D200 housing mod to D300
Started by shchae ·
  • 55Posts
  • 55Replies
  1. That is impressive.
    Any chance to do the same with Sea&Sea DX-D200?
    I think it is possible to do but, I did not have access to S&S d200 housing.
    Sam
  2. Hi Sam,
    Great work!
    I saw Mark Webster's article on your D300 in a Subal ND20 (D200) kit in UWP Mag issue 44.
    He suggested you'd like postings put here.
    Are you intending to make any more kits available? If so, do you know when and approximately how much they'll be?
    Are you considering shoe-horning a D700 or D90 in?
    Mark
  3. Hi, Sam !
    Same question for a Sea & Sea DX D200 housing ... Did you already try a kit to fit an D 300 inside ? Thanks for the info, I'm very much interested ...
  4. Same question for a Sea & Sea DX D200 housing ... Did you already try a kit to fit an D 300 inside ? Thanks for the info, I'm very much interested ...
    Me too.
  5. Sam,
    If the Subal kit is still available, I'm very interested. Please send (offline) info on pricing, shipping, and installation.
  6. Sam,
    Me too - I'm interested
  7. Is this all a big hoax - I have sent three PM's to Sam but no response.....
    Sam, are you there?
    Maybe Subal put a contract out on him.....
  8. Is this all a big hoax - I have sent three PM's to Sam but no response.....
    Sam, are you there?
    Hi,
    I replied your PM & sorry for late response.
    When I posted this modification here, I start receiving PMs & E-mails from
    all over the world & soon my PM section was full. I delete PMs after read
    and again it was full. I trevel a lot for my business and diving & I do not know
    how many PMs I did not received/bounced back. Again sorry for those members
    who did not get my response.
    Sam
  9. For anyone that is interested in this modification, I added a post on my blog with photos of my installation of the kit. It wasn't hard to do. The only tricky part was the washers under the internal extension. I believe that I can change over everything to the D200 is less than ten minutes and reinstall in about the same time. Sam did a great job with the kit. The link to the blog page is D300 into Subal D200 housing.
    Herb Segars
  10. Herb,
    Thanks very much for the clear, detailed explanation and images of your Subal conversion. I've ordered mine from Sam, and will use your page as a guide for my installation when the kit arrives.
  11. Herb,
    Dear herb
    how is the conversion underwater
  12. I was hoping that I would get the chance to try out the conversion before my dive season ended in New Jersey but I was not able to. I will be heading to Crystal River around Christmas time and I plan to try it out then. I will post how things went but based on what I see of the installation, I expect it to work just fine.
    Herb Segars
    Visit My Website
  13. Hi Sam,
    I am interested in information for the Subal D200 conversion to D300.
    I was unable to figure out how to contact you via email so please email me at
    jd.hollingshead@yahoo.com
    Thanks, -John-
  14. I haven't been able to use my modified housing yet but I received an email question from a fellow who has installed the mod and when he connects his strobes (YS-90 - I think), they do not fire. I decided to do some tests with my Ikelite DS-125's and the Subal housing with the D300 installed in the D200 housing. I have an Ikelite iTTL connector for dual Ikelite TTL strobes. I have the internal Subal strobe connector plugged into the five pin port. When I put both strobes on TTL and set the Ikelite connector to TTL, I get a lightning bolt in the camera viewfinder and the strobes fire as they should. In Aperture priority, everything works as it should. If I change the Ikelite connector to Manual and leave the camera in Aperture priority, the strobes still fire but the camera does not seem to recognize that the strobes are attached and chooses a shutter speed for an available light exposure. This is the same whether the strobes are set at TTL or in any of the manual modes. I then tried a single Ikelite DS-125 attached to the Subal connector plugged into the three pin port. I set the strobe on manual and the camera worked okay. It recognized the strobe and worked correctly in Aperture priority and the strobe fired.
    I would be interested in anyone that has performed this mod and their experience with their strobes with the D300 in the D200 housing.
  15. Hi,
    I just want to clarify that my mod has nothing to do with electric wiring but, interested to learn what
    can be the cause. I think it can be from version of YS-90 (I have seen several different version per
    manufacturing date) and/or i-ttl cnvtr.
    Sam
  16. The problem with the YS-90 was that the internal hot shoe connector was plugged into the five pin internal socket. Once the connector was plugged into the three pin connector, everything worked as it should.
  17. Well....thanks to Sam and his engineering skills I now have a fully functional D300 in my D200 Subal housing and you could say that I am quite pleased!
    The kit arrived yesterday and I spent this morning installing it. Fairly straightforward, although I did have to resort to a few long forgotten skills from when I used to be a "fitter/turner" many years ago in the UK.... The new base plate was a perfect fit, the four buttons for the focus spot position/image review required extending using the soft wire provided in the kit and the five slip on extenders for the menu & image zoom buttons had to be filed down a bit as they interfered with the camera buttons when first installed.
    Filing down the slip on extenders was the biggest job, but took less than an hour and the whole thing less that three hours!
    I have tried all of my lens & port combinations and everything seems to work just fine and the only minor negative I can see right now is that it's hard to see the blue channel when looking at the 4 channel histogram. When looking at the actual image review, you can see enough to judge whether the composure is OK and the image zoom buttons work great so you can move the image around.
    I am off to PNG on Saturday to do an assignement in Milne Bay and am really pleased to have the D300 to use. I have been very happy with my results from the D200 underwater and only bought a D300 for land use, figuring I would wait for the next generation of DX camera or go FX before upgrading again, but having the D300 in my existing housing is just heaven on a stick! It's a great camera on land and I'm looking forward to exploring it's capabilities underwater.
    If everything works out, I can keep one of my D200 bodies as my backup/land camera when on dive trips and get my other D200 converted for I/R...
    Sam, you are a legend - thanks very much!
    Don
  18. Dear Don
    Hope you enjoy Milne Bay
    Please advise me how the d300 conversion works underwater. I presume you know to and would normally remove the eyepiece cover and the LCD cover, which I gather was the problem in the past
    Don
    Don
  19. Sam:
    I'm interested in your conversion kit. How do I contact you?
    Art
  20. Sam:
    Art
    Hi,
    Send me a PM here (to 'shchae') and/or e-mail to
    chae5721 at gmail.com
    Sam
