Got my housing today! Can't seem to access the menu with the lanc plugged in and the image reversed, any clue anyone? Lars?
Regards,
LERF
Regards,
LERF
Should be ble to access either way, but you will want to turn off image reversal when manipulating the menu. You will do this direct rather than with mirror. Remember that you can return anything directly to us that needs tweaking (sounds better than repair) rather than go through a dealer. This provides fastest turn around time............
Thanks, got it! One more thing though, it's re the two rods touching the on- screen menu...can't get back to Auto White Balance after setting to manual WB, the upper rod isn't long enough can't reach it. I can tweak it and make it somewhat longer but then it wouldn't touch the shorter end of the menu. It'd be good to have a double thingy ( long and short ) on the upper rod like the lower one.
To send back to US would cost me a bomb from here, perhaps we could just swap parts ie the upper rod?
Thanks for quick response...:0
E-mail me: ike@ikelite.com
The lower rod has two fingers, one being longer than the other. Flip it to the long version. Actually I pulled the finger on the long version out a bit. It's tight to flip with the M71 battery but works.
I dove with mine today in 25ftvis and no direct sun on the water. It did awesome. The housing is much easier to use underwater than I thought it would be. I think the camera does better on auto focus underwater than above but I did lock the camera to short range focus often.
The housing is slightly negative and has outstanding balance. It right's itself nicely. The viewfinder is quite useful though I use the mirror more. The controls work pretty well though the zoom rocker is not strong enough to return the arm. Doesn't really matter as I ran in full wide the whole time. I used Outdoor white balance and the filter most of the time but the video comes out better without it in shallow water, duh! I wasn't below 35ft anyhow. I had no lights.
Yes the reversing circuit disables some stuff but I quickly got used to switching it when I needed to use the touch screen, take a few shots in photo mode, or turn it off immediately. I like that the mirror mode is on when the camera is powered up.
It picks up breathing nicely and there is less camera noise than my Canon outside a housing. Above water it will pick up my speech through the hosuing though it sounds like I'm on the other side of the submarine. ![]()
IT DOESN"T LEAK EITHER. A picture's worth a thousand words so I'll post a clip. Playing back on my HD monitor the camera reports most the footage at 6db and 0db f2.4 on high light. Downward shots were 12db and no noise.
This is a very fast edit. It is 1minute 20sec of HDV footage transcoded to WMV. It requires a fast machine to playback. I tried to get a variety of shots with different lighting a filter use. Enjoy! Oh, the large male Sheephead moving the rocks is named Oscar.
Hello Lars
Congrats on getting the camera underwater.
I downloaded your 73MB clip and it played fine. HDV gives gives so much more definition. Did you have a wide angle on?
I'm really interested in how it goes for low light, as we are thinking of getting one for our second setup.
Just so you can compare, I did a dive the other day in 22 meters in not so clear water with the FX1 and Phenom. I was getting F9+ on 50 shutter, 0db and was white balancing without any filter.
In 14 meters I'm on 100 shutter and getting f9.6+, 0db and can white balance without any filter. In fact I have yet to use the URPRO filter with it.
Hope you load up some more clips soon.
Wags
Thanks! It'll be tough to say. I was diving the east facing shore of an island in the afternoon and the sun was behind a mountain. At 10 meters I couldn't see the surface. Light was decent but not tropical direct sun by any means. You could see how hazy it was down there. No way to get F9 out of that lens underwater though. The FX1 will be hard to touch but the Ikelite housing is really easy underwater. You know you have a camera but don't feel like your commited to use it.
I didn't have a wide angle lens. Everything was shot at the camera's wide setting. I thought I'd have a tough time with focus but it worked predictably. Seems to focus down to .2 meters/1 foot and still have pretty good DOF. I even shot some two inch/50cm gobies but a wide/macro would be needed to do it nice and close. I should have tried the telemacro function.
I too like the footage I shot without the filter. It lets more light in as well and the camera does pretty well at white balancing. I actually didn't do a one touch. While I was down there I switched to Outdoor. My guess is the filter is good as a partial fix things turn really Green/Blue.
This is all new to me but much seems to translate over from still photography. I'm glad I followed your advice and held out for a housing that white balances. I'm going to need lots of practice. Stills were hard as the shutter speed was 1/60. The flash is adjustable for power so I might boost it next time to high.
Here is a still shot taken in photo mode.
Phew! Thanks Lars, what a relief!
So then what's all the fuzz on manual WB about when we don't even use it? Quote: Ikelite HC-1 manual:
Color filter: When using color filter ( during the day ), set the camera WB to Indoor for 0-15 ft depth. For 15-80ft depth, set WB to Outdoor.
Video-Lite: When using optional Video Lite at NIGHT,set the camera WB to Indoor position. During the DAY, use the Outdoor setting for subjects beyond 4-5ft and the Indoor setting for closer subjects.
I don't consider Indoor or Outdoor settings manual, they're pre-set by the camera. But what the heck, if they work...who cares!
Re the 2 rods touching the on-screen menu, I had to pull out the nipple of the upper rod a bit, it was too short to touch certain tabs, such as to going back to Auto WB.
You can't change the battery without having to take out the camera competely, unscrew the tray, swap batteries, screw back tray, insert camera..a bit hassle. Unless you're changing tapes after every dive, extra batteries seems unavoidable since HD sucks a lot more power, I'd imagine it'd be necessary to change batteries quite often. Options? cut out the piece of the bottom tray?
There's an internal lens shade that comes with the housing It's black in color and screws on to the camera lens. It supposedly to help block light refelction/refraction caused by interaction on the external color filter and the dome port ( quote: Ikelite ). I think it also stabilizes the camera lens onto the housing inside. Mine was packed loosely in the box, I couldn't find it at first since it ended up squeezed between the foams! So make sure when you get your housing, locate and secure the internal shade.
The URPro red filter also comes with the housing, well packed in an extra small box and a lanyard but alas, it's the rubberised type that just slips onto the housing lens. I wish Ike would have provided the double- threaded URPro filter that screws onto the 67mm lens and external lens can be screwed onto the filter ie wide angle. It's kinda hard and costly to get filters for each external lens that you have, expecially the large ones for the wide-angle and dome lenses.
Other than that, the housing is fine.
Can't wait to try it out underwater! ![]()
I think at deeper depths I will need to WB manually but for shallow dives I think outdoor is fine. Everything was totally experimental for me. The camera balances pretty well.
I did the same with the rods.
I used the QM71 battery and I think it will last for several dives before a change. I don't film my whole dive either. For instance I did a one hour dive and only had twelve minutes of stuff worth pointing the camera at. The rest of the time I turned it off. I don't like opening my cameras onboard. Sometimes it's necessary though. I guess you could notch the tray but dive with it for a long bit before you consider any mods.
The "shade" is actually necessary to position the camera properly. Without it you won't be able to operate the zoom/focus ring. Rembering the tape, charged battery, shade and flipping the screen around and plugging in the LANC is all that is needed before closing it up.
I have mixed feelings over the filter. I'll have to experiment more with it.
I wonder, is it recommended to keep the housing snapped shut when not in use? In long term storage it seems like it wouldn't be good for the oring. I always kept my other cameras unlatched.
You'll want to take the O-ring out and put it in a little plastic bag and then you can drop it inside the housing, when storing.
But it sounds like you guys don't have much time away from the camera. :-)
So it seems to be shaping up that there isn't always a need for manual WB, given your experience with the Outdoor WB setting.
Ah, Brine Shrimp...# of posts...lightbulb on...
Hi,
Does anyone have any experience of using this with an external 'wet' wide angle lens e.g. Inon? Or are the optical results better using the 'dry' wide angle lens provided by Sony, attached to the camera inside the Ikelite housing?
Hi,Does anyone have any experience of using this with an external 'wet' wide angle lens e.g. Inon? Or are the optical results better using the 'dry' wide angle lens provided by Sony, attached to the camera inside the Ikelite housing?
I have a Sony TRV900, Gates housing and the Inon wet wide angle lens. I got the Inon lens a few years ago as part of the Gates multiport wet switchable system. I am very happy with it.
I have several videos on my website that you can download.
www.ronrosa.com/ron/scuba.htm
The ones with footage with the Inon are Kona, Aruba, and Grand Cayman.
Look you're moving up the food chain to hermit crab
Post another thousand times and everyone will think you are the photogod. Thanks on the Oring. I'll do that on my Canon housing too. Doing that on the Nikonos IV was a guaranty for a leak.
For everyone's info the Ikelite will not accept an internal wide angle. There's no room. I was going to borrow an Inon 100 from a friend but didn't get the chance. It takes a Type II threaded 67mm version per Ike. Maybe next dive. B)
Look you're moving up the food chain to hermit crabPost another thousand times and everyone will think you are the photogod. B)
Does that mean i get to change from Manta boy... ![]()
I've been diving an Ikelite Housed HC1 w/ Inon UWL-100 Type 1. I was fully expecting to hate the optics of the combination, but have been very impressed. Displayed on a 47" TV I see no noticable issues with corner sharpness. I haven't tried a Sony or Century wide angle behind the dome yet, either. Not enough time to dive...
With Telemacro enabled and 1 Inon UCL-165M67 Macro lens, I was shooting the face of a shark nosed goby full frame. I'm going to invest in a better tripod to sacrifice to the saltwater gods, then really see what this thing can do for supermacro w/ stacked macros.
I had the Ikelite with HC1 as my first setup for underwater video. I used the Inon type 2 wide angle lens. Most of my shots are not macro and I do see that the center of the is in focus but the edges are not. I used the large Ikelite red filter but it was not secure and lost the red plastic during a high current dive. The housing with the Inon is somewhat negatively bouyant and can be tiring to hold in current when you need to use one hand to swim against current. I had a backup double threaded red filter that was more secure. One has to unthread the lens in the ocean to get rid of the bubbles. Then when get to depth, do the manual white balance. This is cumbersome as you have to hold the housing sideways and find a white target while manipulating the joysticks. I wore a glove in my left hand only. That could be a problem in cold water environment. The white balance would need to be reset if you ascend to a different depth. Some of the pins were too long in my housing and would press on to the button at depth due to higher pressure outside. This prevented the use of the touch screen during the initial use and therefore no manual white balance. Luckily I was able to solve it.
Just some random thoughts. If I plan to dive frequently, I would get the A1 for easier manual white balance. I don't think my housing has that extra button for the A1 customized button but I don't know where it would be anyways since I don't have one. I have some awesome footage but will need to figure out who to transfer to the PC and how to convert before I can share.
Tony
Tony,the custom button on the A1 is on the right side of the camera, having the lens facing away from you. It's just next to the focus ring and is the same button on the HC1 assigned for flash settings.
Did you remove the base unit while using the wide angle lens? That might help with the weight....
Some divers don't use the white card but I made one connected to standard balls and arms with clamps and can attached it to the top of the housing grip. That way I still have both hands free to do any settings.
Did you used manual one touch WB? Ikelite recommends otherwise: quote HC-1 manual:
Hi Sim
Just got my housing yesterday and took it to the swimming pool. Like you I could not swtich back to auto white balance from manual WB because the upper rod was too short. How did you solve this? Did you email Ike?
I also got an Epoque wet wide angle lens that I haven't tried yet. As for the internal lens shade I'll have to look for it carefully in the box since I haven't come across it!
I got a Fisheye FIX light HG20DX for lighting. At 20W I wonder if it's bright enough..
Looking forward to going to Bali this weekend to try out the setup!
Just pull out the rubber tip a bit, Ileite will send you proper replacepment tips if you email them and maybe the lens shade as well? They should pack it in a box, mine was squeezed between the foams, luckily I found it before disposing the box!
Have a good trip to Bali, loking forward to your comments on the HC-1 an the housing.
Cheers!
