Sony HDR-HC1 with Ikelite housing
Started by LERF ·
  • 97Posts
  • 97Replies
  1. Super macro on video is a PITA!!!! so much harder than still cuz need to keep things steady
    Would be nice if ol Camdiver would chime in one of these days, he is excellent at super macro work
  2. Super macro on video is a PITA!!!!  so much harder than still cuz need to keep things steady
    Thanks. Now I feel a little better about my failures with the lens. I don't think I've seen Camdivers work. I've seen incredible macro work by Kris Wilk and Ray Izumi.
    In addition to keeping things still, I need to get my eyes tuned to find the small stuff. I don't think I've ever seen a nudibranch.
  3. Ok here's what I've done in the interim. It's an inexpensive solution to get my feet wet :P. I bought a set of 67mm Hoya multicoated diopter lenses from Adorama.com for $70. There is a +1 +2 & +4 in the set. From what I've heard here the +4 is a good all around closeup. I took the +1 and disassembled it removing the snap ring and glass. I then drilled a couple of small vent holes through the sides and used some Plumber's glue to attach it to the top of the housing. This ring is now a mount for the +4 when it's not in use. I'm hoping the housing doesn't compress at depth and pop it off. What do you think of the idea?
    http://67.122.16.97/lars/hc1/Hoya67mmMacroSetup.jpg
    Wish I could say I did this with the video camera but it was my Digital Elph. In So Cal you trip over Nudibranchs on every dive. They love cold water I guess.
    Edited by larsdennert
  4. Hey Lars,
    Have been following your progress and am wondering if you have gotten to white balance at depth yet? If so, is it what it is cut out to be, or overblown? I am still on the edge of trying to find the right housing!!!!
    thanks
    Jim
  5. I haven't been back in the water as the waves and rain have made things poor. I'm going to try either next week or the week after. I'll try the HID light, White Bal at depth, and my new crazy macro setup. I don't consider the diving I did to be a full test. However I feel pretty confident about it's ability. I'll definately share some more video. I think I have 40gig of web space left til I need to add another drive to the server.
  6. Hi Lars, did you get some new footage to see with your HC1? Very interested to see some demo :-) if possible, new one :-)
    ERIK
  7. Thanks marcus.
    There is a lot of distortion in the turtle video? What codec are you using or is that the lens in the housing causing it? I can see the vignetting but the softness around just outside the center of the picture is pretty bad. What WA lens does Ikelite send with that housing?
    Edited by scubadru
  8. From his sig it looks like he's using the Epoque. Rather disappointing if it is. The distortion looks more like a really strong diopter though. The Ikelite doesn't come with any lenses; just a flat 67mm threaded glass port. Marcus, have you shot with just the flat port?
    I'm going to try out my +4 close up diopter on the 25th so I'll have more video to post as well.
    I like the video that comes straight out of the flat port. I'm in no hurry to buy a WA at this point. Something else to carrry and unbalance the housing.
  9. Yes the turtle video was using an Ikelite external screw on red filter, with the Epoque screwed on top of that. I think this accentuates the vignetting since the WA lens is even further away. Without the external screw on filter and just the Epoque, the vignetting is not so bad but there is still some. Of course without the WA lens, there is no vignetting and the picture is much better.
  10. We are changing the port to mount those wide angle lenses closer to the camera. This should correct the softness Lim reported. Email <video@ikelite.com> and we can forward a replacement port for your housing............
  11. Hi Ike,
    would it be possible for us to mount the new replacement port ourselves? Wouldn't it involve glueing ?
  12. Ports simply unscrew and replacement screws on hand tight. "Simply" is misleading because you may need a strap wrench to break it loose because of "O" ring friction.
  13. Hi Ike
    Glenn emailed me asking me to send in the housing to change the port. However I have unscrewed the port myself. Could I screw a replacement port back myself if you sent it to me? Thanks.
  14. Hi Ike!
    I emailed Glen a few days ago, asking him to send me the shorter port. But after a few sleepless nights, I came to think about longer and wider port!
    Since HD need high quality lens ( check this thread: http://wetpixel.com/forums/index.php?showtopic=12059 ), it'd be a good idea to use the superb Sony VCL- HG073Y internal WA lens. This 0.7x WA lens is designed specially for the HC-1 and has aboslutely no distortation whatsoever. I use it on land all the time and don't even bother to take it off for close up shots. You can still go pretty close with this lens.
    This lens is 73cm in diameter and 6cm long, so I guess the port will have to be longer and wider as well.
    My Ikelite TRV-950 came with an 0.7x internal WA lens, so what do you think, Ike?
    Edited by LERF
  15. I will check with the knowledgeable types............
  16. We are changing the port to mount those wide angle lenses closer to the camera.  This should correct the softness Lim reported.  Email <video@ikelite.com> and we can forward a replacement port for your housing............
    Hi Ike,
    Is this a free replacement? Is it ready now?
    My friend has this very problem with his Inon w/a lens and will no-doubt contact you when he's back from his liveaboard trip.
    Nick
  17. We will fix him up. The Inon lens is designed to supplement wide angle use of the lens. It was not intended to operate through the zoom range. We have a .5x lens and port that is fine for these camera if anyone is interested.
    ike@ikelite.com
  18. Ike,
    Do you have any more thoughts on the question of a port to accommodate the Sony VCL-HG073 lens? It would be nice to have just one lens to use both underwater and above water.
    --Mark
  19. I tired out my +4 diopter this weekend. Wow the DOF is small and with telemacro I need to skip the coffee to keep things steady. Here's a reduced frame grab. It doesn't work well for anything but closeups. I'll admit I wasn't concentrating on my focusing skills those dives.
    The Light Canon works well too. The light is very white and it boots faster than I can get the rest of the settings ready. The Gates arm needs some mods so the jury is still out.
    I shot the whole day without the supplied red filter. I have to say that I couldn't get the white balance right doing it off the sand. Too green, too blue... Sheesh, just put it in outdoor mode and go. I need some practice and/or tips there.
    A short 1 minute HD video clip is on my website.
