Nikon 8-15mm in the house!
Started by adamhanlon ·
  • 77Posts
  • 77Replies
  1. Being a DX shooter (D500), I will be interested to see how it will hold optically when used with a Kenko 1.4X Pro 300 Teleconverter, which will essentially turn the 8-15 into a 11.2-21mm fisheye zoom.
  2. After playing with the new lens on my D500 on land for a couple of hours this afternoon I can add the following:
    • Unlike on Adam's Seacam setup, with Nauticam, the 10-24 zoom gear is a few mm too long to get the teeth to mesh in the housing. Other gears in my collection don't appear to be easily adaptable either, so it looks like waiting for Nauticam to produce a definitive gear or making something custom.
    • As expected, the lens isn't physically compatible with Nikon's own 1.4x Mk III TC.
    • The lens will work with my fairly old version of the Kenko 1.4x Teleplus Pro 300 and as Walt suggests, this allows a full zoom range without any cut-off/vignetting on the DX sensor and presumably a maximum angle of coverage only marginally less than the Tokina 10-17 at its widest. However autofocus using this TC and D500 is subtly less good with the Nikon lens. AFS on back button appears to work well with both lenses. AFC works OK with the Tokina with just occasional and minor initial hunting. On the Nikon lens, AFC also works but with significantly more frequent and rapid hunting before the focus settles at least in indoor light. As far as I can tell at the moment, final focus accuracy is OK. I don't get the impression that this is a deal breaker for most circumstances when this combination is likely to be used, but it could be an issue if using the TC to extend reach for rapidly moving pelagics? I haven't so far compared optical quality.
    Mark
  3. Further land-based observations on the Nikkor 8-15 Fisheye used with and without a teleconverter on DX (D500):
    • A Nauticam zoom gear for this lens is now available - but there isn't currently one listed for the lens with teleconverter
    • Nauticam and Zen now have port extension recommendations. Of interest to Tokina fisheye upgraders, the relative differences from those recommended for the Tokina 10-17 vary with the specific dome. For instance Zen recommend a total of 30mm extension for the DP-100 compared with 15mm for the Tokina, while Nauticam recommend the same 20mm extension with their 210mm acrylic dome as for the Tokina. For those upgrading from a DP-100 with integrated 15mm extension, the best solution seems to be the removal of the integrated extension and reassembly of the dome assembly using shorter screws (easy), then using a Nauticam 30mm port extension.
    • My earlier experience using the Nikkor 8-15 with an elderly Kenko 1.4x Teleplus Pro 300 was possibly flawed as that particular TC became progressively dysfunctional in autofocus and aperture control and had to be replaced by a new Kenko 1.4x Teleplus Pro 300 DGX. The new TC has so far autofocussed impeccably on land with the Nikkor fisheye - scarcely different from using the lens alone.
    • Optically on land, the Nikkor performs significantly better than the Tokina across the zoom range with vastly less Chromatic Aberration and better sharpness both at the centre and edges. These comparisons have been limited to the f8 and f11 apertures I typically use behind domes.
    • With the Kenko 1.4x teleconverter the zoom range usefully becomes 11-21 with complete coverage of the DX sensor throughout the range. Fully zoomed out on DX, the angle of coverage is just slightly less that that of the lens on its own at maximum full coverage of the sensor (about 10mm zoom). Fully zoomed in to 21mm the angle of coverage (reach) is greater than that provided by the Tokina on its own but less than that provided by the Tokina plus TC (24mm).
    • Comparing the 2 fisheye lenses optically on land in combination with the 1.4x TC, the Nikkor still performs substantially better than the Tokina across their zoom ranges for Chromatic Aberration, central and edge sharpness. At 11mm and f9.0, the Nikkor is very sharp centrally but the edges are soft. At 21mm and f9.0, sharpness is still very good centrally but is also good at the edges.
    • The focal length of 11mm can be achieved either by using the Nikkor alone at mid-zoom or by using the lens with 1.4x TC fully zoomed out. Both deliver excellent central sharpness but while with the lens alone edge sharpness is good, with the TC the edges are quite poor.
    DX land-based Conclusions:
    • The Nikkor lens is a substantially better performer than the Tokina both with and without a teleconverter
    • The TC works much better optically with the Nikkor, at least peripherally, when it is zoomed in. Edge performance suffers when zoomed out. The same is probably true of the Tokina but performance is poorer with this lens throughout the zoom range and across the image.
    • It is a viable strategy to optimise the Nikkor's zoom range for DX cameras by using a Kenko 1.4x Teleplus Pro DGX teleconverter only as long as good edge performance when zoomed out can be sacrificed. Otherwise it may be better to reserve this combination for use only when fully zoomed in.
    Caveat:
    • How these observations and conclusions translate to use behind domes with their curved and close virtual images remains to be explored.
    Mark
  4. Hi MarkD, as I am still waiting for delivery of mine, I much appreciate the amount of work you put into the info you provided. Once I have mine in hand I will be seeing what this lens does behind my Zen 170mm and DP-100mm Minidome, and possibly behind Nauticam’s 140mm fisheye dome port as well. I already have the Kenko 1.4x teleconverter, along with both a20mm and 30mm set of Nauticam extension rings. All I need now is the zoom gears for the lens to work with and without the teleconverter. Then things should get interesting.
  5. I continue to be concerned by the level of flare that the 8-15mm gives sometimes, when shooting towards the sun. This photo was taken in shallow water in the Caribbean - and the sun + flare etc is making a big mess of the frame. This was shot at the 15mm end, but I was using it without the port shades and the lens hood, because I had a zoom gear on it.
    This is just a screen grab from Lightroom - but you get the idea.
    I only used the lens on one dive on this trip. Are others, who are shooting the lens more than me, finding this problem SOMETIMES when using it without the lens hood and port shades?
  6. I have found the same problem.
    This was with the 8-15mm at 15mm the lens did not have shades on it.The port is a SEACAM Fisheye Port (FP) also with the shades removed.
    Settings were 1/250@f/8, ISO 250 on a Nikon D810
    I originally thought this might be internal reflection due the lack of shades? Certainly though the flare circle at the bottom is simply lens flare and not to do with the shades...
    I found that I had to be careful framing but if I was, the lens seemed to be able to cope with high contrast scenes quite well.
    Adam
  7. I originally thought this might be internal reflection due the lack of shades? Certainly though the flare circle at the bottom is simply lens flare and not to do with the shades..
    That dim circle is a reflection of the sun reflecting off the sensor and again reflecting back onto the sensor from some lens elements. You need to have a very bright image and a very dark area where the reflection ends up. It's pretty normal with digital (sensors are far more reflective than film), and I see it with other lenses. Particularly the 14-24 f2.8, which is somewhat of a flare magnet.
  8. That's interesting and concerning, Adam - that your photo has exactly the same flare in the same place as mine. Alex
    Edited by Alex_Mustard
  9. Alex. I have recently taken about 560 images underwater with the Nikkor 8-15 fisheye on the DX format D500, around 230 of which contained partial or full sunbursts or dappled light. Most were taken with a 210mm Nauticam acrylic dome but a few were with a Zen DP100 dome and a few again were taken in conjunction with a Kenko 1.4x TC. Focal lengths varied through the DX applicable zoom range and there are a mixture of horizontal and vertical format shots. None of the images show any hint of the flare seen in your and Adam’s shots. Many of the sunburst shots were taken fairly shallow – a few at 3m. or slightly shallower. Probably the relevant difference is that using DX, I didn’t need to remove the dome shade but I didn’t use the lens hood.
    Mark
  10. Alex's shot has interesting colored vertical stripes at the top. The only thing arranged in rows or columns is related to the sensor, e.g., microlenses. Maybe worth testing with more camera models (different sensors). Topside as well to see if this is and interaction with the dome port such as reflections, e.g., off sensor through lens then off port back into the lens.
  11. "I was using it without the port shades and the lens hood, because I had a zoom gear on it"
    It hadn't occurred to me to put the lens hood on the lens within the domes, so I tried that out today at home. On the Nauticam system, the lens hood will not pass through the N120 housing throat so has to be mounted from the front after the camera has been installed and before mounting the dome. That works fine with adequate clearance for the Nauticam 210mm dome and 20mm port extension. However there is insufficient radial clearance for use with the Zen DP-100 dome and the recommended 30mm port extension. There will probably be adequate clearance using larger Zen domes. The Nauticam zoom gear does not prevent mounting of the lens hood. It would be interesting to find out if using a lens hood within larger domes avoids the flare that is apparently sometimes an issue using full frame without external dome shades.
    Mark
  12. Now the Nikkor 8-15 has been around for a while I wondered how any Subal DX users are getting on with it .
    I'd like to try this lens with the DP100 on a D500. Anyone have any info on a suitable EXR and zoom ring with the ND500 housing?
    Thanks!
  13. I purchased my Nikon 8-15mm last July and on my last dive on that year's dive trip shot it on a D800 in a Subal ND800 housing with a Seacam wideport on it.. Nice results, one of which, mating octopuses, I posted under this topic. I'm finally diving again with a new camera (Nikon D850), new housing (Nauticam NA-D850), and new port (a Saga 4" dome).
    Enroute to Australia I stopped in Bali and was able to do five dives with the above combination in conditions ranging from mediocre to great (Kalanganyar, then Menjangan Island, and finally Secret Bay). I took several hundred pictures with the fisheye behind the Saga dome which does not allow you to use Nikon's own lens shade. I did have a shade on the Saga dome port that was made from a PVC pipe-joint that I purchased from Home Depot for $6.05 and the paid a machine shot to fit to the dome. The shade also provides protection for the otherwise exposed and vulnerable glass dome.
    In none of my pictures did I get any of the unusual flare that Alex Mustard and Adam Hanlon reported. I enjoyed shooting pictures with the exaggerated perspective of the fisheye while getting quite close to subjects that were sometimes only a few centimeters in length.
    The striped catfish at Kalanganyar were only about 2-3 cm long, but look larger due to the fisheye and being only about15 cm from the dome port. The Striped Cleaner Shrimp was also quite small and was only a cm or two from the Saga dome port. The yellow frogfish, Antennarius hispidus, was about 20 cm long. The first shot with the rope was shot from about a foot away and the second shot from only a few inches.
    Although I was shooting FX with no cropping, it is easy to imagine the cropings that would have been possible had I chosen to shoot in the DX mode or 1.2 crop mode.
    Edited by divegypsy
  14. Alex. I have recently taken about 560 images underwater with the Nikkor 8-15 fisheye on the DX format D500, around 230 of which contained partial or full sunbursts or dappled light. Most were taken with a 210mm Nauticam acrylic dome but a few were with a Zen DP100 dome and a few again were taken in conjunction with a Kenko 1.4x TC. Focal lengths varied through the DX applicable zoom range and there are a mixture of horizontal and vertical format shots. None of the images show any hint of the flare seen in your and Adam’s shots. Many of the sunburst shots were taken fairly shallow – a few at 3m. or slightly shallower. Probably the relevant difference is that using DX, I didn’t need to remove the dome shade but I didn’t use the lens hood.
    Mark
    Mark whats your opinion the Nikon 8-15mm when compared directly against the Tokina 10-17mm on the Nikon D500?
    Regards Mark
  15. Hi Mark. Optically, the greatest difference is substantially less chromatic aberration with the 8-15. Subjectively, the lens is also significantly sharper. As expected, these differences are more pronounced towards the edges of the image.
    A downside is the reduced useful zoom range on DX meaning less reach. If youre not careful It is also easy to waste a few pixels by zooming out too far and cutting off the corners. These issues can be avoided by using a Kenko 1.4x teleconverter although this does sacrifice a few degrees of coverage at the wide end. Optically this combination works well behind a dome. When I last looked, no manufacturer offered a zoom gear for the combination so I use the standard Nauticam gear and a removable collar that provides the necessary extension.
    For me the image quality improvements far outweigh the minor downsides and I have retired my Tokina.
    Regards, Mark
  16. Hi Mark. Optically, the greatest difference is substantially less chromatic aberration with the 8-15. Subjectively, the lens is also significantly sharper. As expected, these differences are more pronounced towards the edges of the image.
    Regards, Mark
    Mark, appreicate your reply.
    On the wider scale of things have you compared the Nikon 8-15mm against the Nikon 10.5mm Fisheye on the D500?
    Regards Mark
    Edited by Aussiebyron
  17. Hi Mark. I cant offer personal comparative experience with the Nikon 10.5. I would suppose that as a much more modern and expensive lens, the 8-15 might be optically better, but of course as a zoom lens, design compromises will have been made. These compromises arent obvious to me in underwater use.
    Regards, Mark
    Regards, Mark
  18. So far, I have been getting really good results with the Nikon AF-S Fisheye NIKKOR 8-15mm f/3.5-4.5E ED Lens mated with a Kenko 1.4X Pro 300 Teleconverter, which essentially turns it into a 11-21mm fisheye zoom on my D500 body. In addition to having the sharpness slightly better than the Tokina 10-17, I am seeing far less CA in the images than what I would typically see when using the 10-17.
    Currently I favor using it with the Nauticam 180mm dome port with a 30mm extension ring, as well as my newly acquired Nauticam 140mm dome port with a 50mm Nauticam Extension ring. To get the lens to work with the 1.4X Teleconverter I strangely enough found that I could make one of Nauticam’s Focus gears for the Canon EF 100mm f2.8 Macro lens to work – with a slight amount of manipulation to the plastic insert ring for it.
    Here is an image from Cayman Brac shot with the lens zoom out at 11mm, 8mm if you go by the zoom ring marks from behind the Nauticam 180mm dome port with a 30mm extension ring. Exposure values: 1/180 s at f/9.5, ISO 400.
  19. Interesting topic, so for a D850 which is the best lens sigma 15mm, nikon 8-15mm, nikon 16mm?? Used with zen dp-230 or zen 100/4
  20. ^The 8-15 should still have the optical edge over the 15mm and the close focus advantage over the 16mm.
