Sony A7C + 28-60 kit lens + WWL vs Olympus OM-D E-M1 II + 14-42 + WWL
Started by JayceeB ·
  • 68Posts
  • 68Replies
  1. 18 hours ago, JayceeB said:
    Most pictures you see of the Nauticam with 28-60 lens show the focus knob installed on the port.  This is optional, so I left it off until I decide whether a manual focus gear is required.
    Here is a photo of the focus knob that shipped with the 28-60 port.
    I could stand to remove mine. How do you plug the hole that is left?
  3. 5 hours ago, JayceeB said:
    Thanks, Waterpixel.  That helps.
    The port ships with the focus knob uninstalled.  I left it off.
    My port shipped with the focus knob installed. I don't recall anything in the box that would constitute a plug for the hole if I removed the focus knob.
    Here is what the focus knob plug looks like.PXL_20210420_185306725.jpg.95499bad7cc4705f39b13ff8dae3cadd.jpg
  5. Here are two pictures showing the Olympus+12-40+7" dome on the left and Sony+28-60+WWL-1B on the right.  (**Note: 1lb weight velcro'd to the bottom of the 7" dome for trim on the left).
  6. And this shows my complete kit.  The 200mm cross-bar mount for the WWL-1B works very well, and keeps your strobe arms clear and light.  Might be worth trying a 70x200mm float arm for the cross-bar as the entire kit still needs a bit more buoyancy.  As you can see, I only have single 200mm arms for strobe mounts to keep the kit compact.  Double arms would give more room for additional stix.
  7. Very nice and clean setup, @JayceeB. Are you planning to use a wet macro lens also?
    Kind regards,
    Ajay
  8. Yes, I have a CMC-1.  Have not yet decided how best to carry it.  Right now I just throw it in my BC pocket.  I could mount it on the cross bar, but if you want to trade WWL-1 for CMC-1, there's an awkward moment where both lenses are unmounted.  I may end up using 70x200mm float arms with a bayonet adapter on one instead of the stix.
    Yep. That is exactly why I got the double-sided bayonet mount to go on one of my float arms.
    As well, I might have times when I want to shoot something of a size that I don't want the WWL-1 or the CMC attached....
    I haven't actually used it yet, though....
  10. One item to note.
    I had issues with the A7C on two of the first 4 dives.  On the second dive of each day (not sure if this is important or not), the camera would lock up half way through the dive with a ‘Writing to Card. Please wait…’.  Turning the camera on/off underwater didn’t fix it.  I had to remove the battery and replace to get it to stop after the dive.  I made 2 changes, that seem to have fixed this issue.  I’m not sure if they are both required, but configuration options are:
    1. Changed File Format=RAW (uncompressed) + JPEG to File Format=RAW (uncompressed).
    2. Changed Finder/Monitor=Auto to Finder/Monitor=Manual. (Thanks, Phil Burghard, for this suggestion).
  11. Here are a few photos taken with the Sony.
    Distant Ambient Light as-shot and cropped (28-60+WWL-1B):  Scalloped Hammerhead
    Not a great shot, but it's only the second one i've seen, so i'll keep it, regardless of quality.  I was impressed that the camera could achieve auto-focus with the dark shark against a dark blue background.
    hammer-as-shot.jpg.6ce499b8139c2cfac2882a1c8e329a44.jpghammer-cropped.jpg.99dc41e8d57d66ba44fb7d94e35b1879.jpg
  12. Distant Ambient Light as-shot and cropped (28-60+WWL-1B):  Tiger
    Edited by JayceeB
  13. Distant Ambient Light  (28-60+WWL-1B):  General Shots
    Edited by JayceeB
  14.  (28-60+WWL-1B) Over exposed as-shot and cropped:  Baby Frogfish
    This frogfish was about 2-3 cm long.  I first tried shooting with the CMC-1, but couldn't get my lens in close enough to focus, as the fish was set back in an indentation.  Next, I tried shooting with just the 28-60 and no wet lenses, but the minimum working distance for the 28-60 at 60mm is quite large.  Next, I tried shooting with the 28-60+WWL-1B...this is what I shot with, and then cropped.  I was surprised that a shot this over-exposed could be adjusted to proper exposure.  Cropping still left an acceptable level of quality for me.
  15. Very interesting, thanks for sharing the images and your thoughts...:goodpost:
    Regarding the title of your tread, how would you personally compare the two rigs?
    Wolfgang
    Wolfgang
    Thanks, Wolfgang.  Give me a bit to formulate my comparison thoughts.
  17. (28-60+CMC-1) Macro:
    Here are a couple of examples I took with the CMC-1.  I don't have experience with this type of lens, so there were quite a few throw-aways.  Included is a seastar shrimp as-shot and cropped, and a redspotted nudibranch.
    Edited by JayceeB
  18. (28-60+WWL-1B) With Strobes:
    And finally, a few shots taken with strobes using the WWL-1B.  The frogfish is an adult nearly the size of a dinner plate.
  19. Wow, lovely turtle shot.
  20. The Turtle shot is amazing.
