighted to see results from your rig that impress everyone here.
    craig
  8. Troy, part of image reproduction quality goes back to tonality, and dealing with the compression that results from reproducing an image.
    Anybody who is familiar with the Zone System can relate to what I'm about to write. Basically, human vision has a very wide dynamic range, and about the limits as to what you can capture on a CCD is about 12 stops, while film is anywhere from 10 to 12 stops. The problem is that when you go to make a C-print, you're limited (by D(max) - D(min)) to about 6 stops; while in an enlarger with B&W film you can squeeze about 7-8 stops with dodging & burning. ALL of the commercial RIP's used by Durst, ZBE and Cymbolic Sciences only have 8 bit resolution -- That's 8 stops total range, assuming "perfect" paper.
    But wait a minute! Didn't our scene contain 10-12 stops of dynamic range? This is where management of the toe and shoulder of the curve come into play, i.e. this is where shadow and highlight details are held... Or lost.
    This is where the CCD-RAW image conversion software comes into play; and this is easily verified: You can take the same raw file from a 1Ds2 and convert it in ACR, Canon's own software, and CaptureOne... And get totally different results. (We did just that at Faulkner Studios this past spring, trying to diagnose an issue with wood tones reproducing properly.)
    To make a long story short, an example of holding highlight details and shadow details simultaneously is a bride & groom: You have to hold the folds & lace in the white bridal gown while also holding the shadow details in the groom's tux. With color, it's even tougher, because you have three separate curves that have to be managed, without color crossover.
    In addition, CCD's have "blind spots" where certain colors munge into others. Most notable is (are) purples, which fade into blue. Full Spectrum RGB (formerly DCF Full Spectrum) was basically the first product to address this issue; although it appears that PhaseOne has also incorporated the principle into CaptureOne.
    DISCLAIMER: I was, a beta tester for Tribeca Labs for Full Spectrum RGB; and in fact my photo is on the shrink-wrap package.
    I'm not very familiar with Hasselblad's Flexcolor software -- I think it was a holdover from their FlexTite scanner software -- but what was part of the dog & pony show 2 weeks ago in NYC at the H3D-II launch was the new "Phocus" software for handling their CCD-RAW images. In any case, the tonality of the images in their "end-to-end" -- Lens, camera, CCD, software -- system is quite stunning.
    Incidentally, you (Troy) can probably open your Hassy files in CaptureOne Pro -- Download the 30-day time bombed demo and give it a try; and compare the results. I have a suspicion that, at least on land, your Flexcolor software is better, since it corrects for chromatic aberrations, because it "knows" which lens was used.
  9. Part Two:
    Another issue you (Troy) face is the distortion added by the variations in optical properties of the port, as well as at the water-port and port-air boundaries. I'm not sure if Phocus allows you to enter manual correction coefficients; but one of the hot products at PhotoPlus is DxO Optics Pro 5, which automates the process.
    I almost forgot: Most any RAW converter will work with your H3D files, because Hasselblad fully supports the .DNG standard. (I know for a fact the H3D-II outputs .DNG-compatible files; so even if your H3D does not, the firmware upgrade will take care of it.)
    Anyway, getting back to the subject at hand, there are many factors that go into "image quality;" and some of these, although subjective (such as bokeh), have "causes" (like the geometry of the aperture opening) that can be easily identified.
  10. Speak of the devil: The announcement for CaptureOne v4 ß2 just hit my Inbox...
    All of you RAW shooters, have at it! ;)
    Update: It requires WinXP/SP2, Vista, or Mac X10.4.10 :guiness:
    [in case you're wondering why I am :angry:, it is because I'm running Win2k/Server/SP4; and I do not want Active Directory here at home...]
    Edited by Dan Schwartz
  11. Troy,
    craig
    Hello Craig,
    That's a step in the right direction. I specifically stated that the mf is a good mid-macro shooter and is in not way an excellent choice for super-macro shots. I also said at least I can crop and get a good image to print. That being said, why would you say that I need to back it up with good sound technical information. there is nothing that I said that is remotely putting down 35mm format and glorifying the mf even as being prestigous. You throw in these words, adjectives and comments that are misleading people to think that I am saying something that I am not. You are putting me in a bad light. If other people choose to say what they want to say then so be it. Don't throw me in the pot.
    If you are so interested in good sound technical information, then why are you reluctant to illustrate your points to give as a reference? It's like saying Troy you post, I critique and I will stay safe with my technical information. If I were the one stating mf is superior, then I would be like you and say "show it". You will most definately help me to understand you if you would simply post some of your super macro shots and very wide angle shots and give us your 100% crop and edge detail samples to illustrate your point. I bet there will be strengths and weaknesses in both formats depending on the purposes you use them for. So why speculate with continued tech talk again and again w/o any illustrations. Does that sound fair to you or will you give another excuse? Tropical storm Noel is coming our way and I have a 4 day wedding event so bear with me as I provide images to ILLUSTRATE my results. When finding limitations in the mf I hope to work around them and push the strengths as well. Who knows the potential of mf u/w. That is yet to be seen created by someone in the right place at the right time. You do u/w photography right? How many images do you throw away and honestly keep? If you take 100 do you keep 10, 15, 20 or maybe 5? A lot of the super macro images taken on the 35mm format are out of focus and edge detail are slightly blurred. They look awesome in 2x3 or 4x6 or even 5x7. But very few are actually in focus and have sharp definative lines on the subject. So we may all tout about our equipment but, I think its the experience of diving, exploring and looking for that awesome shot.
    Troy
  12. Hello Dan,
    Good to see you still at it.
    The Imageprint rip software prints full 16bit .
    All the best,
    Troy
  13. Guys - to keep this thread readable (which is worthwhile as there is good info in here) can we keep the quoting of previous messages to the required minimum to make your points.
  14. That's a step in the right direction. I specifically stated that the mf is a good mid-macro shooter and is in not way an excellent choice for super-macro shots. I also said at least I can crop and get a good image to print. That being said, why would you say that I need to back it up with good sound technical information.
    No need to be condescending, Troy. Yes, you admitted that the H3D was not good for anything beyond basic macro but that was after continued efforts on my part to point out that it was so. The macro information in this thread I've had to find entirely by myself while overcoming an incorrect lens ID from you.
    Regarding the "good sound technical information" I've asked for, that was specifically in regards to you challenging my claim that cropping to achieve macro destroyed the advantage of the larger sensor. That is a simple truism, yet you take exception to that without offering any argument.
    While you may not be responsible for all the boasting in this thread, you've claimed multiple times that your H3D was capable of 5'x8' prints and you made other claims of superior performance. On the other hand, when you took issue with things I said, you inaccurately paraphrased me in order to argue against me. I don't see where you have room to complain.
    No and I don't offer excuses. For someone who complains of being unjustly attacked, you sure can be insulting, Troy.
    I am not speculating with tech talk---cropping reduces IQ on any camera under all circumstances. Your request that I post images is nothing more than an attempt to redirect the conversation. There is no image that I could post that would add to this discussion, but there are plenty that could take the pressure off of you.
    How is this relevant to the H3D? How is this relevant to cropping?
    Nonsense. Your inability to shoot high magnifications does not mean that no one here can.
  15. Troy, I was referring to RIP's for photo printers, not inkjet ;) printers.
    Also, if my memory is correct, you're running a Mac; and if so, ColorByte's Imageprint driver is choking on Leopard. :guiness:
    Hello Dan,
  16. Craig, looking at the end-to-end "system" of lens, CCD, and software, Troy can easily crop out 60% of the pixels and still have as many to play with as in the 16 million in a 1DsII image... and still have a better image because of better software.
    You shoot Canon CCD-RAW: Which software do you use for your conversion? Canon? CaptureOne? ACR? If you use ACR, do you correct for chromatic aberrations, vignetting, & barrel/pincushion distortion?
    Troy's software is already configured with lens data to clean up any CA, as part of the "system" he has. Granted, DxO Optics Pro now does this too; but I would still have to see the results.
    (more...)
    (cut)
    (cut)
    (balance cut)
    Also, the number of pixels a camera can deliver is overrated, when it comes to digital photo prints (as opposed to inkjet).
    The reason is as close as your CRT monitor: You get a "blending" of the pixels into a smooth photo reproduction; and because of this blending that takes place when the laser or LED hits the photo paper, you do not need a 1:1 pixel mapping, i.e. you don't need 254 ppi (for Durst Epsilon & Lambda), 300 ppi (for LightJet & ZBE Chromira), or 320 ppi (for Fuji Frontier) to produce a smooth image. These are all $90k-$150k photo printers that are used in commercial labs; and they all have RIP's (raster image processors) that resample and adjust the data accordingly.
    Getting back to the number of pixels being overrated, the question that begs to be asked is Just how big will be the largest print you need?
    Closely related is If I make a mural size print, can I trade off any quality since the viewing distance will be greater?
    Now, getting back to Troy's Hassy and it producing quality large prints, his shooting style for macro will be different than your 1DsII: Whereas you want to "fill the frame" he can simply "zoom by cropping," having the ability to lop off 60% of the pixels and still have the same number as your Canon has.
    [Granted, Troy would not be able to stop down as much -- Probably no more than f/16 -- if he intends to zoom by cropping without starting to see diffraction artifacts, as you correctly pointed out previously, since the circle of confusion would be smaller. That being said, the because he would then only be using a portion of the lens coverage real estate (off axis distance), this is balanced by greater corner sharpness due to cropping out the areas where the MTF curves fall off.]
    ...And, if you like telephoto compression of the scene, you get more of that with medium format due to the longer focal lengths for the larger CCD/film area for MF. But, that is a topic for another day, as it's almost midnight.
    Cheers!
    Dan
  17. Good morning Dan,
    I use a pc.
    Troy
  18. Craig, looking at the end-to-end "system" of lens, CCD, and software, Troy can easily crop out 60% of the pixels and still have as many to play with as in the 16 million in a 1DsII image... and still have a better image because of better software.
    You'll have to prove that, Dan. The number is about 57%, and I'm not going to take your word that Troy's software is better or that his residual image is better. One thing that is inarguable is that, once Troy crops out 60% of his pixels, his enlargement capability is similar to a 1Ds2.
    No, I don't shoot Canon, Dan, but I have in the past. Yes, I do correct for CA and vignetting and I do so manually so that the port is considered. Barrel/pincushion is not important enough underwater to be concerned with. I have corrected for that before using PS plugins, however.
    No, it isn't, because Troy's software doesn't know about the ports which introduce far more aberrations than his lenses do.
    Tell that to the one's here boasting of 5'x8' print capability!
    Yes, and that tradeoff can be made for 35mm solutions as well.
    All this is irrelevant, Dan, as your points typically are. There is a difference between an H3D and a 1Ds2 or 1Ds3. It is the relative difference that is important here. I've noticed no one has dared take on my assertion that a 1Ds2 is capable of 3'x5' prints if the H3D can do 5'x8'. Why the constant double standards?
    Not if he wants to preserve his IQ and print size advantages he can't. Furthermore, cropping in the manner you suggest gets Troy about a 35mm frame width. A 1Ds2 can easily do better than that (it starts out there with every lens!) and the difference is quite valuable.
    Yes, Dan, Troy would in essence be converting his MF rig into a 35mm one without any IQ benefits, without any print size benefits, without any high ISO benefits, and with only a 120mm macro lens option that offers only f/4 for focus and no 1.4x teleconverter. Sounds like a loser to me. You are always so eager to discard all the benefits of MF when arguing that macro isn't so bad, then turn around and extoll the virtues of MF image quality ignoring the fact that you've discarded it.
    No you don't, Dan. The 120mm has a 70mm equivalent perspective by Troy's own data. My regular macro lens offers 180mm and I use it currently on a DX crop. 35mm can easily provide 300mm or even 400mm of macro perspective while maintaining excellent quality. You are totally wrong on this one.
  19. Hello everyone,
    Here is an extreme crop of the Juvy Flamingo tongue. Come to think of it I believe I was 1ft. away, not 5" as I thought. I hope to post some more at the extreme end of my mid-macro set up. I just want to illustrate here the edge detail and so on. I was wondering if anyone could post an image that shows the edge detail using the 35mm format whilst getting closer to a critter of equal size. The Juvy Flamingo Tongue was 4-7mm. By getting the full frame closer to a critter with a 35mm format what quality loss or gain is acheived when going to print to at least 16x20.
    Troy
    Original file
  20. Looks very 'clean' to me. It sure would be nice for purposes of this discussion, if you could hook up with a 35mm format shooter, and shoot similar images with each rig. Maybe Steve Frink will read this and invite you over to the keys for a 'shootout'. I'll even come down and bring my piddly D200. :) In fact I will probably see him at DEMA when I head over there tomorrow, and suggest it.
    Seriously though I think such direct comparisons are feasible, just takes the right people hooking up.
    Edited by loftus
