The Ikelite housing for the Sony HDR-HC1 is possibly the most affordable one available to date. A purely mechanical housing, it offers access to almost all functions of the camcorder, incl. the inevitable manual white balance via the touch screen menu. It also includes an extra buttton for the more advanced, pro-like model Sony A1. The extra button allows you to program the manual white balance, so that you don't have to go through the touch screen menu, however the A-1 costs much more than the HC-1 ! So much more that you'd almost be able to purchase the Ikelite housing with that amount!
Detailed infos on the housing from Ikelite's website:
Housing measures 6" wide, or 10.5" wide with the removable handle bar attached; 8" high including the removable base; and 11" deep including knobs and port. Weight above water is less than ten pounds.
Molded of clear polycarbonate to provide seamless construction and corrosion-proof performance. This "Clearly Superior" design provides full view of the camcorder, control functions, and assurance the system is safe, allowing you to see if the case is sealed.
Super Eye magnifier for the optical viewfinder is included, providing enhanced viewing while wearing a diving mask. External #9290.94 Side Mount Mirror is included to provide viewing of the color monitor through the clear housing. Reversing electronic circuitry shows correct left-to-right image.
Space is provided to allow use of the optional Sony NP-FM50, NP-FM70 or NP-QM71 batteries.
The base removes instantly with a unique toggle clamp for traveling or attaching of the optional Pro Video-Lite II battery pack. The handle assembly detaches from the housing by removal of just two nuts for packing.
All camera controls can be accessed with this housing, including both manual and auto focus.
All touch screen menu functions are provided which allows white balance. The A1 allows assigning white balance to the right-front push button for which a control is provided.
Housing includes image reversing circuitry so objects appear correct when screen is viewed using the mirror.
* Power on/off/memory
* Recording start/stop
* Zoom control
* Tele Macro
* Expanded Focus
* Exposure on/off
* Exposure adjustment
* Photo button
* Manual Focus Ring
* Focus Lock switch
* Back Light button
* Glass lens port
* Viewfinder magnification and
* Mirror for viewing screen included
* Removable external UR/Pro Filter
* Accepts external wide-angle lenses
* Accepts NP-FM50, NP-FM70 or NP-QM71 optional batteries
For pics of the housing, go to: http://ikelite.com/web_two/sony_hc1.html
Please share your comments, views, tips, tricks using the HC-1/A-1 with Ikelite housing here. Thanks to all contributors!
