GH5 focus issue with external monitor
Started by kun1 ·
  • 30Posts
  • 30Replies
  1. I'm having issues with my GH5 failing to focus using the back button focus when my external monitor (DP4) is connected.
    Without the DP4 connected back button focus works as expected. I have it set to lock when pressed.
    Connect DP4 backbutton focus no longer works. Pressing the shutter button half way is the only way to auto focus
    Setting the focus via back button then turning on the DP4 cancels the focus.
    Has anyone had this issue with their external monitor be it a DP4 or something else?
    Is their a known solution or a setting I can change to allow the back button focus to operate when an external monitor is connected?
    Edited by kun1
  2. No one using an external monitor with their GH5 :-( back button focus working??
  3. I ll connect it to a Ninja 2 and let you know
  4. I'm using a gh4 and it works with the smallhd 501. It is slower than without the monitor tho when shooting 4k as the signal needs to be down converted to 1080, which is a little bummer.
    Skickat från min VTR-L29 via Tapatalk
  5. I was using a Dive and See monitor for a while on my GH4 (Until the mini HDMI port packed it in) and I used back-button focus all the time. I wouldn't have thought the two models would be that different.
  6. Hi
    No issue with a GH5 and a smallHD 502 Bright monitor.
    Could be an issue with the hdmi cable?
    Claude
  7. Have you tried disabling focus assist on the DP4?
    The GH5 has a touch focus on the screen maybe the monitor is taking that over
  8. Could be an issue with the hdmi cable?
    Claude
    That was my first thought as well... Either HMDI or bulkhead connector. But the focus assist could be a good clue as well
    Edited by bubffm
  9. Thanks for the replies.
    I’ve tried a few different cables now, which eliminates the bulkhead unfortunately..
    Turned off focus assist as well to no resolve.
    Really struggling with this one, can’t think of anything else that effects the focus
  10. Using my Ninja Flame and Inferno
    - I have the back button set to 'AF-ON' (so the same as half pressing the shutter)
    Works when connected.
    I know it might sound stupid, but try plugging in your GH5 to your TV and see if it does the same.
  11. Using my Ninja Flame and Inferno
    Good idea idea, I tried it and it does the same.
    Here is a video showing what happens when I press the back focus button with a monitor/tv connected...
    Such a frustrating problem
    https://youtu.be/rWLqpDfj5Ic
  12. Hi kun1. Just came across your post below and I am having the same issue with my GH-5 and Ninja V.... when I connect the hdmi cable to the external recorder the back focus button stops working. I was wondering if you have found a solution since posting the issue last year?
  13. Hi, unfortunately I couldn't resolve the issue, I tried replacing literally every cable or connector.
    Please do update this thread if you manage to solve the problem.
    Sent from my SM-G975F using Tapatalk
  14. Sorry to hear no resolution. If I find a solution will let you know. Will try and also check with Panasonic...
  15. I'm having issues with my GH5 failing to focus using the back button focus when my external monitor (DP4) is connected.
    The AF lock button locks the focus but doesn’t refocus it just stops it where it currently is. It works identically with or without monitor for me.
    If you want the focus not to move until you hit the button again you need to set the AF/AE to AF-On and the camera in manual focus
    This works in all scenarios HDMI or not
    Af lock hold is disabled if Af-On is selected by default
    So backbutton focus=Af on
    not Af lock
    The newest firmware also have af on near and af on far both working very well
    So unless there is some other requirement back button focus works as intended on the GH5 with the external monitor connected
    not Af lock
    You are completely wrong and you don't have the humility to test for yourself.
  17. You are completely wrong and you don't have the humility to test for yourself.
    I use this camera since 2017 and not only I am familiar with the features but I can also read a manual
    Yesterday just to be sure I got the field monitor out of the cupboard and tested again and yes it does exactly what it says on the manual
    AF lock -> locks the focus
    AF on -> performs auto focus
    Page 104 GH5 manual
    There is no point using Af lock other than still images in my view
    I use Af on on all my videos land and underwater
    Page 104 GH5 manual
    Massimo do you want to make a race to who has the longest?
    I shot with Panasonic camera since GH2. I owned a GH2, GH3, GH4 and GH5 and all behave exactly the same way:
    Camera in AFS
    AF/AE Lock = AF LOCK
    AF/AE LOCK Hold = ON
    Once you press the button once, the camera REFOCUS and then LOCK THE FOCUS. I repeat: the camera REFOCUS.
    This is the default setting used on land (except die-hard filmmakers who use MF) and underwater by everyone on Pana camera for WA shots. On macro shots underwater you will use AF/AE Lock = ON and AF/AE LOCK is grayed out.
    With the monitor attached via HDMI the first settings works perfectly. Please don't force me to make a video explaining you how the AF works on Pana camera.
    Edited by Davide DB
