Sony HDR-HC1 with Ikelite housing
Started by LERF ·
  • 97Posts
  • 97Replies
  1. Image reversing circuit must be turned "off" so touch screen menu pads can be accessed properly by the controls. Then turn it back on. We are trying to determine if pal version has touch screen pads in a different location.
  2. You can't change the battery without having to take out the camera competely, unscrew the tray, swap batteries, screw back tray, insert camera..a bit hassle. Unless you're changing tapes after every dive, extra batteries seems unavoidable since HD sucks a lot more power, I'd imagine it'd be necessary to change batteries quite often. Options? cut out the piece of the bottom tray?
    The URPro red filter also comes with the housing, well packed in an extra small box and a lanyard but alas, it's the rubberised type that just slips onto the housing lens. I wish Ike would have provided the double- threaded URPro filter that screws onto the 67mm lens and external lens can be screwed onto the filter ie wide angle. It's kinda hard and costly to get filters for each external lens that you have, expecially the large ones for the wide-angle and dome lenses.
    Other than that, the housing is fine.
    Can't wait to try it out underwater!  :)
    Hi Sim,
    Are you using the FM50 battery? That only has about 80 min recording time. I use the QM71D which lasts 200 mins. There is also the QM91D which lasts 315 mins, although I haven't tried it. It is quite thick and I'm not absolutely sure it fits in the housing.
    BTW I got the Ikelite screw on red filter for the housing and I tried screwing on my Epoque 0.56X Wide conversion lens DCL-20 onto it and it works, although the two surfaces come together very close for comfort!
  3. Hi, Any one using an A1e, and if yes how is the cam and is quality? Do you take good footage? Anyone could compair with HC1?
    ERIK
  4. Painted Frogfish,
    I have both the FM-50 and QM-71 batteries. How come you got the screw on red filter from Ikelite and I've got the rubberised slip-on one? Shouldn't they provide the same one to each housing?
    Ike, any comments on this?
  5. Hi Sim
    No, I got the rubberised slip on one. But I also ordered the screw on one from my supplier.
  6. The little wand covers for the touch screen are not ideal. They are rounded at the end to a sort of tip. When in use the tip doesn't touch the screen but instead more the side of the cover. However the tip limits how far out you can pull it before it interferes with the base plate while the short finger is being articulated. I'm thinking to square it off by cutting the tip off to get another mm of reach. The top wand touches with a narrow edge. It too may benefit from some shaving so it will contact with a larger area and thereby contact more buttons.
    Also I'd be extremely surprised if the QM91 battery would work in the housing. The 71 barely fits inside and the little space that remains is needed in order to flip the screen wand from short to long finger.
    http://67.122.16.97/lars/hc1/IkeliteWands.jpg
    Edited by larsdennert
  7. Here's another picture for everyone on my lighting solution. I mounted a UK Light Canon HID using a Gates arm from scuba.com. Less than $300 for the setup. Doesn't sound bad if you say it quickly. Wow it's a bright light. Makes the UK 1200 D Cell Halogen look like it needs new batteries. Haven't dove with the new setup. Waves are 15ft here in CA. Surf's up dude.
    http://67.122.16.97/lars/hc1/IkeLightCanon.JPG
    Happy Holidays to all.
  8. lars, thanks for the status messages.
    Question: How is your access to the zoom in/out lever?
    With the mechanical controls not on the handles, how is your access? Is your hand large enough to reach with your thumb? With 7mm gloves I could think that a possibility.
    Or do you find that you don't change zoom often?
  9. Hi Shasta
    The zoom is on the right upper side of the housing. It is a little cylindrical control which you have to twist clockwise/counterclockwise and to do so you have to take your hand off the right handle.
  10. Yea you can see it sticking out at an angle on my light canon pic. The other one in the center operates the reversing circuitry.
    The only controls that can be operated without removing a hand are the Start/Stop and Photo. The Start/Stop is actually a bit of a stretch with the thumb and I have pretty big hands.
    I don't find myself using the zoom very much. I leave it on wide and frame as close as possible until those fish get nervous. I do the same with still photography. You really want the minimum amount of water between you and the subject. I set the focus to 0.2m which is 8 inch and then creep in. On longer shots the auto focus sometimes works but guessing the manual distance seems to work pretty well too with enough DOF to get things clear.
    Now I'm debating on lenses. Mr. Frogfish I see you have both the 100UWL and the 165 macro. What do you end up using more? I'm leaning toward the macro.
  11. AELung, are you zooming with the UWL100? The lens should only be used at its wide angle setting.
  12. Hi Lars
    I don't have the 100UWL. The Inon 165 macro has a bayonet type thread for my S50 camera, not the video. The only lens I have for the video is an Epoque wide angle0.56x, but it vignettes.
  13. Hi Lars
    What do you find more useful? I know Canon made a macro diopter for the S series but I've not tried one. The macro lenses I've had always came in useful. I'm debating whether to get the macro or something like the Inon 100 or Epoque 67mm thread lens.
    The wide should allow close up too with it's big DOF but it's pretty heavy underwater. Real macro might be better. Maybe I should search...
  14. How was your search Lars? Has anyone got any recommendations as to macro options available (for HC1/Ikelite)??
  15. How was your search Lars? Has anyone got any recommendations as to macro options available (for HC1/Ikelite)??
    Here is a nice comparison of Inon and Epoque I found on Marinecamera's website.
    I imagine you have to be very close to the subject with the Epoque and focusing will be difficult. I guess that's the trade off for a powerful lens.
  16. That's a great comparison. I did a similar thing with some above water macro rings I have.
    http://67.122.16.97/lars/hc1/BowerMacroFullWide.JPG
    http://67.122.16.97/lars/hc1/BowerMacroFullZoom.JPG
    http://67.122.16.97/lars/hc1/BowerMacroPartialZoom.JPG
    http://67.122.16.97/lars/hc1/TeleMacroZoom.JPG
    I decided that too strong of a macro ring gives you severe edge distortion. The Inon 165 looks pretty good and it's about a $100 as I recall. Expensive for a diopter but cheaper than a $329 WA. My guess is that it's a +4 to +6 but it's so hard to say. People seem to recommend a +4. I used one on a still camera some years back and it cut the focal distance 1/4. Tiffen sells 67mm diopters cheap. I can't recall the retailer site at the moment but it was sets of 3 in +2 +4 +6or7.
    I'm actually in Orlando FL this week on business but snuck off to Epcot for the DiveQuest thingy with some friends. They took video of us and had a really wide angle (inside their housing) I swam right past the camera guy at 2ft and almost my whole body is in the shot.
    Some friends shot video from behind the glass on the dry side too. I'm going to rip the UW DVD they soak you for and remix it with the dry stuff back to DVD and give a short presentation to our dive club on diving in a fish tank. It's a really different type of dive. Anyway, It's got me thinking again about how usefull a WA can be especially when the vis is 200 ft.
  17. I have the DML-2 from Epoque and wouldn't dream of using it on the video camera.
    I have used Inon's UCL-165 M67 Lens, and 2 of them stacked, and had lots of good resullts. With Ikelite's flat port, the single macro lens and Telemacro mode frames the face of a shark nose goby full frame, and the 2 together was framing things like eyeballs. I was blown away, but couldn't come close to keeping the shot steady.
    I guess I'll have to sacrifice a nice ball head and an expensive macro focusing rail to the saltwater gods to get those shots...
  18. I have the DML-2 from Epoque and wouldn't dream of using it on the video camera.
    Can I ask why ? Seems like a pretty powerful lens and if photographer's use it why wouldn't it be good for video ?
    Ron
  19. Sorry, I missed that.
    I think it will be too strong to use with any success. I'll try it though, in due time. Our shore dive here is totally blown out, so it will be a few days...
    Ryan
  20. Sorry, I missed that.
    Ryan
    Let me know how it works for you. I have one and find it very difficult to use. The depth of field is very limited and I have to be within 2-3 inches of the subject.
    I'm a newbie at macro work, so I'm not sure if it's just me or the lens is indeed difficult to use for video.
    The lens is part of my Gates Multiport package. I originally thought it was an Inon lens, but found out the macro lens is Epoque and the W/A is Inon.
