3-D Printed DIY Fiber Optic Connectors
As a DIY Fiber Cable article was just posted, this seems like a good time to share this article on 3-D printing connectors for your DIY cables. The Connectors are really the heart of the cable, as the fiber is simply a manufactured item bought from a supplier.
One of weak points of most of these DIY's is getting the right connectors. The solutions range from buying connectors (at about $10 a pop or $20 per cable), re-using connectors from old cables (which may require drilling them out and gluing fiber) to using random bits of off the shelf hardware which may have poor fit and finish. I've tried all of these solutions.
Early in 2023, I bought my first 3D Printer and have been making a bunch of Scuba/Camera related parts. One of my early projects was a set of custom designed connectors for Optical fiber strobe cables. I think these are at least as good as the OEM cables I've seen from Nauticam, Inon, etc. And it had the added benefit of being really fun to design, print, test, and refine. I've been actively diving these connectors all year as have friends I gave cables to. Collectively we have done a couple of hundred dives with good results.
If you have a 3D printer with some TPU and PETG or PLA material, you can print these out at a very low unit cost. You will need some M3x6mm nuts and bolts and 2mm thick fiber optic to complete. I suggest either 1-meter or 1.5-meter cables depending on your strobe arm configuration.
I've just uploaded the design and STL print templates to the public sharing site Thingiverse:  https://www.thingiverse.com/thing:6134211
Thingiverse Details:
Inon Style Optical Fiber Cable Connectors
Make your own optical fiber cables using these connectors paired with 2mm fiber. I used both 613 multi-core fiber cables and cheap TosLink cables. The design assumes 2.2mm OD for the cables.
This design contains two styles of connectors: A 90deg elbow and 180deg straight connectors. The elbow part is printed with PETG. PLA will work but may not stand up as well to the elements. The actual connector parts are printed with TPU. These parts must be soft rubber, so no material substitutes are possible.
The 90deg Elbow part snaps together and is secured with two M3x6mm nuts/bolts. These nuts & bolts can be purchased from many sources like Amazon and are very low cost. (A set of M3 bolts with ~40 sets in several lengths is $10) The TPU connector and strain relief parts fit in the groves of the elbow. Thread the optical fiber through the TPU parts and align them into the elbow before screwing them together.
The TPU parts should be snug enough to hold the cable secure with no adhesive. If it is not secure, you can apply a small amount of silicone-based glue to the cable as you thread it into the TPU parts. Using glue may make it difficult to reuse the connectors should a cable get damaged.
Use the connectors in combinations that work for your camera rig. I like a 90deg connector on the top of my Nauticam housing and a 180deg connector on an Inon or Backscatter strobe. With a Retra strobe a 90deg connector will work better.
I have found these connectors to work well with a firm connection that is installed or removed with appropriate resistance.
User Feedback
Recommended Comments
turandot
Members
Very interesting. Thanks for sharing. I'll give it a try. A possible improvement would be a design to place small rubber o-rings on the connectors to the diving housing.
Dave_Hicks
Members
(edited)
The entire connector part is TPU Rubber already (the black parts). No o-ring necessary, it would be redundant. The TPU tip does have an o-ring like donut bulge in it BTW. You'll see when you blow it up in the slicer.
Edited by Dave_Hicks
svilen
Members
Hi @Dave_Hicks
Do you know if INON style connectors are the same as Sea & Sea ones?
The Inon 2-hole bush connectors are the same diameter as the Sea and Sea.
Dave_Hicks
Members
14 hours ago, svilen said:
Hi @Dave_Hicks
Yes, they are mostly standard.
svilen
Members
3 hours ago, Dave_Hicks said:
That one is my design! Hope it works for you.
Thank you for your hard work!
Dave_Hicks
Members
Definitely fun and not work.
CaolIla
Members
I agree with you, create some 3D part is fun and not work. I like that
I'm building a new snoot for Retra strobe
I was not happy with the previous... this one will be perfect... or not ... ;)
CaolIla
Members
36 minutes ago, TimG said:
Be sure to post pics, Caollla!
For sure I will post my creation, make a new topic with explanation of the conception.
Also some picture from the previous snoot and why I build a new one with a new strategy
