L&M Sola 1200
Started by peterbkk ·
  • 69Posts
  • 69Replies
L&M Sola 1200
  1. Is the Sola 4000 available yet or has any one tried a prototype.
    Looking to get 2 for my 5DMkII rig
  2. Apparently it's not yet ready.
  3. Apparently it's not yet ready.
    Thanks Drew any idea on when it will be available?
  4. Thanks Drew any idea on when it will be available?
    Backscatter and L&M are estimating August at the moment.
  5. Backscatter and L&M are estimating August at the moment.
    Thanks I better start saving now.
  6. What do you do when the rechargeable battery runs out? I don't believe they are user replaceable. If you send them back to L & M , how much for a replacement battery?
  7. What do you do when the rechargeable battery runs out? I don't believe they are user replaceable. If you send them back to L & M , how much for a replacement battery?
    We've all been firmly conditioned by all manufacturers, (cars, electronics, etc.) to the "planned obsolescence" concept, right?
    I doubt if too many users will ever get through the 1,000 cycles before they buy the latest and greatest lighting system...
    Regards
    Peter
  8. Maybe for you, Peter. I've repacked my NiMH a few times over for my Halogen, HID and HMI lights. And it's never close to 1k times. more like 5-600... if that!
  9. Maybe for you, Peter. I've repacked my NiMH a few times over for my Halogen, HID and HMI lights. And it's never close to 1k times. more like 5-600... if that!
    Drew , while this is a fair comment based on your experience with NiMH batteries - Peter's post is about his SOLA 1200 lights that use Lithium Iron batteries.
    Lets keep on track.
  10. Mr Mooney,
    Actually PeterBkk's comments looked to me like a comment on marketing of products in general, so it's an open comment. :) Moreover, repacking of Li-Ion is also common so the principle of repacking instead of purchasing a new battery aptly applies, so long as the cells are the same. In fact Li-Ion die after a certain time (age) more often than the number of recharges, which is a factor with NiMH/NiCad batteries.
    Now with the SOLA1200, L&M sealed the batteries in, which would mean a bit more work to repack. I haven't ripped one apart yet so I can't tell but I can't imagine for ease of assembly, that L&M would make it difficult to pull the cells out.
  11. Mr Wong ,
    Just keeping you focused :) ( pardon the pun )
    The intention for SOLA battery replacement is a return to authorised LMI service centre process .
  12. Hi,
    I might be escaping a little bit of the subject, but can you tell me wheter you prefer a Sola 1200 or a Big Blue VL 1300?
    I'm just starting in the uw video world... I might buy only one light to see how it goes and then, depending on the results, buy a second one.
    Do you think it is worth it to have only one video light? Or if I'm not using two of them it's better not to use any at all?
    So far, the only difference I've seen between these two video lights is the beam angle... and that the solas are flooding proff.
    I really appreciate the help.
    Thanks.
  13. We've all been firmly conditioned by all manufacturers, (cars, electronics, etc.) to the "planned obsolescence" concept, right?
    Regards
    Peter
    Missed this thread.. am interested in these lights actually, i like your idea of 3...I would need 3 for sure, good thinking.
    I would definitely go through 1000 cycles though, i dive a lot and am very cheap.. i don't upgrade more than once every 10 years or so :)
    The new Gates are also intriguing but these may be more my style.. hmmm.. decisions
  14. Sola 1200 is still a new addition to video light options, so not a good history of reliablity yet. But based on past history with L&M electronics, I'd buy 4 units if I normally would be using 2 lights. I've had 2 strobe fail on the same trip, so like to plan for worst case. Murphy is always looking over your shoulder.
    Edited by jcclink
  15. Missed this thread.. am interested in these lights actually, i like your idea of 3...I would need 3 for sure, good thinking.
    I've used the Sola 1200s for several months now, over about 100 dives. So far, very reliable. If diving somewhere with a lot of waterborne silt or sand, make sure you rinse the slide switches properly so they don't get sticky.
    Using 3 lights (60 degrees each) works quite well. They give you WA coverage without have to be too precise about alignment. It allows you to point the centre light downwards so, if you truck in on a subject, you don't get a shadow appearing from the bottom of the image.
    I run them on 1/2 power on night dives and when there is little natural light and on full power when competing with the sun for some fill/color light. Because the charging is so easy (wipe dry, plug-in, switch-on) I usually charge between dives but can nurse them through 2 or 3 dives if careful.
    With the 1/2" locline, they are light to carry and easy to position. They curl up out of the way alongside the housing when out of the water. The locline wraps around the light-head to protect them when travelling.
    Replacing the battery might be possible but I doubt it. Not sure how you could even open the light unit.
    But they are not that expensive that you'd mind replacing them after a few years.
    Regards
    Peter
    PS. I believe the Sola 4000 is imminent. A pair of them will light up the ocean. Built in blue filter, switches from 60 to 90 degrees. Double the price and double the weight of the 1200.
  16. I might be escaping a little bit of the subject, but can you tell me wheter you prefer a Sola 1200 or a Big Blue VL 1300?
    Preference is personal. I've had good experiences with L&M over many years.
    For a beam test comparison of the Sola with Big Blue, go to http://www.uwimaging.com/sola1200v.html click on Beam Test, select the lights you want to compare and drag the slider to the middle.
    Regards
    Peter
  17. Preference is personal. I've had good experiences with L&M over many years.
    Regards
    Peter
    Thanks for the response Peter...
    I took a look at it... is this beam test accurate? Because it seems that the sola light has smooth edges while the vL1300 has it more abrupt.
    If thats the case, as I'll start with just one head, the sola has a pro point there.
    The point is, the VL1300 comes with the filters and its easier to attach to my housing (an equinox). Does these filters make much of a difference?
    Oh my, I didn't think i'd be so hard to decide...
    Thanks again for the info.
  18. Oh my, I didn't think i'd be so hard to decide...
    Don't complain. Not so many years ago, you had to make the housing yourself... :)
    Attaching the Sola 1200 with its locline arms to any housing is quite easy. Just went through the process with my new BS Kinetics housing. Took a bit of shopping in a marine supplies shop to get the right size SS screws and couple of hours getting the locline base drilled and mounted right.
    A blue filter might be useful if you are trying to color match with the sun. I tried doing that for a while but found that it didn't make a huge difference and added another complication.
    Regards
    Peter
  19. Don't complain. Not so many years ago, you had to make the housing yourself... :)
    Regards
    Peter
    Thanks again for all the info Peter.
    Regards,
    Nathalia
  20. Thanks for the response Peter...
    I don't think L&M tested the VL1300... the light in their chart is the TL 1x30 a spot light. Apples and oranges.
