Backscatter Smart Control Optical TTL Flash Trigger
Backscatter Smart Control Optical TTL Flash Trigger Review & Setup Guide
[Moderators Note: Waterpixels member, James Emery, is the Marketing and Media Manager at Backscatter]
The Backscatter Smart Control Optical TTL Flash Trigger provides super-accurate, automatic flash exposures with Olympus/OM System and Sony cameras using Backscatter strobes. The Olympus/OM System trigger is TTL compatible with the Mini Flash 2 and Hybrid Flash, while the Sony trigger is TTL compatible with the Hybrid Flash. The Backscatter Smart Control Optical TTL Flash Trigger is more than just a TTL trigger, it also can be used for manual triggering, rapid firing over 30 frames per second, and HSS (high speed sync), all built into a self-contained USB-C rechargeable unit.
The Backscatter Smart Control Optical TTL Flash Trigger has three different models, two universal types for Sony and Olympus/OM System cameras, and one for Nauticam full-frame Sony housings.
Promo Smash Cut of the Backscatter Smart Control Optical TTL Flash Trigger
Watch the video for the key features of the Backscatter Smart Control Optical TTL Flash Trigger
Watch Our Full Review of the Backscatter Smart Control Optical TTL Flash Trigger
Smart Control Optical TTL for the Most Accurate Results
Underwater systems utilize different methods to achieve TTL through a camera, housing and strobe, including hardwired TTL, digital optical TTL, and S-TTL (slave or mimic TTL). The Backscatter TTL trigger uses a digital optical system in the form of Smart Control Optical TTL, which is a proprietary TTL system, to achieve accurate results.
CLICK HERE TO KEEP READING
User Feedback
Recommended Comments
There are no comments to display.
