D200 housing mod to D300
Started by shchae ·
  • 55Posts
  • 55Replies
  1. I have now done two trips to PNG with my D300 in the D20 housing and have to say that I am very pleased with the conversion. I finally got round to making a page on my website to document the actual conversion so that it's easy for anybody else considering it - here is the link:
    http://www.indopacificimages.com/pages/pag...00_convert.html
    I have also created image galleries from both trips:
    Tufi: http://www.indopacificimages.com/pages/ima...lery/index.html
    Tawali: http://www.indopacificimages.com/pages/ima...lery/index.html
    The bottom line is that if you already have a D300 and a D200 housing, this is a great way to go!
    Don
  2. Sam installed the D300 kit in my Subal during one of his recent trips to California. To label the new functions of the controls, I bought stick-on letters at a craft shop.
  3. Has anyone managed this with a Sea and Sea DX-D200 yet?
  4. I would be interested in Sea&Sea upgrade too.
  5. Hi Sam,
    This is great work. Would it be possible to convert the Subal ND80 housing to take a Nikon D90? Taking into account that under water, I usually only touch aperture, shutter speed and shutter release which are all in the same place. And sometimes the multiselector (different story). I will not use liveview or video.
    --Rob
  6. Hi
    Work is in process & it can be done.
    Subal D200 housing was tighter than Nexus but, still has room to adopt
    D300 with minor mod, using even same base plate + same back plate.
    So far,
    1.Lens hole is centered.
    2.Using same base plate (front steel piece for D200 removed & new
    D300 plate will be added to secure the camera properly).
    3.Need to tune a spring botton & on/off switch. Minor work.
    4.Using same back plate. (extra shoes need to be added like I did on Nexus).
    I am not drilling new hole or plugging the hole. Goal is to modify
    the housing with small screw driver & allen keys in 10-15 min. & put
    it back to original in same amount of time as needed, all at minimum cost.
    Sam
  7. Hi
    So far,
    Sam
    Hi Sam, My d-200 is out of service. I could get another body or upgrade to d300. I have subal housing. Any more of those adapter kits available? Sure would like one. Thank you. ED
  8. ED,
    I replied PM.
    Sam
  9. Hi Sam
    Are the D300 conversion kits still available? I have both Subal and Sea and Sea housings for the D200.
    Thanks Sean
  10. How Can I buy one kit to change my subal ND20 to ND30?
  11. Hola a todos los miembros de Wetpixel , Hello to all members of Wetpixel
    Siento escribir en castellano o español , pero tengo un mal ingles I sorry writing in spanish or castellano , but I have a bad English.
    Bueno comentarles, que yo desde hace ya algunos años vendi mi Nikon d200 que usaba con su caja Sea&sea dx d200 y compre la nikon d300 , con lo cual tuve que adaptar esta ultima a la caja Sea&sea DX D200.
    Bueno , inicialmente me pareció facil , pero a medida que iba trabajando iba encontrando obstáculos que iba superando . Antes de empezar todo contacte con un constructor de cajas ( www.sagadive.com ) , por que ellos habían realizado la modificación de una de ellas , pera la verdad es que me aportaron poco .
    Las dos SLR tiene muchos puntos en común , pero inicialmente el mayor trabajo , de mas precisión y delicado es la confección de la base de asentamiento o zapata ( quick shoe ) por que el centro de rosca del tornillo de las SLR son diferentes .
    Bien, podría seguir seguir en el tema durante varias paginas con fotos , pero antes me gustaria saber si existe alguien interado en las explicaciones
    Gracias a todos // Thank you all for your reading
    ommsub
  12. Are just got a Subal ND200 - are any of your conversion kits available?? I am especially interested in the D300.
    Mark
  13. Sam,
    Is the upgrade kit still availabe - I would be highly interessted in this kit!
    Are there maybe also other upgrade possible with the ND20?
    Thanks!
    Michael
  14. Hi,
    Upgrade was available in 2008 & are no longer available.
    Sam
