Marelux New Soft Lite Snoot
Marelux has announced the new Soft Lite today. This is a redesign using plastic which drops the weight by 190g over the past Soft Pro line which is now discontinued. I have attached the specs and photos.
Smart Optical Flash Tube Lite (SOFT Lite) Patented Product
Product Features
  • Enables to narrow down beam coverage simply by attaching in front of strobe.
  • The aiming light of SOFT-LITE can be changed between red and white.
  • The aiming light of SOFT-LITE XW/XR is only available in one color(white or red),but the brightness of the aiming light is brighter.
  • Adjustable brightness
  • Aiming light delay off time adjustable
  • · Use one 21700 Lithium battery which can support 10 hours of continuous use(SOFT-LITE XW/XR can be used for 4 hours)
(You can use 18650 battery by using a battery adapter)
Product Specs
  • Material:Plastic
  • Length : 155mm
  • Weight : 600g (on land) Neutral buoyancy underwater
  • Waterproof depth : -100m
  • Focal length (in water) : 130mm
  • Light spot adjustable range : 3~50mm
User Feedback
Recommended Comments
There are no comments to display.
