TG-6 & Backscatter M52 Wide Angle Lens issue
Started by hedonist222 ·
  • 41Posts
  • 41Replies
  1. because the camera has a an option you select when you use a wide angle
    basically the camera automatically zooms in to 1.4 so that the hood doesn't show up
    this should not be the with the m52 as its designed to be used wide open as you demonstrated above
